NamingServiceTest Class Reference
#include <NamingServiceTest.hxx>
Inheritance diagram for NamingServiceTest:
void setUp ()
void tearDown ()
void testConstructorDefault ()
 Test default constructor: must be followed by a call to init_orb(ORB) More...
void testConstructorOrb ()
 Test constructor with ORB parameter. More...
void testRegisterResolveAbsNoPath ()
 Test Register and resolve of a single CORBA object with absolute pathname, without subdirectories. More...
void testRegisterResolveRelativeNoPath ()
 Test Register and resolve of a single CORBA object with relative pathname, without subdirectories. More...
void testRegisterResolveAbsWithPath ()
 Test Register and resolve of a single CORBA object with absolute pathname, in a subdirectory. More...
void testRegisterResolveRelativeWithPath ()
 Test Register and resolve of a single CORBA object with relative pathname, in a subdirectory. More...
void testResolveBadName ()
 Test resolve with a name not known. More...
void testResolveBadNameRelative ()
 Test resolve with a name not known, with a relative path. More...
void testResolveFirst ()
void testResolveFirstRelative ()
 Test register and resolve multiple objects, test resolveFirst, relative path Register a few objects in /nstestfirstrel/echo_n where n is the object id. More...
void testResolveFirstUnknown ()
 Test resolveFirst with unknown name. More...
void testResolveFirstUnknownRelative ()
 Test resolveFirst with unknown name, relative Path. More...
void testResolveComponentOK ()
 Test ResolveComponent works as specified. More...
void testResolveComponentEmptyHostname ()
 Test ResolveComponent gives nil pointer if hostname is not given (empty) More...
void testResolveComponentUnknownHostname ()
 Test ResolveComponent gives nil pointer if hostname is unknown. More...
void testResolveComponentEmptyContainerName ()
 Test ResolveComponent when containerName is empty. More...
void testResolveComponentUnknownContainerName ()
 Test. More...
void testResolveComponentEmptyComponentName ()
 Test. More...
void testResolveComponentUnknownComponentName ()
 Test. More...
void testResolveComponentFalseNbproc ()
 Test with a false number nbproc. More...
void testContainerName ()
 Test. More...
void testContainerNameParams ()
 Test. More...
void testBuildContainerNameForNS ()
 Test. More...
void testBuildContainerNameForNSParams ()
 Test. More...
void testFind ()
 Test. More...
void testCreateDirectory ()
 Test. More...
void testChangeDirectory ()
 Test. More...
void testCurrentDirectory ()
 Test. More...
void testList ()
 Test. More...
void testListDirectory ()
 Test. More...
void testListDirectoryRecurs ()
 Test. More...
void testListSubdirs ()
 Test. More...
void testDestroyName ()
 Test. More...
void testDestroyDirectory ()
 Test. More...
void testDestroyFullDirectory ()
void testGetIorAddr ()
 Test. More...
void _destroyDirectoryRecurs (std::string path)
 DestroyFullDirectory is not recursive Need Housekeeping of /Containers for further tests ! More...
CORBA::ORB_var _orb
SALOME_NamingService _NS
PortableServer::POA_var _root_poa
PortableServer::POAManager_var _pman
PortableServer::ObjectId_var _myFactoryId
NSTEST_aFactory_i * _myFactory
CORBA::Object_var _factoryRef
 CPPUNIT_TEST_SUITE (NamingServiceTest)
 CPPUNIT_TEST (testConstructorDefault)
 CPPUNIT_TEST (testConstructorOrb)
 CPPUNIT_TEST (testRegisterResolveAbsNoPath)
 CPPUNIT_TEST (testRegisterResolveRelativeNoPath)
 CPPUNIT_TEST (testRegisterResolveAbsWithPath)
 CPPUNIT_TEST (testRegisterResolveRelativeWithPath)
 CPPUNIT_TEST (testResolveBadName)
 CPPUNIT_TEST (testResolveBadNameRelative)
 CPPUNIT_TEST (testResolveFirst)
 CPPUNIT_TEST (testResolveFirstRelative)
 CPPUNIT_TEST (testResolveFirstUnknown)
 CPPUNIT_TEST (testResolveFirstUnknownRelative)
 CPPUNIT_TEST (testResolveComponentOK)
 CPPUNIT_TEST (testResolveComponentEmptyHostname)
 CPPUNIT_TEST (testResolveComponentUnknownHostname)
 CPPUNIT_TEST (testResolveComponentEmptyContainerName)
 CPPUNIT_TEST (testResolveComponentUnknownContainerName)
 CPPUNIT_TEST (testResolveComponentEmptyComponentName)
 CPPUNIT_TEST (testResolveComponentUnknownComponentName)
 CPPUNIT_TEST (testResolveComponentFalseNbproc)
 CPPUNIT_TEST (testContainerName)
 CPPUNIT_TEST (testContainerNameParams)
 CPPUNIT_TEST (testBuildContainerNameForNS)
 CPPUNIT_TEST (testBuildContainerNameForNSParams)
 CPPUNIT_TEST (testFind)
 CPPUNIT_TEST (testCreateDirectory)
 CPPUNIT_TEST (testChangeDirectory)
 CPPUNIT_TEST (testCurrentDirectory)
 CPPUNIT_TEST (testList)
 CPPUNIT_TEST (testListDirectory)
 CPPUNIT_TEST (testListDirectoryRecurs)
 CPPUNIT_TEST (testListSubdirs)
 CPPUNIT_TEST (testDestroyName)
 CPPUNIT_TEST (testDestroyDirectory)
 CPPUNIT_TEST (testDestroyFullDirectory)
 CPPUNIT_TEST (testGetIorAddr)
 CPPUNIT_TEST_SUITE_END ()
std::string _getTraceFileName ()
 Set Trace mechanism. More...
◆ _destroyDirectoryRecurs()
void NamingServiceTest::_destroyDirectoryRecurs ( std::string  path)
◆ _getTraceFileName()
std::string NamingServiceTest::_getTraceFileName ( )
  • delete preexisting trace classes if any
  • set trace on file Get or initialize the orb Create a SALOME_NamingService instance
References GetTmpDir().
Referenced by setUp().
◆ CPPUNIT_TEST() [1/36]
NamingServiceTest::CPPUNIT_TEST ( testBuildContainerNameForNS  )
◆ CPPUNIT_TEST() [2/36]
NamingServiceTest::CPPUNIT_TEST ( testBuildContainerNameForNSParams  )
◆ CPPUNIT_TEST() [3/36]
NamingServiceTest::CPPUNIT_TEST ( testChangeDirectory  )
◆ CPPUNIT_TEST() [4/36]
NamingServiceTest::CPPUNIT_TEST ( testConstructorDefault  )
◆ CPPUNIT_TEST() [5/36]
NamingServiceTest::CPPUNIT_TEST ( testConstructorOrb  )
◆ CPPUNIT_TEST() [6/36]
NamingServiceTest::CPPUNIT_TEST ( testContainerName  )
◆ CPPUNIT_TEST() [7/36]
NamingServiceTest::CPPUNIT_TEST ( testContainerNameParams  )
◆ CPPUNIT_TEST() [8/36]
NamingServiceTest::CPPUNIT_TEST ( testCreateDirectory  )
◆ CPPUNIT_TEST() [9/36]
NamingServiceTest::CPPUNIT_TEST ( testCurrentDirectory  )
◆ CPPUNIT_TEST() [10/36]
NamingServiceTest::CPPUNIT_TEST ( testDestroyDirectory  )
◆ CPPUNIT_TEST() [11/36]
NamingServiceTest::CPPUNIT_TEST ( testDestroyFullDirectory  )
◆ CPPUNIT_TEST() [12/36]
NamingServiceTest::CPPUNIT_TEST ( testDestroyName  )
◆ CPPUNIT_TEST() [13/36]
NamingServiceTest::CPPUNIT_TEST ( testFind  )
◆ CPPUNIT_TEST() [14/36]
NamingServiceTest::CPPUNIT_TEST ( testGetIorAddr  )
◆ CPPUNIT_TEST() [15/36]
NamingServiceTest::CPPUNIT_TEST ( testList  )
◆ CPPUNIT_TEST() [16/36]
NamingServiceTest::CPPUNIT_TEST ( testListDirectory  )
◆ CPPUNIT_TEST() [17/36]
NamingServiceTest::CPPUNIT_TEST ( testListDirectoryRecurs  )
◆ CPPUNIT_TEST() [18/36]
NamingServiceTest::CPPUNIT_TEST ( testListSubdirs  )
◆ CPPUNIT_TEST() [19/36]
NamingServiceTest::CPPUNIT_TEST ( testRegisterResolveAbsNoPath  )
◆ CPPUNIT_TEST() [20/36]
NamingServiceTest::CPPUNIT_TEST ( testRegisterResolveAbsWithPath  )
◆ CPPUNIT_TEST() [21/36]
NamingServiceTest::CPPUNIT_TEST ( testRegisterResolveRelativeNoPath  )
◆ CPPUNIT_TEST() [22/36]
NamingServiceTest::CPPUNIT_TEST ( testRegisterResolveRelativeWithPath  )
◆ CPPUNIT_TEST() [23/36]
NamingServiceTest::CPPUNIT_TEST ( testResolveBadName  )
◆ CPPUNIT_TEST() [24/36]
NamingServiceTest::CPPUNIT_TEST ( testResolveBadNameRelative  )
◆ CPPUNIT_TEST() [25/36]
NamingServiceTest::CPPUNIT_TEST ( testResolveComponentEmptyComponentName  )
◆ CPPUNIT_TEST() [26/36]
NamingServiceTest::CPPUNIT_TEST ( testResolveComponentEmptyContainerName  )
◆ CPPUNIT_TEST() [27/36]
NamingServiceTest::CPPUNIT_TEST ( testResolveComponentEmptyHostname  )
◆ CPPUNIT_TEST() [28/36]
NamingServiceTest::CPPUNIT_TEST ( testResolveComponentFalseNbproc  )
◆ CPPUNIT_TEST() [29/36]
NamingServiceTest::CPPUNIT_TEST ( testResolveComponentOK  )
◆ CPPUNIT_TEST() [30/36]
NamingServiceTest::CPPUNIT_TEST ( testResolveComponentUnknownComponentName  )
◆ CPPUNIT_TEST() [31/36]
NamingServiceTest::CPPUNIT_TEST ( testResolveComponentUnknownContainerName  )
◆ CPPUNIT_TEST() [32/36]
NamingServiceTest::CPPUNIT_TEST ( testResolveComponentUnknownHostname  )
◆ CPPUNIT_TEST() [33/36]
NamingServiceTest::CPPUNIT_TEST ( testResolveFirst  )
◆ CPPUNIT_TEST() [34/36]
NamingServiceTest::CPPUNIT_TEST ( testResolveFirstRelative  )
◆ CPPUNIT_TEST() [35/36]
NamingServiceTest::CPPUNIT_TEST ( testResolveFirstUnknown  )
◆ CPPUNIT_TEST() [36/36]
NamingServiceTest::CPPUNIT_TEST ( testResolveFirstUnknownRelative  )
◆ CPPUNIT_TEST_SUITE()
NamingServiceTest::CPPUNIT_TEST_SUITE ( NamingServiceTest  )
◆ CPPUNIT_TEST_SUITE_END()
NamingServiceTest::CPPUNIT_TEST_SUITE_END ( )
◆ setUp()
◆ tearDown()
void NamingServiceTest::tearDown ( )
  • delete trace classes
◆ testBuildContainerNameForNS()
void NamingServiceTest::testBuildContainerNameForNS ( )
◆ testBuildContainerNameForNSParams()
◆ testChangeDirectory()
◆ testConstructorDefault()
void NamingServiceTest::testConstructorDefault ( )
References _orb, SALOME_NamingService::getIORaddr(), SALOME_NamingService::init_orb(), KERNEL_PY.batchmode_salome::obj, and TestLifeCycleCORBA::rootContext.
◆ testConstructorOrb()
void NamingServiceTest::testConstructorOrb ( )
◆ testContainerName()
void NamingServiceTest::testContainerName ( )
◆ testContainerNameParams()
◆ testCreateDirectory()
◆ testCurrentDirectory()
◆ testDestroyDirectory()
◆ testDestroyFullDirectory()
◆ testDestroyName()
◆ testFind()
◆ testGetIorAddr()
void NamingServiceTest::testGetIorAddr ( )
◆ testList()
void NamingServiceTest::testList ( )
◆ testListDirectory()
void NamingServiceTest::testListDirectory ( )
◆ testListDirectoryRecurs()
void NamingServiceTest::testListDirectoryRecurs ( )
◆ testListSubdirs()
void NamingServiceTest::testListSubdirs ( )
◆ testRegisterResolveAbsNoPath()
void NamingServiceTest::testRegisterResolveAbsNoPath ( )
References _factoryRef, _NS, KERNEL_PY.batchmode_salome::obj, SALOME_NamingService::Register(), and SALOME_NamingService::Resolve().
◆ testRegisterResolveAbsWithPath()
void NamingServiceTest::testRegisterResolveAbsWithPath ( )
References _NS, KERNEL_PY.batchmode_salome::obj, SALOME_NamingService::Register(), and SALOME_NamingService::Resolve().
◆ testRegisterResolveRelativeNoPath()
void NamingServiceTest::testRegisterResolveRelativeNoPath ( )
References _NS, SALOME_NamingService::Change_Directory(), SALOME_NamingService::Create_Directory(), KERNEL_PY.batchmode_salome::obj, SALOME_NamingService::Register(), and SALOME_NamingService::Resolve().
◆ testRegisterResolveRelativeWithPath()
void NamingServiceTest::testRegisterResolveRelativeWithPath ( )
Relative Path is changed to the created subdirectory when Register()
◆ testResolveBadName()
void NamingServiceTest::testResolveBadName ( )
References _NS, KERNEL_PY.batchmode_salome::obj, and SALOME_NamingService::Resolve().
◆ testResolveBadNameRelative()
void NamingServiceTest::testResolveBadNameRelative ( )
◆ testResolveComponentEmptyComponentName()
void NamingServiceTest::testResolveComponentEmptyComponentName ( )
◆ testResolveComponentEmptyContainerName()
void NamingServiceTest::testResolveComponentEmptyContainerName ( )
check bad hostname gives nil pointer. If componentName registered on a container from hostname, a component reference is found (the first one). Else give nil pointer.
References _NS, KERNEL_PY.batchmode_salome::obj, SALOME_NamingService::Register(), SALOME_NamingService::Resolve(), and SALOME_NamingService::ResolveComponent().
◆ testResolveComponentEmptyHostname()
void NamingServiceTest::testResolveComponentEmptyHostname ( )
◆ testResolveComponentFalseNbproc()
void NamingServiceTest::testResolveComponentFalseNbproc ( )
A positive number not corresponding to a registered component gives nil ref. A negative number is not taken into account and may give a non nil ref.
◆ testResolveComponentOK()
void NamingServiceTest::testResolveComponentOK ( )
◆ testResolveComponentUnknownComponentName()
void NamingServiceTest::testResolveComponentUnknownComponentName ( )
◆ testResolveComponentUnknownContainerName()
void NamingServiceTest::testResolveComponentUnknownContainerName ( )
◆ testResolveComponentUnknownHostname()
void NamingServiceTest::testResolveComponentUnknownHostname ( )
◆ testResolveFirst()
◆ testResolveFirstRelative()
void NamingServiceTest::testResolveFirstRelative ( )
Resolve all the objects. ResolveFirst echo with a relative path /nstestfirstrel must give /nstestfirst/echo_i, corresponding to the first object.
References _NS, SALOME_NamingService::Change_Directory(), pythfilter::name, NB_OBJS, KERNEL_PY.batchmode_salome::obj, SALOME_NamingService::Register(), SALOME_NamingService::Resolve(), and SALOME_NamingService::ResolveFirst().
◆ testResolveFirstUnknown()
void NamingServiceTest::testResolveFirstUnknown ( )
References _NS, pythfilter::name, KERNEL_PY.batchmode_salome::obj, and SALOME_NamingService::ResolveFirst().
◆ testResolveFirstUnknownRelative()
void NamingServiceTest::testResolveFirstUnknownRelative ( )
◆ _factoryRef
CORBA::Object_var NamingServiceTest::_factoryRef
◆ _myFactory
NSTEST_aFactory_i* NamingServiceTest::_myFactory
◆ _myFactoryId
PortableServer::ObjectId_var NamingServiceTest::_myFactoryId
◆ _NS
◆ _orb
◆ _pman
PortableServer::POAManager_var NamingServiceTest::_pman
◆ _root_poa
PortableServer::POA_var NamingServiceTest::_root_poa
