KERNEL_PY.batchmode_salome Namespace Reference
def ImportComponentGUI (ComponentName)
def SalomeGUIgetAllSelected (self)
def generateName (prefix=None)
def IDToObject (id)
 from SalomePyQt import * WITHOUTIHMclass SalomeGUI(SALOMEGUI_Swig): WITHOUTIHMgetAllSelected = SalomeGUIgetAllSelected More...
def ObjectToSObject (obj)
def ObjectToID (obj)
def IDToSObject (id)
def PersistentPresentation (theSO, theWithID)
def GetTree (theSO)
def CheckCopyPaste (theSO, theInfo, theComponentPaste)
def FindFileInDataDir (filename)
Variables
 orb = None
int step = 0
float sleeping_time = 0.01
float sleeping_time_max = 1.0
 lcc = LifeCycleCORBA(orb)
 naming_service = SALOME_NamingServicePy_i(orb)
 obj = None
 myStudy = obj._narrow(SALOMEDS.Study)
 myStudyName = myStudy._get_Name()
◆ CheckCopyPaste()
def KERNEL_PY.batchmode_salome.CheckCopyPaste (   theSO,
  theInfo,
  theComponentPaste
◆ FindFileInDataDir()
def KERNEL_PY.batchmode_salome.FindFileInDataDir (   filename)
◆ generateName()
def KERNEL_PY.batchmode_salome.generateName (   prefix = None)
◆ GetTree()
def KERNEL_PY.batchmode_salome.GetTree (   theSO)
◆ IDToObject()
def KERNEL_PY.batchmode_salome.IDToObject (   id)
◆ IDToSObject()
def KERNEL_PY.batchmode_salome.IDToSObject (   id)
◆ ImportComponentGUI()
def KERNEL_PY.batchmode_salome.ImportComponentGUI (   ComponentName)
◆ ObjectToID()
def KERNEL_PY.batchmode_salome.ObjectToID (   obj)
◆ ObjectToSObject()
def KERNEL_PY.batchmode_salome.ObjectToSObject (   obj)
◆ PersistentPresentation()
def KERNEL_PY.batchmode_salome.PersistentPresentation (   theSO,
  theWithID
◆ SalomeGUIgetAllSelected()
def KERNEL_PY.batchmode_salome.SalomeGUIgetAllSelected (   self)
Variable Documentation
◆ lcc
KERNEL_PY.batchmode_salome.lcc = LifeCycleCORBA(orb)
◆ myStudy
KERNEL_PY.batchmode_salome.myStudy = obj._narrow(SALOMEDS.Study)
◆ myStudyName
KERNEL_PY.batchmode_salome.myStudyName = myStudy._get_Name()
◆ naming_service
KERNEL_PY.batchmode_salome.naming_service = SALOME_NamingServicePy_i(orb)
◆ obj
KERNEL_PY.batchmode_salome.obj = None
Referenced by SALOME_NamingService._current_directory(), SALOME_LifeCycleCORBA._FindComponent(), SALOME_NamingService._initialize_root_context(), _PTR(), Abstract_Engines_Container_i.Abstract_Engines_Container_i(), SALOMESDS::DataScopeServerTransaction.addKeyValueInVarErrorIfAlreadyExisting(), SALOMESDS::DataScopeServerTransaction.addKeyValueInVarHard(), SALOMESDS::DataScopeServerTransaction.addMultiKeyValueSession(), SALOMEDS_UseCaseBuilder.Append(), SALOMEDS_UseCaseBuilder.AppendTo(), SALOME_NamingService.Change_Directory(), SALOMEDS_Study_i.Clear(), CommonDataScopeServerMain(), container_common_main(), Container_proxy_impl_final.create_component_instance_env(), create_instance(), Engines_Parallel_Container_i.create_paco_component_node_instance(), Engines_Parallel_Container_i.createCPPInstance(), CreateDataScope(), Abstract_Engines_Container_i.createExecutableInstance(), Abstract_Engines_Container_i.createFileRef(), Engines_Parallel_Container_i.createFileRef(), Abstract_Engines_Container_i.createInstance(), Engines_MPIContainer_i.createMPIInstance(), Abstract_Engines_Container_i.createPyNode(), Abstract_Engines_Container_i.createPyScriptNode(), Abstract_Engines_Container_i.createPythonInstance(), Engines_Parallel_Container_i.createPythonInstance(), SALOMESDS::DataScopeServerTransaction.createRdExtInitVarTransac(), SALOMESDS::DataScopeServerTransaction.createRdExtVarFreeStyleTransac(), SALOMESDS::DataScopeServerTransaction.createRdExtVarTransac(), SALOMESDS::DataScopeServerTransaction.createRdOnlyVarTransac(), SALOMESDS::DataScopeServerTransaction.createRdWrVarTransac(), CreateStudyNSAbstract(), SALOMESDS::DataScopeServerTransaction.createWorkingVarTransac(), SALOMESDS::DataScopeServerTransaction.DataScopeServerTransaction(), SALOMESDS::DataServerManager.DataServerManager(), SALOMEDS_StudyBuilder.DefineComponentInstance(), SALOME_NamingService.Destroy_Directory(), SALOME_NamingService.Destroy_Name(), NormalFunctor.duplicate(), TransactionFunctor.duplicate(), Engines_MPIContainer_i.Engines_MPIContainer_i(), Engines_Parallel_Container_i.find_or_create_instance(), Abstract_Engines_Container_i.find_or_create_instance(), SALOME_ContainerManager.FindContainer(), SALOMEDS_SObject_i.FindSubObject(), FromPyToCpp(), Abstract_Engines_Container_i.get_embedded_NS_if_ssl(), KERNEL.getContainerSA(), GetDriver(), SALOMEDS_DriverFactory_i.GetDriverByIOR(), SALOMEDS_DriverFactory_i.GetDriverByType(), GetDSMInstanceInternal(), GetExternalServerInstance(), GetLockMasterInstance(), KERNEL.getLoggerServantSA(), GetLogManagerInstance(), SALOMESDS::BasicDataServer.getMyDataScopeServer(), SALOMEDS_SObject.GetObject(), SALOMEDS_SObject_i.GetObject(), LifeCycleCORBATest.GetRemoteHost(), SALOMESDS::DataScopeServerTransaction.getRequestSwitcher(), SALOMESDS::DataServerManager.getRequestSwitcher(), KERNEL.getResourcesManager(), KERNEL.getSalomeLauncher(), KERNEL.getSalomeSession(), SALOMESDS::DataServerManager.GetScopePtrGivenName(), SALOME_ExternalServerLauncher.GetServerHandlerGivenName(), SALOMESDS::TransactionMorphRdWrIntoRdOnly.getVar(), SALOME_ContainerManager.GiveContainer(), SALOMEDS_UseCaseBuilder.HasChildren(), SALOMEDS_Study_i.Init(), SALOME_Launcher.init(), SALOME_Trace.Initialize(), SALOMESDS::PickelizedPyObjRdExtServer.invokePythonMethodOn(), SALOMESDS::PickelizedPyObjRdWrServer.invokePythonMethodOn(), IORToObject(), SALOMEDS_UseCaseBuilder.IsUseCase(), SALOMEDS_UseCaseBuilder.IsUseCaseNode(), SALOME_ContainerManager.LaunchContainer(), SALOME_ExternalServerLauncher.launchServer(), Engines_MPIContainer_i.Lcreate_component_instance(), SALOMESDS::DataScopeServerBase.listVars(), SALOMEDS_StudyBuilder.LoadWith(), main(), SALOMESDS::DataScopeServerBase.moveStatusOfVarFromRdExtOrRdExtInitToRdExt(), SALOMESDS::DataScopeServerBase.moveStatusOfVarFromRdExtOrRdExtInitToRdExtInit(), SALOMESDS::DataScopeServerBase.moveStatusOfVarFromRdOnlyToRdWr(), SALOMESDS::DataScopeServerBase.moveStatusOfVarFromRdWrToRdOnly(), NamingService_WaitForServerReadiness(), NormalFunctor.narrow(), TransactionFunctor.narrow(), ObjectToIOR(), OSS.operator<<(), SALOME::GenericObj_wrap< GENOBJ >.operator=(), Parallel_Salome_file_i.Parallel_Salome_file_i(), SALOMESDS::PickelizedPyObjServer.pickelize(), SALOMESDS::PickelizedPyObjServer.Pickelize(), SALOMESDS::PickelizedPyObjRdExtInitServer.PickelizedPyObjRdExtInitServer(), SALOMESDS::PickelizedPyObjServer.PickelizedPyObjServer(), SALOMEDS_SObject_i.ReferencedObject(), SALOME_NamingService.Register(), RegisterCompoInternal(), SALOMEDS::GenObjRegister.RegisterGenObj(), SALOMEDS_UseCaseBuilder.Remove(), SALOMESDS::DataScopeServerTransaction.removeKeyInVarErrorIfNotAlreadyExisting(), SALOMEDS_Study_i.RemovePostponed(), SALOMESDS::RequestSwitcherBase.RequestSwitcherBase(), SALOME_Embedded_NamingService.Resolve(), SALOME_NamingService.Resolve(), SALOME_NamingService.ResolveComponent(), SALOME_NamingService.ResolveFirst(), SALOME_Embedded_NamingService.ResolveFirst(), RetrieveCompoInternal(), KERNEL.retrieveNewStudyServantSA(), SALOMESDS::TransactionDictModify.rollBack(), SALOMETraceCollector.run(), SALOME_ContainerManager.SALOME_ContainerManager(), SALOME_ExternalServerLauncher.SALOME_ExternalServerLauncher(), SALOME_LifeCycleCORBA.SALOME_LifeCycleCORBA(), SALOME_LogManager.SALOME_LogManager(), SALOME_ResourcesManager.SALOME_ResourcesManager(), SALOMEDS_Study_i.SALOMEDS_Study_i(), SALOMEDS.sendMessageToGUI(), SALOMEDS_UseCaseBuilder.SetCurrentObject(), SALOMESDS::PickelizedPyObjServer.setNewPyObj(), SALOME_ContainerScriptExecPerfLog.setPyObj(), SALOME_ContainerScriptPerfLog.setPyObj(), SALOME_ContainerPerfLog.setPyObj(), NamingServiceTest.setUp(), SALOMEDSTest.setUp(), SALOMEDSTest_Embedded.setUp(), SALOME_ContainerManager.ShutdownContainersGeneric(), SALOMESDS::DataScopeServerBase.shutdownIfNotHostedByDSM(), SALOMEDS_UseCaseBuilder.SortChildren(), Test(), NamingServiceTest.testChangeDirectory(), NamingServiceTest.testConstructorDefault(), NamingServiceTest.testConstructorOrb(), NamingServiceTest.testCreateDirectory(), NamingServiceTest.testDestroyDirectory(), NamingServiceTest.testDestroyName(), NamingServiceTest.testFind(), NamingServiceTest.testGetIorAddr(), NamingServiceTest.testRegisterResolveAbsNoPath(), NamingServiceTest.testRegisterResolveAbsWithPath(), NamingServiceTest.testRegisterResolveRelativeNoPath(), NamingServiceTest.testRegisterResolveRelativeWithPath(), NamingServiceTest.testResolveBadName(), NamingServiceTest.testResolveBadNameRelative(), NamingServiceTest.testResolveComponentEmptyComponentName(), NamingServiceTest.testResolveComponentEmptyContainerName(), NamingServiceTest.testResolveComponentEmptyHostname(), NamingServiceTest.testResolveComponentFalseNbproc(), NamingServiceTest.testResolveComponentOK(), NamingServiceTest.testResolveComponentUnknownComponentName(), NamingServiceTest.testResolveComponentUnknownContainerName(), NamingServiceTest.testResolveComponentUnknownHostname(), NamingServiceTest.testResolveFirst(), NamingServiceTest.testResolveFirstRelative(), NamingServiceTest.testResolveFirstUnknown(), NamingServiceTest.testResolveFirstUnknownRelative(), SALOMEDSTest.testSObject(), SALOMEDSTest.testStudyBuilder(), TraceCollector_WaitForServerReadiness(), SALOMEDS::GenObjRegister.UnRegisterGenObj(), SALOMEDS_Study_i.URL(), SALOMESDS::DataScopeServerTransaction.waitForKeyInVar(), SALOMESDS::DataScopeServerTransaction.waitForKeyInVarAndKillIt(), and SALOMESDS::DataScopeServerBase.~DataScopeServerBase().
◆ orb
KERNEL_PY.batchmode_salome.orb = None
◆ sleeping_time
float KERNEL_PY.batchmode_salome.sleeping_time = 0.01
◆ sleeping_time_max
float KERNEL_PY.batchmode_salome.sleeping_time_max = 1.0
◆ step
int KERNEL_PY.batchmode_salome.step = 0
