Engines_ParallelDSC_i Class Referenceabstract
#include <ParallelDSC_i.hxx>
Inheritance diagram for Engines_ParallelDSC_i:
 Engines_ParallelDSC_i (CORBA::ORB_ptr orb, char *ior, int rank, PortableServer::POA_ptr poa, PortableServer::ObjectId *contId, const char *instanceName, const char *interfaceName, bool notif=false)
virtual ~Engines_ParallelDSC_i ()
virtual void add_provides_port (Ports::Port_ptr ref, const char *provides_port_name, Ports::PortProperties_ptr port_prop)
virtual void add_uses_port (const char *repository_id, const char *uses_port_name, Ports::PortProperties_ptr port_prop)
virtual Ports::Port_ptr get_provides_port (const char *provides_port_name, const CORBA::Boolean connection_error)
virtual Engines::DSC::uses_port * get_uses_port (const char *uses_port_name)
virtual void connect_provides_port (const char *provides_port_name)
virtual void connect_uses_port (const char *uses_port_name, Ports::Port_ptr provides_port_ref)
virtual CORBA::Boolean is_connected (const char *port_name)
virtual void disconnect_provides_port (const char *provides_port_name, const Engines::DSC::Message message)
virtual void disconnect_uses_port (const char *uses_port_name, Ports::Port_ptr provides_port_ref, const Engines::DSC::Message message)
virtual Ports::PortProperties_ptr get_port_properties (const char *port_name)
virtual void set_paco_proxy (CORBA::Object_ptr ref, const char *provides_port_name, Ports::PortProperties_ptr port_prop)
 This method is used to register the proxy of the parallel port into all the nodes of the parallel component. More...
virtual CORBA::Boolean add_parallel_provides_proxy_port (const CORBA::Object_ptr ref, const char *provides_port_name, Ports::PortProperties_ptr port_prop)
 This method is used by the node that want to add the parallel proxy port. More...
virtual CORBA::Boolean add_parallel_provides_proxy_wait (const char *provides_port_name)
 This method by the nodes that do not add the proxy to wait is reference. More...
virtual CORBA::Boolean add_parallel_provides_node_port (Ports::Port_PaCO_ptr ref, const char *provides_port_name)
 Permits to add a parallel node of a parallel provides port. More...
virtual const char * get_proxy (const char *provides_port_name)
 Used to get the proxy of the parallel port. More...
char * instanceName ()
 CORBA method: return name of the instance, unique in this Container. More...
char * interfaceName ()
 CORBA method: return name of the component class. More...
void ping ()
 CORBA method: Test if instance is alive and responds. More...
void destroy ()
 CORBA method: Deactivate this instance. More...
Engines::Container_ptr GetContainerRef ()
 CORBA method: return CORBA reference of the Container. More...
void setProperties (const Engines::FieldsDict &dico)
 CORBA method: Gives a sequence of (key=string,value=any) to the component. More...
Engines::FieldsDict * getProperties ()
 CORBA method: returns a previously stored map (key=string,value=any) as a sequence. More...
void Names (const char *graphName, const char *nodeName)
 CORBA method: used by Supervision to give names to this instance. More...
bool Kill_impl ()
 CORBA method: used in Supervision. More...
bool Stop_impl ()
bool Suspend_impl ()
bool Resume_impl ()
CORBA::Long CpuUsed_impl ()
 CORBA method: More...
 C++ method: DumpPython default implementation. More...
virtual Engines::Salome_file_ptr getInputFileToService (const char *service_name, const char *Salome_file_name)
virtual Engines::Salome_file_ptr getOutputFileToService (const char *service_name, const char *Salome_file_name)
virtual void checkInputFilesToService (const char *service_name)
virtual Engines::Salome_file_ptr setInputFileToService (const char *service_name, const char *Salome_file_name)
virtual void checkOutputFilesToService (const char *service_name)
virtual Engines::Salome_file_ptr setOutputFileToService (const char *service_name, const char *Salome_file_name)
void send_parallel_proxy_object (CORBA::Object_ptr proxy_ref)
 C++ method: Used by the Parallel Component to deploy a Parallel Salome_file. More...
virtual bool hasObjectInfo ()
virtual char * getObjectInfo (const char *entry)
PortableServer::ObjectId * getId ()
 C++ method: return CORBA instance id, the id is set in derived class constructor, when instance is activated. More...
Engines_Parallel_Container_i * GetContainerPtr ()
 C++ method: return Container Servant. More...
void beginService (const char *serviceName)
 C++ method: used by derived classes for supervision. More...
void endService (const char *serviceName)
void sendMessage (const char *event_type, const char *message)
 C++ method: Send message to event channel. More...
char * graphName ()
 C++ method: – CHECK IF USED –. More...
char * nodeName ()
bool Killer (pthread_t ThreadId, int signum)
 C++ method: used in Supervision (see kill_impl) More...
void SetCurCpu ()
 C++ method: More...
long CpuUsed ()
 C++ method: More...
void CancelThread ()
 C++ method: More...
void wait_parallel_object_proxy ()
char * get_parallel_proxy_object ()
virtual void configureSalome_file (std::string service_name, std::string file_port_name, Engines::Parallel_Salome_file_proxy_impl *file)
 C++ method: used to configure the Salome_file into the runtime. More...
virtual void provides_port_changed (const char *provides_port_name, int connection_nbr, const Engines::DSC::Message message)=0
 This method is used by the component when the number of connection on a provides port changes. More...
virtual void uses_port_changed (const char *uses_port_name, Engines::DSC::uses_port *new_uses_port, const Engines::DSC::Message message)=0
 This method is used by the component when the number of connection on a uses port changes. More...
static bool isMultiInstance ()
static std::string GetDynLibraryName (const char *componentName)
 C++ method: return standard library name built on component name. More...
static void writeEvent (const char *request, const std::string &containerName, const char *instance_name, const char *port_name, const char *error, const char *message)
 Write a record in the trace file. More...
Protected Types
typedef std::map< std::string, Parallel_Salome_file_i * > _t_Salome_file_map
typedef std::map< std::string, Engines::Parallel_Salome_file_proxy_impl * > _t_Proxy_Salome_file_map
typedef std::map< std::string, std::string > _t_IOR_Proxy_Salome_file_map
typedef std::map< std::string, Engines_Parallel_Component_i::_t_Salome_file_map * > _t_Service_file_map
typedef std::map< std::string, Engines_Parallel_Component_i::_t_Proxy_Salome_file_map * > _t_Proxy_Service_file_map
typedef std::map< std::string, Engines_Parallel_Component_i::_t_IOR_Proxy_Salome_file_map * > _t_IOR_Proxy_Service_file_map
enum  port_type { uses , provides , none }
typedef std::map< std::string, port_t * > ports
std::string _instanceName
std::string _interfaceName
CORBA::ORB_var _orb
PortableServer::POA_var _poa
PortableServer::ObjectId * _id
PortableServer::ObjectId * _contId
Engines_Parallel_Component_i * _thisObj
RegistryConnexion * _myConnexionToRegistry
NOTIFICATION_Supplier * _notifSupplier
std::map< std::string, CORBA::Any > _fieldsDict
_t_Service_file_map _Input_Service_file_map
_t_Service_file_map _Output_Service_file_map
_t_Service_file_map::iterator _Service_file_map_it
_t_Salome_file_map::iterator _Salome_file_map_it
_t_Proxy_Service_file_map _Proxy_Input_Service_file_map
_t_Proxy_Service_file_map _Proxy_Output_Service_file_map
_t_Proxy_Service_file_map::iterator _Proxy_Service_file_map_it
_t_Proxy_Salome_file_map::iterator _Proxy_Salome_file_map_it
_t_IOR_Proxy_Service_file_map _IOR_Proxy_Input_Service_file_map
_t_IOR_Proxy_Service_file_map _IOR_Proxy_Output_Service_file_map
_t_IOR_Proxy_Service_file_map::iterator _IOR_Proxy_Service_file_map_it
_t_IOR_Proxy_Salome_file_map::iterator _IOR_Proxy_Salome_file_map_it
std::string _serviceName
std::string _graphName
std::string _nodeName
pthread_mutex_t * deploy_mutex
char * _proxy
ports my_ports
ports::iterator my_ports_it
Static Protected Attributes
static bool _isMultiInstance = false
pthread_t _ThreadId
long _StartUsed
long _ThreadCpuUsed
bool _Executed
bool _CanceledThread
bool _destroyed
◆ _t_IOR_Proxy_Salome_file_map
typedef std::map<std::string, std::string> Engines_Parallel_Component_i::_t_IOR_Proxy_Salome_file_map
◆ _t_IOR_Proxy_Service_file_map
◆ _t_Proxy_Salome_file_map
typedef std::map<std::string, Engines::Parallel_Salome_file_proxy_impl*> Engines_Parallel_Component_i::_t_Proxy_Salome_file_map
◆ _t_Proxy_Service_file_map
◆ _t_Salome_file_map
typedef std::map<std::string, Parallel_Salome_file_i*> Engines_Parallel_Component_i::_t_Salome_file_map
◆ _t_Service_file_map
◆ ports
typedef std::map<std::string, port_t *> Engines_DSC_interface::ports
◆ port_type
enum Engines_DSC_interface::port_type
uses
provides
none
◆ Engines_ParallelDSC_i()
Engines_ParallelDSC_i::Engines_ParallelDSC_i ( CORBA::ORB_ptr  orb,
char *  ior,
int  rank,
const char *  instanceName,
const char *  interfaceName,
bool  notif = false
◆ ~Engines_ParallelDSC_i()
Engines_ParallelDSC_i::~Engines_ParallelDSC_i ( )
◆ add_parallel_provides_node_port()
CORBA::Boolean Engines_ParallelDSC_i::add_parallel_provides_node_port ( Ports::Port_PaCO_ptr  ref,
const char *  provides_port_name
refCORBA node reference.
provides_port_nameprovides port associated with the node.
true if the node is correctly added.
Referenced by Param_Double_Port_provides_i::init_port().
◆ add_parallel_provides_proxy_port()
CORBA::Boolean Engines_ParallelDSC_i::add_parallel_provides_proxy_port ( const CORBA::Object_ptr  ref,
const char *  provides_port_name,
refCORBA proxy reference.
provides_port_nameprovides port associated with the proxy.
true if the proxy is correctly added.
◆ add_parallel_provides_proxy_wait()
CORBA::Boolean Engines_ParallelDSC_i::add_parallel_provides_proxy_wait ( const char *  provides_port_name)
References get_proxy().
◆ add_provides_port()
virtual void Engines_ParallelDSC_i::add_provides_port ( Ports::Port_ptr  ref,
◆ add_uses_port()
virtual void Engines_ParallelDSC_i::add_uses_port ( const char *  repository_id,
const char *  uses_port_name,
◆ beginService()
◆ CancelThread()
void Engines_Parallel_Component_i::CancelThread ( )
C++ method:
References Engines_Parallel_Component_i::_CanceledThread.
Referenced by CallCancelThread().
◆ checkInputFilesToService()
void Engines_Parallel_Component_i::checkInputFilesToService ( const char *  service_name)
◆ checkOutputFilesToService()
void Engines_Parallel_Component_i::checkOutputFilesToService ( const char *  service_name)
◆ configureSalome_file()
void Engines_Parallel_Component_i::configureSalome_file ( std::string  service_name,
Engines::Parallel_Salome_file_proxy_impl *  file
service_namename of the service that use this Salome_file
file_port_namename of the Salome_file
fileParallel Salome_file C++ object
Referenced by Engines_Parallel_Component_i::checkInputFilesToService(), and Engines_Parallel_Component_i::checkOutputFilesToService().
◆ connect_provides_port()
virtual void Engines_ParallelDSC_i::connect_provides_port ( const char *  provides_port_name)
◆ connect_uses_port()
virtual void Engines_ParallelDSC_i::connect_uses_port ( const char *  uses_port_name,
◆ CpuUsed()
◆ CpuUsed_impl()
◆ destroy()
void Engines_Parallel_Component_i::destroy ( )
CORBA object is deactivated (do not respond any more to CORBA calls), the connection to Regsitry is removed (Registry informed of deactivation), internal server reference counter on the derived servant class is decremented, to allow destruction of the class (delete) by POA, when there are no more references. – TO BE USED BY CONTAINER ONLY (Container housekeeping) –
References Engines_Parallel_Component_i::_destroyed, and MESSAGE.
◆ disconnect_provides_port()
virtual void Engines_ParallelDSC_i::disconnect_provides_port ( const char *  provides_port_name,
◆ disconnect_uses_port()
virtual void Engines_ParallelDSC_i::disconnect_uses_port ( const char *  uses_port_name,
◆ DumpPython()
Engines::TMPFile * Engines_Parallel_Component_i::DumpPython ( CORBA::Boolean  isPublished,
◆ endService()
◆ get_parallel_proxy_object()
char * Engines_Parallel_Component_i::get_parallel_proxy_object ( )
◆ get_port_properties()
virtual Ports::PortProperties_ptr Engines_ParallelDSC_i::get_port_properties ( const char *  port_name)
◆ get_provides_port()
virtual Ports::Port_ptr Engines_ParallelDSC_i::get_provides_port ( const char *  provides_port_name,
◆ get_proxy()
const char * Engines_ParallelDSC_i::get_proxy ( const char *  provides_port_name)
provides_port_namename of the parallel provides port.
IOR of the proxy.
References Engines_Parallel_Component_i::_orb, and Engines_DSC_interface::get_provides_port().
Referenced by add_parallel_provides_proxy_wait(), Param_Double_Port_provides_i::init_port(), and Param_Double_Port_provides_i::wait_init_port().
◆ get_uses_port()
virtual Engines::DSC::uses_port * Engines_ParallelDSC_i::get_uses_port ( const char *  uses_port_name)
◆ GetContainerPtr()
Engines_Parallel_Container_i * Engines_Parallel_Component_i::GetContainerPtr ( )
References Engines_Parallel_Component_i::_contId, and Engines_Parallel_Component_i::_poa.
◆ GetContainerRef()
Engines::Container_ptr Engines_Parallel_Component_i::GetContainerRef ( )
References Engines_Parallel_Component_i::_contId, Engines_Parallel_Component_i::_poa, and MESSAGE.
◆ GetDynLibraryName()
std::string Engines_Parallel_Component_i::GetDynLibraryName ( const char *  componentName)
References TestKernelHelpers::ret.
◆ getId()
PortableServer::ObjectId * Engines_Parallel_Component_i::getId ( )
References Engines_Parallel_Component_i::_id.
◆ getInputFileToService()
Engines::Salome_file_ptr Engines_Parallel_Component_i::getInputFileToService ( const char *  service_name,
const char *  Salome_file_name
◆ getObjectInfo()
virtual char * Engines_Parallel_Component_i::getObjectInfo ( const char *  entry)
◆ getOutputFileToService()
Engines::Salome_file_ptr Engines_Parallel_Component_i::getOutputFileToService ( const char *  service_name,
◆ getProperties()
Engines::FieldsDict * Engines_Parallel_Component_i::getProperties ( )
(see setProperties)
References Engines_Parallel_Component_i::_fieldsDict.
◆ graphName()
char * Engines_Parallel_Component_i::graphName ( )
◆ hasObjectInfo()
virtual bool Engines_Parallel_Component_i::hasObjectInfo ( )
◆ instanceName()
char * Engines_Parallel_Component_i::instanceName ( )
References Engines_Parallel_Component_i::_instanceName.
Referenced by Engines_Parallel_Component_i::Engines_Parallel_Component_i().
◆ interfaceName()
char * Engines_Parallel_Component_i::interfaceName ( )
References Engines_Parallel_Component_i::_interfaceName.
◆ is_connected()
virtual CORBA::Boolean Engines_ParallelDSC_i::is_connected ( const char *  port_name)
◆ isMultiInstance()
static bool Engines_Parallel_Component_i::isMultiInstance ( )
◆ Kill_impl()
bool Engines_Parallel_Component_i::Kill_impl ( )
References Engines_Parallel_Component_i::_ThreadId, and Engines_Parallel_Component_i::Killer().
◆ Killer()
bool Engines_Parallel_Component_i::Killer ( pthread_t  ThreadId,
int  signum
◆ Names()
void Engines_Parallel_Component_i::Names ( const char *  graphName,
const char *  nodeName
◆ nodeName()
◆ ping()
void Engines_Parallel_Component_i::ping ( )
References MESSAGE.
◆ provides_port_changed()
virtual void DSC_Callbacks::provides_port_changed ( const char *  provides_port_name,
int  connection_nbr,
pure virtualinherited
This information helps the user code to detect operation on its ports.
provides_port_namethe name of the provides name that has changed.
connection_nbrthe new number of connection on the provides port.
messagecontains informations about the modification of the port.
Implemented in Superv_Component_i.
Referenced by Engines_DSC_interface::connect_provides_port(), and Engines_DSC_interface::disconnect_provides_port().
◆ Resume_impl()
bool Engines_Parallel_Component_i::Resume_impl ( )
◆ send_parallel_proxy_object()
void Engines_Parallel_Component_i::send_parallel_proxy_object ( CORBA::Object_ptr  proxy_ref)
References Engines_Parallel_Component_i::_orb, and Engines_Parallel_Component_i::_proxy.
◆ sendMessage()
void Engines_Parallel_Component_i::sendMessage ( const char *  event_type,
const char *  message
◆ set_paco_proxy()
void Engines_ParallelDSC_i::set_paco_proxy ( CORBA::Object_ptr  ref,
port_propport properties.
References Engines_DSC_interface::add_provides_port().
◆ SetCurCpu()
void Engines_Parallel_Component_i::SetCurCpu ( )
◆ setInputFileToService()
◆ setOutputFileToService()
◆ setProperties()
void Engines_Parallel_Component_i::setProperties ( const Engines::FieldsDict &  dico)
Base class component stores the sequence in a map. The map is cleared before. This map is for use by derived classes.
dicosequence of (key=string,value=any)
◆ Stop_impl()
◆ Suspend_impl()
◆ uses_port_changed()
virtual void DSC_Callbacks::uses_port_changed ( const char *  uses_port_name,
Engines::DSC::uses_port *  new_uses_port,
uses_port_namethe name of the uses name that has changed.
new_uses_portthe new sequence representing the uses port.
Referenced by Engines_DSC_interface::connect_uses_port(), and Engines_DSC_interface::disconnect_uses_port().
◆ wait_parallel_object_proxy()
void Engines_Parallel_Component_i::wait_parallel_object_proxy ( )
References Engines_Parallel_Component_i::get_parallel_proxy_object().
Referenced by Engines_Parallel_Component_i::setInputFileToService(), and Engines_Parallel_Component_i::setOutputFileToService().
◆ writeEvent()
void Engines_DSC_interface::writeEvent ( const char *  request,
const std::string &  containerName,
const char *  instance_name,
const char *  port_name,
const char *  error,
requestthe name of the request executed
containerNamethe name of the container where the request is executed
instance_namethe name of the component where the request is executed
port_namethe name of the port that is concerned
errorif an error has occured, a string that identifies the error
messageinformations about error or about the request
References SALOME_ContainerPy::containerName, IDLparser::error(), initTrace(), TestMinimalExample::msg, out, traceLevel, and traceType.
Referenced by create_calcium_port(), CalciumInterface::ecp_cd(), CalciumInterface::ecp_ecriture(), CalciumInterface::ecp_effi(), CalciumInterface::ecp_efft(), CalciumInterface::ecp_fin(), CalciumInterface::ecp_fini(), CalciumInterface::ecp_fint(), CalciumInterface::ecp_lecture(), GenericPort< DataManipulator, COUPLING_POLICY >::get(), and GenericPort< DataManipulator, COUPLING_POLICY >::next().
◆ _CanceledThread
bool Engines_Parallel_Component_i::_CanceledThread
privateinherited
◆ _contId
◆ _destroyed
bool Engines_Parallel_Component_i::_destroyed
privateinherited
◆ _Executed
◆ _fieldsDict
◆ _graphName
◆ _id
◆ _Input_Service_file_map
_t_Service_file_map Engines_Parallel_Component_i::_Input_Service_file_map
◆ _instanceName
◆ _interfaceName
◆ _IOR_Proxy_Input_Service_file_map
_t_IOR_Proxy_Service_file_map Engines_Parallel_Component_i::_IOR_Proxy_Input_Service_file_map
◆ _IOR_Proxy_Output_Service_file_map
_t_IOR_Proxy_Service_file_map Engines_Parallel_Component_i::_IOR_Proxy_Output_Service_file_map
◆ _IOR_Proxy_Salome_file_map_it
_t_IOR_Proxy_Salome_file_map::iterator Engines_Parallel_Component_i::_IOR_Proxy_Salome_file_map_it
◆ _IOR_Proxy_Service_file_map_it
_t_IOR_Proxy_Service_file_map::iterator Engines_Parallel_Component_i::_IOR_Proxy_Service_file_map_it
◆ _isMultiInstance
bool Engines_Parallel_Component_i::_isMultiInstance = false
staticprotectedinherited
◆ _myConnexionToRegistry
RegistryConnexion* Engines_Parallel_Component_i::_myConnexionToRegistry
◆ _nodeName
◆ _notifSupplier
◆ _orb
◆ _Output_Service_file_map
_t_Service_file_map Engines_Parallel_Component_i::_Output_Service_file_map
◆ _poa
◆ _proxy
◆ _Proxy_Input_Service_file_map
◆ _Proxy_Output_Service_file_map
◆ _Proxy_Salome_file_map_it
_t_Proxy_Salome_file_map::iterator Engines_Parallel_Component_i::_Proxy_Salome_file_map_it
◆ _Proxy_Service_file_map_it
◆ _Salome_file_map_it
_t_Salome_file_map::iterator Engines_Parallel_Component_i::_Salome_file_map_it
◆ _Service_file_map_it
_t_Service_file_map::iterator Engines_Parallel_Component_i::_Service_file_map_it
◆ _serviceName
◆ _StartUsed
◆ _thisObj
Engines_Parallel_Component_i* Engines_Parallel_Component_i::_thisObj
◆ _ThreadCpuUsed
◆ _ThreadId
◆ deploy_mutex
◆ my_ports
◆ my_ports_it
