SALOMEDS_SObject_i Class Reference
#include <SALOMEDS_SObject_i.hxx>
Inheritance diagram for SALOMEDS_SObject_i:
 SALOMEDS_SObject_i (const SALOMEDSImpl_SObject &, CORBA::ORB_ptr)
 Function : constructor Purpose : More...
virtual ~SALOMEDS_SObject_i ()
 Function : destructor Purpose : More...
virtual PortableServer::POA_ptr _default_POA ()
 Get default POA for the servant object. More...
virtual CORBA::Boolean IsNull ()
 Returns true if the SObject does not belong to any Study. More...
virtual char * GetID ()
 Function :GetID Purpose : More...
virtual SALOMEDS::SComponent_ptr GetFatherComponent ()
 Function : GetFatherComponent Purpose : More...
virtual SALOMEDS::SObject_ptr GetFather ()
 Function : GetFather Purpose : More...
virtual CORBA::Boolean FindAttribute (SALOMEDS::GenericAttribute_out anAttribute, const char *aTypeOfAttribute)
 Function : FindAttribute Purpose : Find attribute of given type on this SObject. More...
virtual CORBA::Boolean ReferencedObject (SALOMEDS::SObject_out obj)
 Function : ReferencedObject Purpose : More...
virtual CORBA::Boolean FindSubObject (CORBA::Long atag, SALOMEDS::SObject_out obj)
 Function : FindSubObject Purpose : More...
virtual char * Name ()
 Function : Name Purpose : gets a name. More...
virtual void Name (const char *)
 Function : Name Purpose : sets a name. More...
virtual SALOMEDS::ListOfAttributes * GetAllAttributes ()
 Function : GetAllAttributes Purpose : Returns list of all attributes for this sobject. More...
virtual CORBA::Object_ptr GetObject ()
 Function : GetObject Purpose : More...
virtual char * GetName ()
 Function : GetName Purpose : More...
virtual char * GetComment ()
 Function : GetComment Purpose : More...
virtual char * GetIOR ()
 Function : GetIOR Purpose : More...
virtual void SetAttrString (const char *, const char *)
 Function : SetAttrString Purpose : More...
virtual CORBA::Short Tag ()
 Function : Tag Purpose : More...
virtual CORBA::Short GetLastChildTag ()
 Function : GetLastChildTag Purpose : More...
virtual CORBA::Short Depth ()
 Function : Depth Purpose : More...
virtual CORBA::LongLong GetLocalImpl (const char *theHostname, CORBA::Long thePID, CORBA::Boolean &isLocal)
virtual void Register ()
 Increment reference counter. More...
virtual void UnRegister ()
 Decrement reference counter. More...
virtual void Destroy ()
static SALOMEDS::SObject_ptr New (const SALOMEDSImpl_SObject &, CORBA::ORB_ptr)
CORBA::ORB_var _orb
SALOMEDSImpl_SObject * _impl
PortableServer::POA_var myPOA
int myRefCounter
◆ SALOMEDS_SObject_i()
SALOMEDS_SObject_i::SALOMEDS_SObject_i ( const SALOMEDSImpl_SObject &  impl,
CORBA::ORB_ptr  orb
◆ ~SALOMEDS_SObject_i()
SALOMEDS_SObject_i::~SALOMEDS_SObject_i ( )
References _impl.
◆ _default_POA()
PortableServer::POA_ptr SALOMEDS_SObject_i::_default_POA ( )
reference to the default POA for the servant
◆ Depth()
CORBA::Short SALOMEDS_SObject_i::Depth ( )
< TODO: conversion from int to CORBA::Short
References _impl, SALOMEDSImpl_SObject::Depth(), and SALOMEDS::lock().
◆ Destroy()
void SALOME::GenericObj_i::Destroy ( )
Deprecated:
Use UnRegister() instead.
◆ FindAttribute()
CORBA::Boolean SALOMEDS_SObject_i::FindAttribute ( SALOMEDS::GenericAttribute_out  anAttribute,
const char *  aTypeOfAttribute
References _impl, _orb, SALOMEDS_GenericAttribute_i::CreateAttribute(), SALOMEDSImpl_SObject::FindAttribute(), and SALOMEDS::lock().
◆ FindSubObject()
CORBA::Boolean SALOMEDS_SObject_i::FindSubObject ( CORBA::Long  atag,
◆ GetAllAttributes()
SALOMEDS::ListOfAttributes * SALOMEDS_SObject_i::GetAllAttributes ( )
< TODO: conversion from size_t to int
References _impl, _orb, SALOMEDS_GenericAttribute_i::CreateAttribute(), SALOMEDSImpl_SObject::GetAllAttributes(), and SALOMEDS::lock().
◆ GetComment()
char * SALOMEDS_SObject_i::GetComment ( )
References _impl, SALOMEDSImpl_SObject::GetComment(), and SALOMEDS::lock().
◆ GetFather()
SALOMEDS::SObject_ptr SALOMEDS_SObject_i::GetFather ( )
References _impl, _orb, SALOMEDSImpl_SObject::GetFather(), SALOMEDS::lock(), and New().
◆ GetFatherComponent()
SALOMEDS::SComponent_ptr SALOMEDS_SObject_i::GetFatherComponent ( )
References _impl, _orb, SALOMEDSImpl_SObject::GetFatherComponent(), SALOMEDS::lock(), and SALOMEDS_SComponent_i::New().
◆ GetID()
char * SALOMEDS_SObject_i::GetID ( )
References _impl, SALOMEDSImpl_SObject::GetID(), and SALOMEDS::lock().
◆ GetIOR()
char * SALOMEDS_SObject_i::GetIOR ( )
References _impl, SALOMEDSImpl_SObject::GetIOR(), and SALOMEDS::lock().
◆ GetLastChildTag()
CORBA::Short SALOMEDS_SObject_i::GetLastChildTag ( )
References _impl, SALOMEDSImpl_SObject::GetLastChildTag(), and SALOMEDS::lock().
◆ GetLocalImpl()
CORBA::LongLong SALOMEDS_SObject_i::GetLocalImpl ( const char *  theHostname,
CORBA::Long  thePID,
CORBA::Boolean &  isLocal
References _impl.
◆ GetName()
char * SALOMEDS_SObject_i::GetName ( )
References _impl, SALOMEDSImpl_SObject::GetName(), and SALOMEDS::lock().
◆ GetObject()
CORBA::Object_ptr SALOMEDS_SObject_i::GetObject ( )
◆ IsNull()
CORBA::Boolean SALOMEDS_SObject_i::IsNull ( )
References _impl, SALOMEDSImpl_SObject::IsNull(), and SALOMEDS::lock().
◆ Name() [1/2]
char * SALOMEDS_SObject_i::Name ( )
References _impl, SALOMEDS::lock(), and SALOMEDSImpl_SObject::Name().
◆ Name() [2/2]
void SALOMEDS_SObject_i::Name ( const char *  name)
References _impl, SALOMEDS::lock(), pythfilter::name, and SALOMEDSImpl_SObject::Name().
◆ New()
◆ ReferencedObject()
CORBA::Boolean SALOMEDS_SObject_i::ReferencedObject ( SALOMEDS::SObject_out  obj)
◆ Register()
void SALOME::GenericObj_i::Register ( )
◆ SetAttrString()
void SALOMEDS_SObject_i::SetAttrString ( const char *  name,
const char *  value
References _impl, SALOMEDS::lock(), pythfilter::name, and SALOMEDSImpl_SObject::SetAttrString().
◆ Tag()
CORBA::Short SALOMEDS_SObject_i::Tag ( )
References _impl, SALOMEDS::lock(), and SALOMEDSImpl_SObject::Tag().
◆ UnRegister()
void SALOME::GenericObj_i::UnRegister ( )
◆ _impl
◆ _orb
◆ myPOA
◆ myRefCounter
int SALOME::GenericObj_i::myRefCounter
