fileRef_i Class Reference
#include <SALOME_FileRef_i.hxx>
Inheritance diagram for fileRef_i:
 fileRef_i ()
 Default constructor, not for use. More...
 fileRef_i (Engines::Container_ptr container, const char *origFileName)
 Constructor to use. More...
virtual ~fileRef_i ()
char * origFileName ()
 CORBA method: More...
char * refMachine ()
Engines::Container_ptr getContainer ()
CORBA::Boolean addRef (const char *machine, const char *fileName)
 CORBA method: after a file transfer on a client computer, registers hostname of client and file path of the copied file. More...
char * getRef (const char *machine)
 CORBA method: check if a copy of the file referenced by fileRef is available on the client computer. More...
Engines::Container_var _container
std::string _origFileName
std::string _machine
std::map< std::string, std::string > _copies
◆ fileRef_i() [1/2]
fileRef_i::fileRef_i ( )
◆ fileRef_i() [2/2]
fileRef_i::fileRef_i ( Engines::Container_ptr  container,
const char *  origFileName
◆ ~fileRef_i()
fileRef_i::~fileRef_i ( )
References MESSAGE.
◆ addRef()
CORBA::Boolean fileRef_i::addRef ( const char *  machine,
const char *  fileName
machineclient hostname
fileNameabsolute path of the transferred file on client computer
References _copies, and MESSAGE.
Referenced by fileRef_i().
◆ getContainer()
Engines::Container_ptr fileRef_i::getContainer ( )
◆ getRef()
char * fileRef_i::getRef ( const char *  machine)
machinehostname of the client computer
path of the copy on the client computer, if the copy exists, else empty string
References _copies, _machine, _origFileName, and MESSAGE.
◆ origFileName()
char * fileRef_i::origFileName ( )
CORBA method:
the file name (absolute path) on the computer which runs the container server
References _origFileName, and MESSAGE.
◆ refMachine()
char * fileRef_i::refMachine ( )
CORBA method:
the hostname of the computer which runs the container server
References _machine, and MESSAGE.
◆ _container
Engines::Container_var fileRef_i::_container
◆ _copies
std::map<std::string, std::string> fileRef_i::_copies
Referenced by addRef(), and getRef().
◆ _machine
std::string fileRef_i::_machine
Referenced by fileRef_i(), getRef(), and refMachine().
◆ _origFileName
std::string fileRef_i::_origFileName
Referenced by fileRef_i(), getRef(), and origFileName().
