Functions | |
| def | MYTRACE () |
| def | REPERE () |
| def | BEGIN_OF (msg) |
| def | END_OF (msg) |
| def | MESSAGE (msg) |
| def | SCRUTE (var_name, var_value) |
Variables | |
| GLogger = SALOME_Trace.SALOME_Trace() | |
| def SALOME_utilities.BEGIN_OF | ( | msg | ) |
References MYTRACE(), REPERE(), and salome_utils.verbose().
Referenced by RegistryService.add(), container_common_main(), RegistryService.end(), SALOME_ModuleCatalog_AcomponentImpl.GetPathPrefix(), RegistryService.hello(), Engines_MPIContainer_i.Lload_impl(), SALOMEDS_AttLong_i.Load(), SALOMEDS_AttReal_i.Load(), main(), RegistryService.remove(), SALOMEDS_AttLong_i.Save(), SALOMEDS_AttReal_i.Save(), TestMPIComponentEngine.SPCoucou(), RegistryConnexion.~RegistryConnexion(), and RegistryService.~RegistryService().
| def SALOME_utilities.END_OF | ( | msg | ) |
Referenced by RegistryService.add(), SALOME_ModuleCatalog_AcomponentImpl.GetPathPrefix(), RegistryService.hello(), Engines_MPIContainer_i.Lload_impl(), main(), RegistryService.remove(), TestMPIComponentEngine.SPCoucou(), RegistryConnexion.~RegistryConnexion(), and RegistryService.~RegistryService().
| def SALOME_utilities.MESSAGE | ( | msg | ) |
References MYTRACE(), and salome_utils.verbose().
| def SALOME_utilities.MYTRACE | ( | ) |
References salome_utils.verbose().
Referenced by BEGIN_OF(), END_OF(), MESSAGE(), and SCRUTE().
| def SALOME_utilities.REPERE | ( | ) |
Referenced by BEGIN_OF(), and END_OF().
| def SALOME_utilities.SCRUTE | ( | var_name, | |
| var_value | |||
References MYTRACE().
Referenced by NamingServiceTest._destroyDirectoryRecurs(), SALOME_NamingService._Find(), SALOME_NamingService._list_directory_recurs(), RegistryConnexion.add(), RegistryService.add(), SALOME_ContainerManager.BuildTempFileToLaunchRemoteContainer(), container_common_main(), Engines_Parallel_Container_i.copyFile(), create_instance(), Abstract_Engines_Container_i.createInstance(), Engines_MPIContainer_i.createMPIInstance(), SALOME_NamingService.Current_Directory(), Abstract_Engines_Container_i.decInstanceCnt(), Engines_Parallel_Container_i.decInstanceCnt(), Engines_MPIContainer_i.Engines_MPIContainer_i(), fileRef_i.fileRef_i(), Abstract_Engines_Container_i.finalize_removal(), Engines_MPIContainer_i.finalize_removal(), Abstract_Engines_Container_i.find_component_instance(), Engines_Parallel_Container_i.find_component_instance(), SALOME_LifeCycleCORBA.FindOrLoad_Component(), SALOME_ModuleCatalogImpl.GetComponentList(), SALOME_FileTransferCORBA.getLocalFile(), SALOME_ModuleCatalog_AcomponentImpl.GetPathPrefix(), SALOME_ModuleCatalog_AcomponentImpl.GetService(), RegistryService.hello(), Engines_MPIContainer_i.Lcreate_component_instance(), Engines_MPIContainer_i.Lload_component_Library(), Abstract_Engines_Container_i.load_component_CppImplementation(), Abstract_Engines_Container_i.load_component_PythonImplementation(), main(), fileTransfer_i.putBlock(), RegistryService.remove(), SALOME_NamingService.ResolveComponent(), SalomeTestComponentEngine_factory(), SALOME_ContainerManager.ShutdownContainersGeneric(), TestMPIComponentEngine_factory(), and Engines_Component_i.~Engines_Component_i().
| SALOME_utilities.GLogger = SALOME_Trace.SALOME_Trace() |
