| def | __init__ (self, containerName, containerIORStr, dftTimeIntervalInMs) |
| def | getPyScriptCls (self) |
| def | logm (self) |
| def | import_component (self, componentName) |
| def | create_component_instance (self, componentName, instanceName) |
| def | create_pynode (self, nodeName, code) |
| def | create_pyscriptnode (self, nodeName, code) |
| def | positionVerbosityOfLogger (self) |
| def | setCurrentDirectory (self, newCwd) |
| def | monitoringtimeresms (self) |
| def | shutdownPy (self) |
| def | killMe (self) |
| def | setLogFileName (self, logFileName) |
| def | SetMonitoringtimeresms (self, value) |
Private Attributes | |
| _containerName | |
| _logFileName | |
| _timeIntervalInMs | |
| _logm | |
| _log | |
| _container | |
Static Private Attributes | |
| _orb = None | |
| _poa = None | |
| string | _containerName = "" |
| _naming_service = None | |
| def SALOME_Container.SALOME_Container_Abstract_i.__init__ | ( | self, | |
| containerName, | |||
| containerIORStr, | |||
| dftTimeIntervalInMs | |||
Reimplemented in SALOME_Container.SALOME_Container_i, SALOME_Container.SALOME_Container_OutOfProcess_i, SALOME_Container.SALOME_Container_OutOfProcess_Replay_i, SALOME_Container.SALOME_Container_OutOfProcess_FT_i, and SALOME_Container.SALOME_Container_OutOfProcess_Replay_FT_i.
References Engines_Component_i._orb, SALOME_ComponentPy.SALOME_ComponentPy_Gen_i._orb, SALOME_Container.SALOME_Container_Abstract_i._orb, Abstract_Engines_Container_i._orb, SALOME_ContainerManager._orb, SALOME_ContainerPy.SALOME_ContainerPy_Gen_i._orb, SALOME_PyNode.ExchangeContextUsingTCP._orb, ConnectionManager_i._orb, Param_Double_Port_uses_i._orb, SALOME_Launcher._orb, LifeCycleCORBATest._orb, Logger._orb, SALOME_ModuleCatalogImpl._orb, SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy._orb, SALOME_NamingService._orb, SALOME_NamingServicePy.SALOME_NamingServicePy_i._orb, NamingServiceTest._orb, Engines_Parallel_Component_i._orb, Engines_Parallel_Container_i._orb, RegistryService._orb, SALOME_ResourcesManager._orb, SALOMEDS_ChildIterator_i._orb, SALOMEDS_Driver_i._orb, SALOMEDS_DriverFactory_i._orb, SALOMEDS_GenericAttribute_i._orb, SALOMEDS_SComponentIterator_i._orb, SALOMEDS_SObject._orb, SALOMEDS_SObject_i._orb, SALOMEDS_Study._orb, SALOMEDS::Notifier._orb, SALOMEDS::GenObjRegister._orb, SALOMEDS_Study_i._orb, SALOMEDS_StudyBuilder._orb, SALOMEDS_StudyBuilder_i._orb, SALOMEDS_UseCaseBuilder_i._orb, SALOMEDS_UseCaseIterator_i._orb, SALOMEDSTest._orb, SALOMESDS::DataScopeKiller._orb, SALOMESDS::DataScopeServerBase._orb, SALOMESDS::DataServerManager._orb, ORB_INIT._orb, Engines_Component_i._poa, SALOME_ComponentPy.SALOME_ComponentPy_Gen_i._poa, SALOME_Container.SALOME_Container_Abstract_i._poa, Abstract_Engines_Container_i._poa, SALOME_ContainerManager._poa, SALOME_ContainerPy.SALOME_ContainerPy_Gen_i._poa, SALOME_PyNode.ContextExchanger_i._poa, SALOME_ExternalServerLauncher._poa, SALOME_Launcher._poa, SALOME_LogManager._poa, Engines_Parallel_Component_i._poa, Engines_Parallel_Container_i._poa, Container_proxy_impl_final._poa, SALOME_ResourcesManager._poa, SALOMESDS::DataScopeServerBase._poa, SALOMESDS::DataServerManager._poa, SALOMESDS::PickelizedPyObjServer._poa, and SalomeOnDemandTK.extension_utilities.format.
| def SALOME_Container.SALOME_Container_Abstract_i.create_component_instance | ( | self, | |
| componentName, | |||
| instanceName | |||
References Engines_Component_i._container, SALOME_Container.SALOME_Container_Abstract_i._container, Salome_file_i._container, fileRef_i._container, HDFexplorer._container, Engines_Component_i._containerName, SALOME_ComponentPy.SALOME_ComponentPy_Gen_i._containerName, SALOME_Container.SALOME_Container_Abstract_i._containerName, Abstract_Engines_Container_i._containerName, SALOME_ContainerPy.SALOME_ContainerPy_Gen_i._containerName, SALOME_FileTransferCORBA._containerName, Engines_Parallel_Container_i._containerName, Container_proxy_impl_final._containerName, Engines_Component_i._orb, SALOME_ComponentPy.SALOME_ComponentPy_Gen_i._orb, SALOME_Container.SALOME_Container_Abstract_i._orb, Abstract_Engines_Container_i._orb, SALOME_ContainerManager._orb, SALOME_ContainerPy.SALOME_ContainerPy_Gen_i._orb, SALOME_PyNode.ExchangeContextUsingTCP._orb, ConnectionManager_i._orb, Param_Double_Port_uses_i._orb, SALOME_Launcher._orb, LifeCycleCORBATest._orb, Logger._orb, SALOME_ModuleCatalogImpl._orb, SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy._orb, SALOME_NamingService._orb, SALOME_NamingServicePy.SALOME_NamingServicePy_i._orb, NamingServiceTest._orb, Engines_Parallel_Component_i._orb, Engines_Parallel_Container_i._orb, RegistryService._orb, SALOME_ResourcesManager._orb, SALOMEDS_ChildIterator_i._orb, SALOMEDS_Driver_i._orb, SALOMEDS_DriverFactory_i._orb, SALOMEDS_GenericAttribute_i._orb, SALOMEDS_SComponentIterator_i._orb, SALOMEDS_SObject._orb, SALOMEDS_SObject_i._orb, SALOMEDS_Study._orb, SALOMEDS::Notifier._orb, SALOMEDS::GenObjRegister._orb, SALOMEDS_Study_i._orb, SALOMEDS_StudyBuilder._orb, SALOMEDS_StudyBuilder_i._orb, SALOMEDS_UseCaseBuilder_i._orb, SALOMEDS_UseCaseIterator_i._orb, SALOMEDSTest._orb, SALOMESDS::DataScopeKiller._orb, SALOMESDS::DataScopeServerBase._orb, SALOMESDS::DataServerManager._orb, ORB_INIT._orb, Engines_Component_i._poa, SALOME_ComponentPy.SALOME_ComponentPy_Gen_i._poa, SALOME_Container.SALOME_Container_Abstract_i._poa, Abstract_Engines_Container_i._poa, SALOME_ContainerManager._poa, SALOME_ContainerPy.SALOME_ContainerPy_Gen_i._poa, SALOME_PyNode.ContextExchanger_i._poa, SALOME_ExternalServerLauncher._poa, SALOME_Launcher._poa, SALOME_LogManager._poa, Engines_Parallel_Component_i._poa, Engines_Parallel_Container_i._poa, Container_proxy_impl_final._poa, SALOME_ResourcesManager._poa, SALOMESDS::DataScopeServerBase._poa, SALOMESDS::DataServerManager._poa, and SALOMESDS::PickelizedPyObjServer._poa.
Referenced by SALOME_ContainerPy.SALOME_ContainerPy_Gen_i.create_component_instance_env(), and SALOME_ContainerPy.SALOME_ContainerPy_Gen_i.create_python_service_instance().
| def SALOME_Container.SALOME_Container_Abstract_i.create_pynode | ( | self, | |
| nodeName, | |||
| code | |||
References Engines_Component_i._orb, SALOME_ComponentPy.SALOME_ComponentPy_Gen_i._orb, SALOME_Container.SALOME_Container_Abstract_i._orb, Abstract_Engines_Container_i._orb, SALOME_ContainerManager._orb, SALOME_ContainerPy.SALOME_ContainerPy_Gen_i._orb, SALOME_PyNode.ExchangeContextUsingTCP._orb, ConnectionManager_i._orb, Param_Double_Port_uses_i._orb, SALOME_Launcher._orb, LifeCycleCORBATest._orb, Logger._orb, SALOME_ModuleCatalogImpl._orb, SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy._orb, SALOME_NamingService._orb, SALOME_NamingServicePy.SALOME_NamingServicePy_i._orb, NamingServiceTest._orb, Engines_Parallel_Component_i._orb, Engines_Parallel_Container_i._orb, RegistryService._orb, SALOME_ResourcesManager._orb, SALOMEDS_ChildIterator_i._orb, SALOMEDS_Driver_i._orb, SALOMEDS_DriverFactory_i._orb, SALOMEDS_GenericAttribute_i._orb, SALOMEDS_SComponentIterator_i._orb, SALOMEDS_SObject._orb, SALOMEDS_SObject_i._orb, SALOMEDS_Study._orb, SALOMEDS::Notifier._orb, SALOMEDS::GenObjRegister._orb, SALOMEDS_Study_i._orb, SALOMEDS_StudyBuilder._orb, SALOMEDS_StudyBuilder_i._orb, SALOMEDS_UseCaseBuilder_i._orb, SALOMEDS_UseCaseIterator_i._orb, SALOMEDSTest._orb, SALOMESDS::DataScopeKiller._orb, SALOMESDS::DataScopeServerBase._orb, SALOMESDS::DataServerManager._orb, ORB_INIT._orb, Engines_Component_i._poa, SALOME_ComponentPy.SALOME_ComponentPy_Gen_i._poa, SALOME_Container.SALOME_Container_Abstract_i._poa, Abstract_Engines_Container_i._poa, SALOME_ContainerManager._poa, SALOME_ContainerPy.SALOME_ContainerPy_Gen_i._poa, SALOME_PyNode.ContextExchanger_i._poa, SALOME_ExternalServerLauncher._poa, SALOME_Launcher._poa, SALOME_LogManager._poa, Engines_Parallel_Component_i._poa, Engines_Parallel_Container_i._poa, Container_proxy_impl_final._poa, SALOME_ResourcesManager._poa, SALOMESDS::DataScopeServerBase._poa, SALOMESDS::DataServerManager._poa, and SALOMESDS::PickelizedPyObjServer._poa.
| def SALOME_Container.SALOME_Container_Abstract_i.create_pyscriptnode | ( | self, | |
| nodeName, | |||
| code | |||
References SALOME_Container.SALOME_Container_Abstract_i._log, Engines_Component_i._orb, SALOME_ComponentPy.SALOME_ComponentPy_Gen_i._orb, SALOME_Container.SALOME_Container_Abstract_i._orb, Abstract_Engines_Container_i._orb, SALOME_ContainerManager._orb, SALOME_ContainerPy.SALOME_ContainerPy_Gen_i._orb, SALOME_PyNode.ExchangeContextUsingTCP._orb, ConnectionManager_i._orb, Param_Double_Port_uses_i._orb, SALOME_Launcher._orb, LifeCycleCORBATest._orb, Logger._orb, SALOME_ModuleCatalogImpl._orb, SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy._orb, SALOME_NamingService._orb, SALOME_NamingServicePy.SALOME_NamingServicePy_i._orb, NamingServiceTest._orb, Engines_Parallel_Component_i._orb, Engines_Parallel_Container_i._orb, RegistryService._orb, SALOME_ResourcesManager._orb, SALOMEDS_ChildIterator_i._orb, SALOMEDS_Driver_i._orb, SALOMEDS_DriverFactory_i._orb, SALOMEDS_GenericAttribute_i._orb, SALOMEDS_SComponentIterator_i._orb, SALOMEDS_SObject._orb, SALOMEDS_SObject_i._orb, SALOMEDS_Study._orb, SALOMEDS::Notifier._orb, SALOMEDS::GenObjRegister._orb, SALOMEDS_Study_i._orb, SALOMEDS_StudyBuilder._orb, SALOMEDS_StudyBuilder_i._orb, SALOMEDS_UseCaseBuilder_i._orb, SALOMEDS_UseCaseIterator_i._orb, SALOMEDSTest._orb, SALOMESDS::DataScopeKiller._orb, SALOMESDS::DataScopeServerBase._orb, SALOMESDS::DataServerManager._orb, ORB_INIT._orb, Engines_Component_i._poa, SALOME_ComponentPy.SALOME_ComponentPy_Gen_i._poa, SALOME_Container.SALOME_Container_Abstract_i._poa, Abstract_Engines_Container_i._poa, SALOME_ContainerManager._poa, SALOME_ContainerPy.SALOME_ContainerPy_Gen_i._poa, SALOME_PyNode.ContextExchanger_i._poa, SALOME_ExternalServerLauncher._poa, SALOME_Launcher._poa, SALOME_LogManager._poa, Engines_Parallel_Component_i._poa, Engines_Parallel_Container_i._poa, Container_proxy_impl_final._poa, SALOME_ResourcesManager._poa, SALOMESDS::DataScopeServerBase._poa, SALOMESDS::DataServerManager._poa, SALOMESDS::PickelizedPyObjServer._poa, SalomeOnDemandTK.extension_utilities.format, SALOME_Container.SALOME_Container_Abstract_i.getPyScriptCls(), SALOME_Container.SALOME_Container_i.getPyScriptCls(), SALOME_Container.SALOME_Container_OutOfProcess_i.getPyScriptCls(), SALOME_Container.SALOME_Container_OutOfProcess_Replay_i.getPyScriptCls(), SALOME_Container.SALOME_Container_OutOfProcess_FT_i.getPyScriptCls(), and SALOME_Container.SALOME_Container_OutOfProcess_Replay_FT_i.getPyScriptCls().
| def SALOME_Container.SALOME_Container_Abstract_i.getPyScriptCls | ( | self | ) |
Referenced by SALOME_Container.SALOME_Container_Abstract_i.create_pyscriptnode().
| def SALOME_Container.SALOME_Container_Abstract_i.import_component | ( | self, | |
| componentName | |||
| def SALOME_Container.SALOME_Container_Abstract_i.killMe | ( | self | ) |
| def SALOME_Container.SALOME_Container_Abstract_i.logm | ( | self | ) |
| def SALOME_Container.SALOME_Container_Abstract_i.monitoringtimeresms | ( | self | ) |
| def SALOME_Container.SALOME_Container_Abstract_i.positionVerbosityOfLogger | ( | self | ) |
| def SALOME_Container.SALOME_Container_Abstract_i.setCurrentDirectory | ( | self, | |
| newCwd | |||
| def SALOME_Container.SALOME_Container_Abstract_i.setLogFileName | ( | self, | |
| logFileName | |||
References Engines_Component_i._containerName, SALOME_ComponentPy.SALOME_ComponentPy_Gen_i._containerName, SALOME_Container.SALOME_Container_Abstract_i._containerName, Abstract_Engines_Container_i._containerName, SALOME_ContainerPy.SALOME_ContainerPy_Gen_i._containerName, SALOME_FileTransferCORBA._containerName, Engines_Parallel_Container_i._containerName, Container_proxy_impl_final._containerName, SALOME_Container.SALOME_Container_Abstract_i._log, SalomeOnDemandTK.extension_utilities.format, and SALOME_Container.SALOME_Container_Abstract_i.logm().
| def SALOME_Container.SALOME_Container_Abstract_i.SetMonitoringtimeresms | ( | self, | |
| value | |||
| def SALOME_Container.SALOME_Container_Abstract_i.shutdownPy | ( | self | ) |
private |
staticprivate |
Referenced by SALOME_ContainerPy.SALOME_ContainerPy_Gen_i._get_name(), SALOME_ContainerPy.SALOME_ContainerPy_Gen_i.create_component_instance(), SALOME_Container.SALOME_Container_Abstract_i.create_component_instance(), SALOME_Container.SALOME_Container_Abstract_i.setLogFileName(), and SALOME_ContainerPy.SALOME_ContainerPy_Gen_i.Shutdown().
private |
private |
private |
private |
Referenced by SALOME_Container.SALOME_Container_Abstract_i.logm().
staticprivate |
staticprivate |
Referenced by SALOME_Container.SALOME_Container_Abstract_i.__init__(), SALOME_ContainerPy.SALOME_ContainerPy_Gen_i.__init__(), SALOME_ContainerPy.SALOME_ContainerPy_i.__init__(), SALOME_ComponentPy.SALOME_ComponentPy_Gen_i.__init__(), SALOME_NamingServicePy.SALOME_NamingServicePy_i.__init__(), SALOME_ContainerPy.SALOME_ContainerPy_Gen_i.create_component_instance(), SALOME_Container.SALOME_Container_Abstract_i.create_component_instance(), SALOME_Container.SALOME_Container_Abstract_i.create_pynode(), SALOME_Container.SALOME_Container_Abstract_i.create_pyscriptnode(), SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.Register(), SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.Resolve(), and SALOME_ContainerPy.SALOME_ContainerPy_Gen_i.Shutdown().
staticprivate |
Referenced by SALOME_Container.SALOME_Container_Abstract_i.__init__(), SALOME_ContainerPy.SALOME_ContainerPy_Gen_i.__init__(), SALOME_ComponentPy.SALOME_ComponentPy_Gen_i.__init__(), SALOME_ContainerPy.SALOME_ContainerPy_Gen_i.create_component_instance(), SALOME_Container.SALOME_Container_Abstract_i.create_component_instance(), SALOME_Container.SALOME_Container_Abstract_i.create_pynode(), SALOME_Container.SALOME_Container_Abstract_i.create_pyscriptnode(), SALOME_ComponentPy.SALOME_ComponentPy_Gen_i.destroy(), SALOME_PyNode.ContextExchanger_i.getInputContext(), and SALOME_PyNode.ContextExchanger_i.getPOA().
private |
