Engines_DSC_i Class Referenceabstract
This class implements the interface Engines::DSC. More...
#include <DSC_i.hxx>
Inheritance diagram for Engines_DSC_i:
 Engines_DSC_i (CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, PortableServer::ObjectId *contId, const char *instanceName, const char *interfaceName, bool notif=false)
 Engines_DSC_i (CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, Engines::Container_ptr container, const char *instanceName, const char *interfaceName, bool notif=false, bool regist=false)
virtual ~Engines_DSC_i ()
virtual void add_provides_port (Ports::Port_ptr ref, const char *provides_port_name, Ports::PortProperties_ptr port_prop)
virtual void add_uses_port (const char *repository_id, const char *uses_port_name, Ports::PortProperties_ptr port_prop)
virtual Ports::Port_ptr get_provides_port (const char *provides_port_name, const CORBA::Boolean connection_error)
virtual Engines::DSC::uses_port * get_uses_port (const char *uses_port_name)
virtual void connect_provides_port (const char *provides_port_name)
virtual void connect_uses_port (const char *uses_port_name, Ports::Port_ptr provides_port_ref)
virtual CORBA::Boolean is_connected (const char *port_name)
virtual void disconnect_provides_port (const char *provides_port_name, const Engines::DSC::Message message)
virtual void disconnect_uses_port (const char *uses_port_name, Ports::Port_ptr provides_port_ref, const Engines::DSC::Message message)
virtual Ports::PortProperties_ptr get_port_properties (const char *port_name)
CORBA::Boolean isSSLMode () override
char * instanceName ()
 CORBA method: return name of the instance, unique in this Container. More...
char * interfaceName ()
 CORBA method: return name of the component class. More...
void ping ()
 CORBA method: Test if instance is alive and responds. More...
void destroy ()
 CORBA method: Deactivate this instance. More...
Engines::Container_ptr GetContainerRef ()
 CORBA method: return CORBA reference of the Container. More...
void setProperties (const Engines::FieldsDict &dico)
 CORBA method: Gives a sequence of (key=string,value=any) to the component. More...
Engines::FieldsDict * getProperties ()
 CORBA method: returns a previously stored map (key=string,value=any) as a sequence. More...
virtual void SetOption (const char *, const char *)
 CORBA method: This method is to set an option specific to a certain EngineComponent. More...
virtual char * GetOption (const char *)
 CORBA method: This method is to get value of an option specific to a certain EngineComponent. More...
void Names (const char *graphName, const char *nodeName)
 CORBA method: used by Supervision to give names to this instance. More...
bool Kill_impl ()
 CORBA method: used in Supervision. More...
bool Stop_impl ()
bool Suspend_impl ()
bool Resume_impl ()
CORBA::Long CpuUsed_impl ()
 CORBA method: More...
 C++ method: DumpPython default implementation. More...
virtual Engines::Salome_file_ptr getInputFileToService (const char *service_name, const char *Salome_file_name)
virtual Engines::Salome_file_ptr getOutputFileToService (const char *service_name, const char *Salome_file_name)
virtual void checkInputFilesToService (const char *service_name)
virtual Engines::Salome_file_ptr setInputFileToService (const char *service_name, const char *Salome_file_name)
virtual void checkOutputFilesToService (const char *service_name)
virtual Engines::Salome_file_ptr setOutputFileToService (const char *service_name, const char *Salome_file_name)
virtual bool hasObjectInfo ()
 Return true if component can provide creation information. More...
virtual char * getObjectInfo (const char *entry)
 Get creation information for object addressed by given entry. More...
virtual char * getVersion ()
 Get version of the component. More...
PortableServer::ObjectId * getId ()
 C++ method: return CORBA instance id, the id is set in derived class constructor, when instance is activated. More...
Engines_Container_i * GetContainerPtr ()
 C++ method: return Container Servant. More...
std::string getContainerName ()
 C++ method: return the name of the container associated with this component This name does not contains the "/Containers" string and all "/" are replaced by "_". More...
void setContainerName ()
 C++ method: set the name of the container associated with this component (attribute containerName) This name does not contains the "/Containers" string and all "/" are replaced by "</em>". More...
void beginService (const char *serviceName)
 C++ method: used by derived classes for supervision. More...
void endService (const char *serviceName)
void sendMessage (const char *event_type, const char *message)
 C++ method: Send message to event channel. More...
char * graphName ()
 C++ method: – CHECK IF USED –. More...
char * nodeName ()
bool Killer (pthread_t ThreadId, int signum)
 C++ method: used in Supervision (see kill_impl) More...
void SetCurCpu ()
 C++ method: More...
long CpuUsed ()
 C++ method: More...
void CancelThread ()
 C++ method: More...
virtual void configureSalome_file (std::string service_name, std::string file_port_name, Salome_file_i *file)
 C++ method: used to configure the Salome_file into the runtime. More...
virtual void provides_port_changed (const char *provides_port_name, int connection_nbr, const Engines::DSC::Message message)=0
 This method is used by the component when the number of connection on a provides port changes. More...
virtual void uses_port_changed (const char *uses_port_name, Engines::DSC::uses_port *new_uses_port, const Engines::DSC::Message message)=0
 This method is used by the component when the number of connection on a uses port changes. More...
static bool isMultiInstance ()
static std::string GetDynLibraryName (const char *componentName)
 C++ method: return standard library name built on component name. More...
static void writeEvent (const char *request, const std::string &containerName, const char *instance_name, const char *port_name, const char *error, const char *message)
 Write a record in the trace file. More...
Protected Types
typedef std::map< std::string, Salome_file_i * > _t_Salome_file_map
typedef std::map< std::string, Engines_Component_i::_t_Salome_file_map * > _t_Service_file_map
enum  port_type { uses , provides , none }
typedef std::map< std::string, port_t * > ports
SALOME_NamingService_Abstract * getNS ()
std::string _instanceName
std::string _interfaceName
std::string _containerName
CORBA::ORB_var _orb
PortableServer::POA_var _poa
PortableServer::ObjectId * _id
PortableServer::ObjectId * _contId
Engines::Container_var _container
Engines_Component_i * _thisObj
RegistryConnexion * _myConnexionToRegistry
NOTIFICATION_Supplier * _notifSupplier
std::map< std::string, CORBA::Any > _fieldsDict
_t_Service_file_map _Input_Service_file_map
_t_Service_file_map _Output_Service_file_map
_t_Service_file_map::iterator _Service_file_map_it
_t_Salome_file_map::iterator _Salome_file_map_it
std::string _serviceName
std::string _graphName
std::string _nodeName
ports my_ports
ports::iterator my_ports_it
Static Protected Attributes
static bool _isMultiInstance = false
pthread_t _ThreadId
long _StartUsed
long _ThreadCpuUsed
bool _Executed
bool _CanceledThread
The implementation of methods are performed by the class Engines_DSC_interface.
◆ _t_Salome_file_map
typedef std::map<std::string, Salome_file_i*> Engines_Component_i::_t_Salome_file_map
◆ _t_Service_file_map
typedef std::map<std::string, Engines_Component_i::_t_Salome_file_map*> Engines_Component_i::_t_Service_file_map
◆ ports
typedef std::map<std::string, port_t *> Engines_DSC_interface::ports
◆ port_type
enum Engines_DSC_interface::port_type
uses
provides
none
◆ Engines_DSC_i() [1/2]
Engines_DSC_i::Engines_DSC_i ( CORBA::ORB_ptr  orb,
const char *  instanceName,
const char *  interfaceName,
bool  notif = false
◆ Engines_DSC_i() [2/2]
bool  notif = false,
bool  regist = false
◆ ~Engines_DSC_i()
Engines_DSC_i::~Engines_DSC_i ( )
◆ add_provides_port()
virtual void Engines_DSC_i::add_provides_port ( Ports::Port_ptr  ref,
const char *  provides_port_name,
◆ add_uses_port()
virtual void Engines_DSC_i::add_uses_port ( const char *  repository_id,
const char *  uses_port_name,
◆ beginService()
◆ CancelThread()
void Engines_Component_i::CancelThread ( )
C++ method:
References Engines_Component_i::_CanceledThread.
Referenced by CallCancelThread().
◆ checkInputFilesToService()
void Engines_Component_i::checkInputFilesToService ( const char *  service_name)
◆ checkOutputFilesToService()
void Engines_Component_i::checkOutputFilesToService ( const char *  service_name)
◆ configureSalome_file()
void Engines_Component_i::configureSalome_file ( std::string  service_name,
Salome_file_i *  file
service_namename of the service that use this Salome_file
file_port_namename of the Salome_file
fileSalome_file C++ object
Referenced by Engines_Component_i::checkInputFilesToService(), and Engines_Component_i::checkOutputFilesToService().
◆ connect_provides_port()
virtual void Engines_DSC_i::connect_provides_port ( const char *  provides_port_name)
◆ connect_uses_port()
virtual void Engines_DSC_i::connect_uses_port ( const char *  uses_port_name,
◆ CpuUsed()
◆ CpuUsed_impl()
◆ destroy()
void Engines_Component_i::destroy ( )
CORBA object is deactivated (do not respond any more to CORBA calls), the connection to Regsitry is removed (Registry informed of deactivation), internal server reference counter on the derived servant class is decremented, to allow destruction of the class (delete) by POA, when there are no more references. – TO BE USED BY CONTAINER ONLY (Container housekeeping) –
References Engines_Component_i::_id, Engines_Component_i::_poa, and MESSAGE.
◆ disconnect_provides_port()
virtual void Engines_DSC_i::disconnect_provides_port ( const char *  provides_port_name,
◆ disconnect_uses_port()
virtual void Engines_DSC_i::disconnect_uses_port ( const char *  uses_port_name,
◆ DumpPython()
Engines::TMPFile * Engines_Component_i::DumpPython ( CORBA::Boolean  isPublished,
◆ endService()
void Engines_Component_i::endService ( const char *  serviceName)
◆ get_port_properties()
virtual Ports::PortProperties_ptr Engines_DSC_i::get_port_properties ( const char *  port_name)
◆ get_provides_port()
virtual Ports::Port_ptr Engines_DSC_i::get_provides_port ( const char *  provides_port_name,
◆ get_uses_port()
virtual Engines::DSC::uses_port * Engines_DSC_i::get_uses_port ( const char *  uses_port_name)
◆ getContainerName()
std::string Engines_Component_i::getContainerName ( )
the container name (reformatted)
References Engines_Component_i::_containerName.
Referenced by create_calcium_port(), CalciumInterface::ecp_cd(), CalciumInterface::ecp_ecriture(), CalciumInterface::ecp_effi(), CalciumInterface::ecp_efft(), CalciumInterface::ecp_fin(), CalciumInterface::ecp_fini(), CalciumInterface::ecp_fint(), and CalciumInterface::ecp_lecture().
◆ GetContainerPtr()
Engines_Container_i * Engines_Component_i::GetContainerPtr ( )
References Engines_Component_i::_container, and Engines_Component_i::_poa.
◆ GetContainerRef()
Engines::Container_ptr Engines_Component_i::GetContainerRef ( )
References Engines_Component_i::_container.
Referenced by Engines_Component_i::setInputFileToService(), and Engines_Component_i::setOutputFileToService().
◆ GetDynLibraryName()
std::string Engines_Component_i::GetDynLibraryName ( const char *  componentName)
References waitContainers::cname, and TestKernelHelpers::ret.
Referenced by Abstract_Engines_Container_i::decInstanceCnt(), and Engines_Parallel_Container_i::decInstanceCnt().
◆ getId()
PortableServer::ObjectId * Engines_Component_i::getId ( )
References Engines_Component_i::_id.
Referenced by SalomeTestComponentEngine_factory(), and TestMPIComponentEngine_factory().
◆ getInputFileToService()
Engines::Salome_file_ptr Engines_Component_i::getInputFileToService ( const char *  service_name,
const char *  Salome_file_name
◆ getNS()
◆ getObjectInfo()
char * Engines_Component_i::getObjectInfo ( const char *  entry)
◆ GetOption()
char * Engines_Component_i::GetOption ( const char *  )
◆ getOutputFileToService()
Engines::Salome_file_ptr Engines_Component_i::getOutputFileToService ( const char *  service_name,
◆ getProperties()
Engines::FieldsDict * Engines_Component_i::getProperties ( )
(see setProperties)
References Engines_Component_i::_fieldsDict.
◆ getVersion()
char * Engines_Component_i::getVersion ( )
This method is supposed to be implemented in all derived classes; default implementation returns empty string that means that no version information about the component is available.
The version of the component is stored to the study, as a part of general persistence mechanism; once stored, version information in the study cannot be changed.
string containing component's version, e.g. "1.0"
Referenced by SALOME_DriverPy.SALOME_DriverPy_i::Version().
◆ graphName()
char * Engines_Component_i::graphName ( )
◆ hasObjectInfo()
bool Engines_Component_i::hasObjectInfo ( )
◆ instanceName()
◆ interfaceName()
char * Engines_Component_i::interfaceName ( )
References Engines_Component_i::_interfaceName.
◆ is_connected()
virtual CORBA::Boolean Engines_DSC_i::is_connected ( const char *  port_name)
◆ isMultiInstance()
static bool Engines_Component_i::isMultiInstance ( )
◆ isSSLMode()
◆ Kill_impl()
bool Engines_Component_i::Kill_impl ( )
References Engines_Component_i::_ThreadId, and Engines_Component_i::Killer().
◆ Killer()
bool Engines_Component_i::Killer ( pthread_t  ThreadId,
int  signum
◆ Names()
void Engines_Component_i::Names ( const char *  graphName,
const char *  nodeName
References Engines_Component_i::_graphName, Engines_Component_i::_nodeName, Engines_Component_i::graphName(), and Engines_Component_i::nodeName().
◆ nodeName()
◆ ping()
void Engines_Component_i::ping ( )
References MESSAGE.
◆ provides_port_changed()
virtual void DSC_Callbacks::provides_port_changed ( const char *  provides_port_name,
int  connection_nbr,
pure virtualinherited
This information helps the user code to detect operation on its ports.
provides_port_namethe name of the provides name that has changed.
connection_nbrthe new number of connection on the provides port.
messagecontains informations about the modification of the port.
Implemented in Superv_Component_i.
Referenced by Engines_DSC_interface::connect_provides_port(), and Engines_DSC_interface::disconnect_provides_port().
◆ Resume_impl()
bool Engines_Component_i::Resume_impl ( )
◆ sendMessage()
void Engines_Component_i::sendMessage ( const char *  event_type,
const char *  message
◆ setContainerName()
void Engines_Component_i::setContainerName ( )
References Engines_Component_i::_container, Engines_Component_i::_containerName, SALOME_ContainerPy::containerName, and pythfilter::name.
Referenced by Engines_Component_i::Engines_Component_i().
◆ SetCurCpu()
void Engines_Component_i::SetCurCpu ( )
◆ setInputFileToService()
Engines::Salome_file_ptr Engines_Component_i::setInputFileToService ( const char *  service_name,
◆ SetOption()
void Engines_Component_i::SetOption ( const char *  ,
const char *
◆ setOutputFileToService()
Engines::Salome_file_ptr Engines_Component_i::setOutputFileToService ( const char *  service_name,
◆ setProperties()
void Engines_Component_i::setProperties ( const Engines::FieldsDict &  dico)
Base class component stores the sequence in a map. The map is cleared before. This map is for use by derived classes.
dicosequence of (key=string,value=any)
◆ Stop_impl()
bool Engines_Component_i::Stop_impl ( )
◆ Suspend_impl()
◆ uses_port_changed()
virtual void DSC_Callbacks::uses_port_changed ( const char *  uses_port_name,
Engines::DSC::uses_port *  new_uses_port,
uses_port_namethe name of the uses name that has changed.
new_uses_portthe new sequence representing the uses port.
Referenced by Engines_DSC_interface::connect_uses_port(), and Engines_DSC_interface::disconnect_uses_port().
◆ writeEvent()
void Engines_DSC_interface::writeEvent ( const char *  request,
const std::string &  containerName,
const char *  instance_name,
const char *  port_name,
const char *  error,
requestthe name of the request executed
containerNamethe name of the container where the request is executed
instance_namethe name of the component where the request is executed
port_namethe name of the port that is concerned
errorif an error has occured, a string that identifies the error
messageinformations about error or about the request
References SALOME_ContainerPy::containerName, IDLparser::error(), initTrace(), TestMinimalExample::msg, out, traceLevel, and traceType.
Referenced by create_calcium_port(), CalciumInterface::ecp_cd(), CalciumInterface::ecp_ecriture(), CalciumInterface::ecp_effi(), CalciumInterface::ecp_efft(), CalciumInterface::ecp_fin(), CalciumInterface::ecp_fini(), CalciumInterface::ecp_fint(), CalciumInterface::ecp_lecture(), GenericPort< DataManipulator, COUPLING_POLICY >::get(), and GenericPort< DataManipulator, COUPLING_POLICY >::next().
◆ _CanceledThread
bool Engines_Component_i::_CanceledThread
privateinherited
◆ _container
◆ _containerName
◆ _contId
◆ _Executed
◆ _fieldsDict
◆ _graphName
◆ _id
◆ _Input_Service_file_map
◆ _instanceName
◆ _interfaceName
◆ _isMultiInstance
bool Engines_Component_i::_isMultiInstance = false
staticprotectedinherited
◆ _myConnexionToRegistry
RegistryConnexion* Engines_Component_i::_myConnexionToRegistry
◆ _nodeName
◆ _notifSupplier
◆ _orb
◆ _Output_Service_file_map
◆ _poa
◆ _Salome_file_map_it
◆ _Service_file_map_it
◆ _serviceName
◆ _StartUsed
◆ _thisObj
◆ _ThreadCpuUsed
◆ _ThreadId
◆ my_ports
◆ my_ports_it
