Engines_Parallel_Component_i Class Reference
#include <SALOME_ParallelComponent_i.hxx>
Inheritance diagram for Engines_Parallel_Component_i:
 Engines_Parallel_Component_i (CORBA::ORB_ptr orb, char *ior, int rank, PortableServer::POA_ptr poa, PortableServer::ObjectId *contId, const char *instanceName, const char *interfaceName, bool notif=false, bool regist=true)
 Standard Constructor for generic Component, used in derived class Connection to Registry and Notification. More...
virtual ~Engines_Parallel_Component_i ()
 Destructor: call Container for decrement of instances count. More...
char * instanceName ()
 CORBA method: return name of the instance, unique in this Container. More...
char * interfaceName ()
 CORBA method: return name of the component class. More...
void ping ()
 CORBA method: Test if instance is alive and responds. More...
void destroy ()
 CORBA method: Deactivate this instance. More...
Engines::Container_ptr GetContainerRef ()
 CORBA method: return CORBA reference of the Container. More...
void setProperties (const Engines::FieldsDict &dico)
 CORBA method: Gives a sequence of (key=string,value=any) to the component. More...
Engines::FieldsDict * getProperties ()
 CORBA method: returns a previously stored map (key=string,value=any) as a sequence. More...
void Names (const char *graphName, const char *nodeName)
 CORBA method: used by Supervision to give names to this instance. More...
bool Kill_impl ()
 CORBA method: used in Supervision. More...
bool Stop_impl ()
bool Suspend_impl ()
bool Resume_impl ()
CORBA::Long CpuUsed_impl ()
 CORBA method: More...
 C++ method: DumpPython default implementation. More...
virtual Engines::Salome_file_ptr getInputFileToService (const char *service_name, const char *Salome_file_name)
virtual Engines::Salome_file_ptr getOutputFileToService (const char *service_name, const char *Salome_file_name)
virtual void checkInputFilesToService (const char *service_name)
virtual Engines::Salome_file_ptr setInputFileToService (const char *service_name, const char *Salome_file_name)
virtual void checkOutputFilesToService (const char *service_name)
virtual Engines::Salome_file_ptr setOutputFileToService (const char *service_name, const char *Salome_file_name)
void send_parallel_proxy_object (CORBA::Object_ptr proxy_ref)
 C++ method: Used by the Parallel Component to deploy a Parallel Salome_file. More...
virtual bool hasObjectInfo ()
virtual char * getObjectInfo (const char *entry)
PortableServer::ObjectId * getId ()
 C++ method: return CORBA instance id, the id is set in derived class constructor, when instance is activated. More...
Engines_Parallel_Container_i * GetContainerPtr ()
 C++ method: return Container Servant. More...
void beginService (const char *serviceName)
 C++ method: used by derived classes for supervision. More...
void endService (const char *serviceName)
void sendMessage (const char *event_type, const char *message)
 C++ method: Send message to event channel. More...
char * graphName ()
 C++ method: – CHECK IF USED –. More...
char * nodeName ()
bool Killer (pthread_t ThreadId, int signum)
 C++ method: used in Supervision (see kill_impl) More...
void SetCurCpu ()
 C++ method: More...
long CpuUsed ()
 C++ method: More...
void CancelThread ()
 C++ method: More...
void wait_parallel_object_proxy ()
char * get_parallel_proxy_object ()
virtual void configureSalome_file (std::string service_name, std::string file_port_name, Engines::Parallel_Salome_file_proxy_impl *file)
 C++ method: used to configure the Salome_file into the runtime. More...
static bool isMultiInstance ()
static std::string GetDynLibraryName (const char *componentName)
 C++ method: return standard library name built on component name. More...
Protected Types
typedef std::map< std::string, Parallel_Salome_file_i * > _t_Salome_file_map
typedef std::map< std::string, Engines::Parallel_Salome_file_proxy_impl * > _t_Proxy_Salome_file_map
typedef std::map< std::string, std::string > _t_IOR_Proxy_Salome_file_map
typedef std::map< std::string, Engines_Parallel_Component_i::_t_Salome_file_map * > _t_Service_file_map
typedef std::map< std::string, Engines_Parallel_Component_i::_t_Proxy_Salome_file_map * > _t_Proxy_Service_file_map
typedef std::map< std::string, Engines_Parallel_Component_i::_t_IOR_Proxy_Salome_file_map * > _t_IOR_Proxy_Service_file_map
std::string _instanceName
std::string _interfaceName
CORBA::ORB_var _orb
PortableServer::POA_var _poa
PortableServer::ObjectId * _id
PortableServer::ObjectId * _contId
Engines_Parallel_Component_i * _thisObj
RegistryConnexion * _myConnexionToRegistry
NOTIFICATION_Supplier * _notifSupplier
std::map< std::string, CORBA::Any > _fieldsDict
_t_Service_file_map _Input_Service_file_map
_t_Service_file_map _Output_Service_file_map
_t_Service_file_map::iterator _Service_file_map_it
_t_Salome_file_map::iterator _Salome_file_map_it
_t_Proxy_Service_file_map _Proxy_Input_Service_file_map
_t_Proxy_Service_file_map _Proxy_Output_Service_file_map
_t_Proxy_Service_file_map::iterator _Proxy_Service_file_map_it
_t_Proxy_Salome_file_map::iterator _Proxy_Salome_file_map_it
_t_IOR_Proxy_Service_file_map _IOR_Proxy_Input_Service_file_map
_t_IOR_Proxy_Service_file_map _IOR_Proxy_Output_Service_file_map
_t_IOR_Proxy_Service_file_map::iterator _IOR_Proxy_Service_file_map_it
_t_IOR_Proxy_Salome_file_map::iterator _IOR_Proxy_Salome_file_map_it
std::string _serviceName
std::string _graphName
std::string _nodeName
pthread_mutex_t * deploy_mutex
char * _proxy
Static Protected Attributes
static bool _isMultiInstance = false
pthread_t _ThreadId
long _StartUsed
long _ThreadCpuUsed
bool _Executed
bool _CanceledThread
bool _destroyed
◆ _t_IOR_Proxy_Salome_file_map
typedef std::map<std::string, std::string> Engines_Parallel_Component_i::_t_IOR_Proxy_Salome_file_map
◆ _t_IOR_Proxy_Service_file_map
◆ _t_Proxy_Salome_file_map
typedef std::map<std::string, Engines::Parallel_Salome_file_proxy_impl*> Engines_Parallel_Component_i::_t_Proxy_Salome_file_map
◆ _t_Proxy_Service_file_map
◆ _t_Salome_file_map
◆ _t_Service_file_map
◆ Engines_Parallel_Component_i()
Engines_Parallel_Component_i::Engines_Parallel_Component_i ( CORBA::ORB_ptr  orb,
char *  ior,
int  rank,
const char *  instanceName,
const char *  interfaceName,
bool  notif = false,
bool  regist = true
orbObject Request broker given by Container \parap poa Portable Object Adapter from Container (normally root_poa)
contIdcontainer CORBA id inside the server
instanceNameunique instance name for this object (see Container_i)
interfaceNamecomponent class name
notifuse of notification
References _contId, _instanceName, _myConnexionToRegistry, _notifSupplier, _orb, _poa, _proxy, deploy_mutex, instanceName(), MESSAGE, salome::orb, and SALOME_ContainerPy::poa.
◆ ~Engines_Parallel_Component_i()
Engines_Parallel_Component_i::~Engines_Parallel_Component_i ( )
When instances count falls to 0, the container tries to remove the component library (dlclose)
References _id, _interfaceName, _myConnexionToRegistry, _notifSupplier, _proxy, Engines_Parallel_Container_i::decInstanceCnt(), deploy_mutex, and MESSAGE.
◆ beginService()
void Engines_Parallel_Component_i::beginService ( const char *  serviceName)
References _Executed, _fieldsDict, _instanceName, _serviceName, _StartUsed, _ThreadCpuUsed, _ThreadId, CpuUsed_impl(), MESSAGE, and Utils_Identity::s.
◆ CancelThread()
void Engines_Parallel_Component_i::CancelThread ( )
C++ method:
References _CanceledThread.
Referenced by CallCancelThread().
◆ checkInputFilesToService()
void Engines_Parallel_Component_i::checkInputFilesToService ( const char *  service_name)
◆ checkOutputFilesToService()
void Engines_Parallel_Component_i::checkOutputFilesToService ( const char *  service_name)
◆ configureSalome_file()
void Engines_Parallel_Component_i::configureSalome_file ( std::string  service_name,
Engines::Parallel_Salome_file_proxy_impl *  file
service_namename of the service that use this Salome_file
file_port_namename of the Salome_file
fileParallel Salome_file C++ object
Referenced by checkInputFilesToService(), and checkOutputFilesToService().
◆ CpuUsed()
long Engines_Parallel_Component_i::CpuUsed ( )
C++ method:
References _Executed, _StartUsed, _ThreadId, and prepare_test::usage.
Referenced by CpuUsed_impl(), and SetCurCpu().
◆ CpuUsed_impl()
◆ destroy()
void Engines_Parallel_Component_i::destroy ( )
CORBA object is deactivated (do not respond any more to CORBA calls), the connection to Regsitry is removed (Registry informed of deactivation), internal server reference counter on the derived servant class is decremented, to allow destruction of the class (delete) by POA, when there are no more references. – TO BE USED BY CONTAINER ONLY (Container housekeeping) –
References _destroyed, and MESSAGE.
◆ DumpPython()
Engines::TMPFile * Engines_Parallel_Component_i::DumpPython ( CORBA::Boolean  isPublished,
◆ endService()
void Engines_Parallel_Component_i::endService ( const char *  serviceName)
References _CanceledThread, _instanceName, _StartUsed, _ThreadCpuUsed, _ThreadId, CpuUsed_impl(), and MESSAGE.
◆ get_parallel_proxy_object()
char * Engines_Parallel_Component_i::get_parallel_proxy_object ( )
References _proxy.
Referenced by setInputFileToService(), setOutputFileToService(), and wait_parallel_object_proxy().
◆ GetContainerPtr()
Engines_Parallel_Container_i * Engines_Parallel_Component_i::GetContainerPtr ( )
References _contId, and _poa.
◆ GetContainerRef()
Engines::Container_ptr Engines_Parallel_Component_i::GetContainerRef ( )
References _contId, _poa, and MESSAGE.
◆ GetDynLibraryName()
std::string Engines_Parallel_Component_i::GetDynLibraryName ( const char *  componentName)
References TestKernelHelpers::ret.
◆ getId()
PortableServer::ObjectId * Engines_Parallel_Component_i::getId ( )
References _id.
◆ getInputFileToService()
Engines::Salome_file_ptr Engines_Parallel_Component_i::getInputFileToService ( const char *  service_name,
const char *  Salome_file_name
◆ getObjectInfo()
virtual char * Engines_Parallel_Component_i::getObjectInfo ( const char *  entry)
◆ getOutputFileToService()
Engines::Salome_file_ptr Engines_Parallel_Component_i::getOutputFileToService ( const char *  service_name,
◆ getProperties()
Engines::FieldsDict * Engines_Parallel_Component_i::getProperties ( )
(see setProperties)
References _fieldsDict.
◆ graphName()
char * Engines_Parallel_Component_i::graphName ( )
References _graphName.
Referenced by Names(), sendMessage(), and SALOME_ComponentPy.SALOME_ComponentPy_Gen_i::sendMessage().
◆ hasObjectInfo()
virtual bool Engines_Parallel_Component_i::hasObjectInfo ( )
◆ instanceName()
char * Engines_Parallel_Component_i::instanceName ( )
References _instanceName.
Referenced by Engines_Parallel_Component_i().
◆ interfaceName()
char * Engines_Parallel_Component_i::interfaceName ( )
References _interfaceName.
◆ isMultiInstance()
static bool Engines_Parallel_Component_i::isMultiInstance ( )
◆ Kill_impl()
bool Engines_Parallel_Component_i::Kill_impl ( )
References _ThreadId, and Killer().
◆ Killer()
bool Engines_Parallel_Component_i::Killer ( pthread_t  ThreadId,
int  signum
References MESSAGE.
Referenced by CpuUsed_impl(), Kill_impl(), Stop_impl(), and Suspend_impl().
◆ Names()
void Engines_Parallel_Component_i::Names ( const char *  graphName,
const char *  nodeName
References _graphName, _nodeName, graphName(), MESSAGE, and nodeName().
◆ nodeName()
◆ ping()
void Engines_Parallel_Component_i::ping ( )
References MESSAGE.
◆ Resume_impl()
bool Engines_Parallel_Component_i::Resume_impl ( )
References _id, _instanceName, _interfaceName, _Sleeping, _ThreadId, and MESSAGE.
◆ send_parallel_proxy_object()
void Engines_Parallel_Component_i::send_parallel_proxy_object ( CORBA::Object_ptr  proxy_ref)
References _orb, and _proxy.
◆ sendMessage()
void Engines_Parallel_Component_i::sendMessage ( const char *  event_type,
const char *  message
References _notifSupplier, graphName(), nodeName(), and NOTIFICATION_Supplier::Send().
◆ SetCurCpu()
void Engines_Parallel_Component_i::SetCurCpu ( )
C++ method:
References _ThreadCpuUsed, and CpuUsed().
Referenced by SetCpuUsed().
◆ setInputFileToService()
Engines::Salome_file_ptr Engines_Parallel_Component_i::setInputFileToService ( const char *  service_name,
◆ setOutputFileToService()
Engines::Salome_file_ptr Engines_Parallel_Component_i::setOutputFileToService ( const char *  service_name,
◆ setProperties()
void Engines_Parallel_Component_i::setProperties ( const Engines::FieldsDict &  dico)
Base class component stores the sequence in a map. The map is cleared before. This map is for use by derived classes.
dicosequence of (key=string,value=any)
◆ Stop_impl()
bool Engines_Parallel_Component_i::Stop_impl ( )
References _id, _instanceName, _interfaceName, _ThreadId, Killer(), and MESSAGE.
◆ Suspend_impl()
bool Engines_Parallel_Component_i::Suspend_impl ( )
References _id, _instanceName, _interfaceName, _Sleeping, _ThreadId, Killer(), and MESSAGE.
◆ wait_parallel_object_proxy()
void Engines_Parallel_Component_i::wait_parallel_object_proxy ( )
References get_parallel_proxy_object().
Referenced by setInputFileToService(), and setOutputFileToService().
◆ _CanceledThread
bool Engines_Parallel_Component_i::_CanceledThread
Referenced by CancelThread(), and endService().
◆ _contId
◆ _destroyed
bool Engines_Parallel_Component_i::_destroyed
Referenced by destroy().
◆ _Executed
◆ _fieldsDict
std::map<std::string,CORBA::Any> Engines_Parallel_Component_i::_fieldsDict
◆ _graphName
◆ _id
PortableServer::ObjectId* Engines_Parallel_Component_i::_id
◆ _Input_Service_file_map
_t_Service_file_map Engines_Parallel_Component_i::_Input_Service_file_map
Referenced by setInputFileToService().
◆ _instanceName
◆ _interfaceName
◆ _IOR_Proxy_Input_Service_file_map
_t_IOR_Proxy_Service_file_map Engines_Parallel_Component_i::_IOR_Proxy_Input_Service_file_map
◆ _IOR_Proxy_Output_Service_file_map
_t_IOR_Proxy_Service_file_map Engines_Parallel_Component_i::_IOR_Proxy_Output_Service_file_map
Referenced by setOutputFileToService().
◆ _IOR_Proxy_Salome_file_map_it
_t_IOR_Proxy_Salome_file_map::iterator Engines_Parallel_Component_i::_IOR_Proxy_Salome_file_map_it
◆ _IOR_Proxy_Service_file_map_it
_t_IOR_Proxy_Service_file_map::iterator Engines_Parallel_Component_i::_IOR_Proxy_Service_file_map_it
◆ _isMultiInstance
bool Engines_Parallel_Component_i::_isMultiInstance = false
staticprotected
◆ _myConnexionToRegistry
RegistryConnexion* Engines_Parallel_Component_i::_myConnexionToRegistry
◆ _nodeName
◆ _notifSupplier
◆ _orb
◆ _Output_Service_file_map
_t_Service_file_map Engines_Parallel_Component_i::_Output_Service_file_map
◆ _poa
◆ _proxy
◆ _Proxy_Input_Service_file_map
_t_Proxy_Service_file_map Engines_Parallel_Component_i::_Proxy_Input_Service_file_map
◆ _Proxy_Output_Service_file_map
_t_Proxy_Service_file_map Engines_Parallel_Component_i::_Proxy_Output_Service_file_map
◆ _Proxy_Salome_file_map_it
_t_Proxy_Salome_file_map::iterator Engines_Parallel_Component_i::_Proxy_Salome_file_map_it
◆ _Proxy_Service_file_map_it
_t_Proxy_Service_file_map::iterator Engines_Parallel_Component_i::_Proxy_Service_file_map_it
◆ _Salome_file_map_it
_t_Salome_file_map::iterator Engines_Parallel_Component_i::_Salome_file_map_it
◆ _Service_file_map_it
_t_Service_file_map::iterator Engines_Parallel_Component_i::_Service_file_map_it
◆ _serviceName
std::string Engines_Parallel_Component_i::_serviceName
◆ _StartUsed
◆ _thisObj
Engines_Parallel_Component_i* Engines_Parallel_Component_i::_thisObj
◆ _ThreadCpuUsed
◆ _ThreadId
◆ deploy_mutex
pthread_mutex_t* Engines_Parallel_Component_i::deploy_mutex
