Salome_file_i Class Reference
A class to manage file transfer in SALOME. More...
#include <Salome_file_i.hxx>
Inheritance diagram for Salome_file_i:
 Salome_file_i ()
 Default constructor,. More...
virtual ~Salome_file_i ()
virtual void load (const char *hdf5_file)
 CORBA method. More...
virtual void save (const char *hdf5_file)
virtual void save_all (const char *hdf5_file)
virtual void setLocalFile (const char *comp_file_name)
virtual void setDistributedFile (const char *comp_file_name)
virtual void connect (Engines::Salome_file_ptr source_Salome_file)
virtual void connectDistributedFile (const char *file_name, Engines::Salome_file_ptr source_Salome_file)
virtual void setDistributedSourceFile (const char *file_name, const char *source_file_name)
virtual void recvFiles ()
virtual void removeFile (const char *file_name)
virtual void removeFiles ()
virtual void setContainer (Engines::Container_ptr container)
virtual Engines::files * getFilesInfos ()
virtual Engines::file * getFileInfos (const char *file_name)
virtual Engines::SfState * getSalome_fileState ()
virtual CORBA::Long open (const char *file_name)
 CORBA method: try to open the file given. More...
virtual void close (CORBA::Long fileId)
 CORBA method: close the file associated to the fileId given at open. More...
virtual Engines::fileBlock * getBlock (CORBA::Long fileId)
CORBA::Long openW (const char *fileName)
 open the given file in write mode (for copy) More...
void putBlock (CORBA::Long fileId, const Engines::fileBlock &block)
 put a data block for copy into a file More...
virtual PortableServer::POA_ptr _default_POA ()
 Get default POA for the servant object. More...
virtual void Register ()
 Increment reference counter. More...
virtual void UnRegister ()
 Decrement reference counter. More...
virtual void Destroy ()
Protected Types
typedef std::map< int, FILE * > _t_fileAccess
typedef std::map< std::string, Engines::file > _t_fileManaged
typedef std::map< std::string, Engines::Salome_file_var > _t_fileDistributedSource
virtual bool checkLocalFile (std::string file_name)
 local C++ method : This method is used by revFiles to check if a local managed file is ok. More...
virtual bool getDistributedFile (std::string file_name)
 local C++ method : this method is used by recvFiles to get a distributed file from is distributed source. More...
int _fileId
long _path_max
_t_fileAccess _fileAccess
_t_fileManaged _fileManaged
_t_fileDistributedSource _fileDistributedSource
Engines::SfState _state
Engines::Container_ptr _container
Engines::Salome_file_var _default_source_Salome_file
int _fileKey
int _ctr
PortableServer::POA_var myPOA
int myRefCounter
◆ _t_fileAccess
typedef std::map<int, FILE*> Salome_file_i::_t_fileAccess
◆ _t_fileDistributedSource
typedef std::map<std::string, Engines::Salome_file_var> Salome_file_i::_t_fileDistributedSource
◆ _t_fileManaged
typedef std::map<std::string, Engines::file> Salome_file_i::_t_fileManaged
◆ Salome_file_i()
◆ ~Salome_file_i()
Salome_file_i::~Salome_file_i ( )
◆ _default_POA()
PortableServer::POA_ptr SALOME::GenericObj_i::_default_POA ( )
reference to the default POA for the servant
Reimplemented in SALOMEDS_ChildIterator_i, SALOMEDS_GenericAttribute_i, SALOMEDS_SComponentIterator_i, SALOMEDS_SObject_i, SALOMEDS_UseCaseBuilder_i, and SALOMEDS_UseCaseIterator_i.
References SALOME::GenericObj_i::myPOA.
◆ checkLocalFile()
bool Salome_file_i::checkLocalFile ( std::string  file_name)
fileNamename of the file
References _fileManaged, and ORBConfigFile::path.
Referenced by recvFiles(), and Parallel_Salome_file_i::recvFiles_node().
◆ close()
void Salome_file_i::close ( CORBA::Long  fileId)
fileIdgot in return from open method
References _fileAccess, and MESSAGE.
Referenced by load().
◆ connect()
void Salome_file_i::connect ( Engines::Salome_file_ptr  source_Salome_file)
◆ connectDistributedFile()
void Salome_file_i::connectDistributedFile ( const char *  file_name,
◆ Destroy()
void SALOME::GenericObj_i::Destroy ( )
Deprecated:
Use UnRegister() instead.
◆ getBlock()
Engines::fileBlock * Salome_file_i::getBlock ( CORBA::Long  fileId)
References _fileAccess, and FILEBLOCK_SIZE.
◆ getDistributedFile()
bool Salome_file_i::getDistributedFile ( std::string  file_name)
If there is no source_file_name for the file, it tries to get the file from the source. In this case, the source distributed file has to managed only one file to be able to the send the file.
References _fileDistributedSource, _fileManaged, MESSAGE, and ORBConfigFile::path.
◆ getFileInfos()
Engines::file * Salome_file_i::getFileInfos ( const char *  file_name)
◆ getFilesInfos()
Engines::files * Salome_file_i::getFilesInfos ( )
CORBA method.
See also
Engines::Salome_file::getFilesInfos
References _fileManaged, and Utils_Identity::file.
Referenced by main().
◆ getSalome_fileState()
Engines::SfState * Salome_file_i::getSalome_fileState ( )
CORBA method.
See also
Engines::Salome_file::getSalome_fileState
References _state.
◆ load()
◆ open()
CORBA::Long Salome_file_i::open ( const char *  file_name)
If the file is readable, return a positive integer else return 0;
fileNamefile name to be transferred
fileId = positive integer > 0 if open OK.
References _fileAccess, _fileId, _fileManaged, MESSAGE, and ORBConfigFile::path.
◆ openW()
CORBA::Long fileTransfer_i::openW ( const char *  fileName)
CORBA method: try to open the file. If the file is writable, return a positive integer else return 0;
fileNamepath to the file to be transferred
References fileTransfer_i::_ctr, fileTransfer_i::_fileAccess, and fileTransfer_i::_fileKey.
◆ putBlock()
void fileTransfer_i::putBlock ( CORBA::Long  fileId,
const Engines::fileBlock &  block
CORBA method: put a block of data into the file associated to the fileId given at openW.
fileIdgot in return from openW method
blockan octet sequence to copy into opened file
References fileTransfer_i::_fileAccess, and SALOME_utilities::SCRUTE().
◆ recvFiles()
◆ Register()
void SALOME::GenericObj_i::Register ( )
◆ removeFile()
void Salome_file_i::removeFile ( const char *  file_name)
CORBA method.
See also
Engines::Salome_file::removeFile
References MESSAGE.
◆ removeFiles()
void Salome_file_i::removeFiles ( )
CORBA method.
See also
Engines::Salome_file::removeFiles
References MESSAGE.
◆ save()
◆ save_all()
◆ setContainer()
void Salome_file_i::setContainer ( Engines::Container_ptr  container)
◆ setDistributedFile()
◆ setDistributedSourceFile()
void Salome_file_i::setDistributedSourceFile ( const char *  file_name,
const char *  source_file_name
◆ setLocalFile()
◆ UnRegister()
void SALOME::GenericObj_i::UnRegister ( )
◆ _container
◆ _ctr
int fileTransfer_i::_ctr
◆ _default_source_Salome_file
Engines::Salome_file_var Salome_file_i::_default_source_Salome_file
◆ _fileAccess
_t_fileAccess Salome_file_i::_fileAccess
Referenced by close(), getBlock(), and open().
◆ _fileDistributedSource
◆ _fileId
int Salome_file_i::_fileId
Referenced by open(), and Salome_file_i().
◆ _fileKey
int fileTransfer_i::_fileKey
◆ _fileManaged
◆ _path_max
long Salome_file_i::_path_max
◆ _state
◆ myPOA
◆ myRefCounter
int SALOME::GenericObj_i::myRefCounter
