Engines::DSC Interface Reference
Interface of a DSC component. More...
import"DSC_Engines.idl";
Inheritance diagram for Engines::DSC:
exception  BadPortReference
 Port's reference is not the right reference. More...
exception  BadPortType
 This exception is raised if the type of the provides port is bad. More...
exception  BadProperty
 Object property is not good for the port. More...
exception  NilPort
 Port's reference is Nil ! More...
exception  PortAlreadyDefined
 This exception is raised if you try to add a port with the same name than a previous defined port. More...
exception  PortNotConnected
 This exception is raised when you try to use a port that is not connected. More...
exception  PortNotDefined
 This exception is raised when a port is used before it is added to the component. More...
enum  Message { AddingConnection , RemovingConnection , ApplicationError }
 This enumeration is used when the connection of a port (uses or provides) is changed. More...
typedef sequence< Ports::Port > uses_port
 a uses port More...
void add_provides_port (in Ports::Port ref, in string provides_port_name, in Ports::PortProperties port_prop) raises (PortAlreadyDefined, NilPort, BadProperty)
 This operation adds a provides port to the component. More...
void add_uses_port (in string repository_id, in string uses_port_name, in Ports::PortProperties port_prop) raises (PortAlreadyDefined, BadProperty)
 This operation adds a uses port to the component. More...
Ports::Port get_provides_port (in string provides_port_name, in boolean connection_error) raises (PortNotDefined, PortNotConnected, BadPortType)
 Get a provides port of the component. More...
uses_port get_uses_port (in string uses_port_name) raises (PortNotDefined, PortNotConnected, BadPortType)
 Get a uses port of the component. More...
void connect_provides_port (in string provides_port_name) raises (PortNotDefined)
 Connect a provides port with a uses port. More...
void connect_uses_port (in string uses_port_name, in Ports::Port provides_port_ref) raises (PortNotDefined, BadPortType, NilPort)
 Connect a uses port with a provides port. More...
boolean is_connected (in string port_name) raises (PortNotDefined)
 Check if a port is connected. More...
void disconnect_provides_port (in string provides_port_name, in Engines::DSC::Message message) raises (PortNotDefined, PortNotConnected)
 Disconnect a uses port from a provides port. More...
void disconnect_uses_port (in string uses_port_name, in Ports::Port provides_port_ref, in Engines::DSC::Message message) raises (PortNotDefined, PortNotConnected, BadPortReference)
 Disconnect a provides port from a uses port. More...
Ports::PortProperties get_port_properties (in string port_name) raises (PortNotDefined)
 Get port's property object. More...
void ping ()
 Determines whether the server has already been loaded or not. More...
boolean isSSLMode () raises (SALOME::SALOME_Exception)
void destroy ()
 Remove component instance from container. More...
Container GetContainerRef ()
 Returns the container that the Component refers to. More...
void setProperties (in FieldsDict dico)
 Set component instance properties. More...
FieldsDict getProperties ()
 Get component instance properties. More...
void SetOption (in string optionName, in string value)
 Set an option value. More...
string GetOption (in string optionName)
 Return an option value. More...
void Names (in string aGraphName, in string aNodeName)
 Set name of a node in a graph (for SUPERVISOR use) More...
boolean Kill_impl ()
 Kill the component (if you can) More...
boolean Stop_impl ()
 Stop the component (if you can) More...
boolean Suspend_impl ()
 Suspend the component. More...
boolean Resume_impl ()
 Resume the component. More...
long CpuUsed_impl ()
 Get the cpu used. More...
TMPFile DumpPython (in boolean isPublished, in boolean isMultiFile, out boolean isValidScript)
 Get a python dump. More...
Engines::Salome_file getInputFileToService (in string service_name, in string Salome_file_name) raises (SALOME::SALOME_Exception)
 Returns a CORBA Ref of a input Salome_file managed by a service. More...
void checkInputFilesToService (in string service_name) raises (SALOME::SALOME_Exception)
 Check service input files (transfer them if needed) More...
Engines::Salome_file setInputFileToService (in string service_name, in string Salome_file_name) raises (SALOME::SALOME_Exception)
 This method adds a input Salome_file to a service of the component. More...
Engines::Salome_file getOutputFileToService (in string service_name, in string Salome_file_name) raises (SALOME::SALOME_Exception)
 Returns a CORBA Ref of a output Salome_file managed by a service. More...
void checkOutputFilesToService (in string service_name) raises (SALOME::SALOME_Exception)
 Check service output files (transfer them if needed) More...
Engines::Salome_file setOutputFileToService (in string service_name, in string Salome_file_name) raises (SALOME::SALOME_Exception)
 This method adds an output Salome_file to a service of the component. More...
boolean hasObjectInfo ()
 Indicate if the component instance provides custom information about its objects. More...
string getObjectInfo (in string entry)
 Get custom information about the given object. More...
string getVersion ()
 Get version of the component. More...
Data Fields
readonly attribute string instanceName
 The name of the instance of the Component. More...
readonly attribute string interfaceName
 The name of the interface of the Component. More...
This interface defines the operations needed to add a component model with dynamic port declaration to the SALOME object model. A component is a black box that interacts with other components only by his ports. A port represents a connection point for the component. In this model, a port is a CORBA interface, so a CORBA object.
There is two ways for a component to interact with a port type :
  • It implements the port : it means "the component provides an implementation of the interface of the port". We design this kind of port as "provides ports". It provides an interface to other components.
  • It needs to use an object that provides the port interface. We say that the component uses this port type. It is represented by a "uses" port. A uses port can be connected with a provides port of the same interface type. When the connection is done, a component can use the "uses port" to use the interface provided by the "provides port".
The interface DSC implements the component interface that contains the operations that are needed to manage declarations into a component and connections between ports.
These operations are logicaly divided in two parts :
  • First part permits to add an get ports of a component.
  • Second part permits to connect/disconnect ports.
◆ uses_port
a uses port
This sequence is a uses port. It's a sequence since a uses port can be connected with x provides port. Sometimes this kind of uses port is called multiple port. At this programming level, the user has to deal with the sequence. In the DSC_user layer, the user only deals with one pointer.
◆ Message
This information is for the component's user code.
AddingConnection
RemovingConnection
ApplicationError
◆ add_provides_port()
void Engines::DSC::add_provides_port ( in Ports::Port  ref,
NilPort,
BadProperty
refport's Corba reference.
provides_port_nameport's name.
port_propport's property object.
Exceptions
PortAlreadyDefined
NilPort
BadProperty
Notice that the name of the port is unique on a component. So if there is a uses port that has the same name, the PortAlreadyDefined exception will be throw. Also notice that each port as an object property that is associated with.
◆ add_uses_port()
void Engines::DSC::add_uses_port ( in string  repository_id,
BadProperty
repository_idport's Corba repository id. Eg : IDL:toto.tata/MODULE/INTERFACE_NAME:1.0
uses_port_nameport's name.
Exceptions
PortAlreadyDefined
BadProperty
Notice that the name of the port is unique on the component. So if there is a provides port that has the same name, the PortAlreadyDefined exception will be throw. Also notice that each port as an object property that is associated with.
◆ checkInputFilesToService()
void Engines::EngineComponent::checkInputFilesToService ( in string  service_name)
This method is used before the activation of the service. It calls recvFiles() on all the input Salome_file files of the service.
Before each recvFiles(), it uses the callback method named configureSalome_file. This method allows the user to configure the files managed by the Salome_file.
By default, there is no files managed when a Salome_file is created, but the supervisor set some files managed by the Salome_file from the information contained into the schema file.
service_nameservice's name.
Exceptions
containsinformation about files that are not in a good state.
◆ checkOutputFilesToService()
void Engines::EngineComponent::checkOutputFilesToService ( in string  service_name)
This method is used at the end of the service. It calls recvFiles() on all the output Salome_file files of the service.
Exceptions
◆ connect_provides_port()
void Engines::DSC::connect_provides_port ( in string  provides_port_name)
provides_port_nameprovides port's name.
Exceptions
PortNotDefined
Notice that the provides doesn't uses port names or component reference.
◆ connect_uses_port()
void Engines::DSC::connect_uses_port ( in string  uses_port_name,
BadPortType,
NilPort
uses_port_nameuses port's name.
provides_port_refprovides port's Corba reference.
Exceptions
PortNotDefined
BadPortType
NilPort
◆ CpuUsed_impl()
long Engines::EngineComponent::CpuUsed_impl ( )
◆ destroy()
void Engines::EngineComponent::destroy ( )
Deactivates the Component. – TO BE USED BY CONTAINER ONLY (Container housekeeping) – use remove_impl from Container instead !
◆ disconnect_provides_port()
void Engines::DSC::disconnect_provides_port ( in string  provides_port_name,
PortNotConnected
messagestate associated with the disconnection.
Exceptions
PortNotDefined
PortNotConnected
◆ disconnect_uses_port()
void Engines::DSC::disconnect_uses_port ( in string  uses_port_name,
PortNotConnected,
BadPortReference
provides_port_refCORBA reference of the provides port.
Exceptions
PortNotDefined
PortNotConnected
BadPortReference
◆ DumpPython()
TMPFile Engines::EngineComponent::DumpPython ( in boolean  isPublished,
Get a python dump.
Returns a python script, which is being played back reproduces the data model of component
◆ get_port_properties()
Ports::PortProperties Engines::DSC::get_port_properties ( in string  port_name)
properties object's CORBA reference.
Exceptions
PortNotDefined
◆ get_provides_port()
Ports::Port Engines::DSC::get_provides_port ( in string  provides_port_name,
PortNotConnected,
BadPortType
It can be used by the framework or the component himself.
If it's the framework that wants the port, the reference has to be given even if the port is not connected (boolean connection_error to false). Contrary, if it's the component that wants the port, the port is given in most of cases only if it is connected (boolean connection_error to true). Notice that you can choose the behaviour that you want.
connection_errortrue if you want to wait that the port is connected with an another port.
Exceptions
PortNotDefined
PortNotConnected
BadPortType
◆ get_uses_port()
uses_port Engines::DSC::get_uses_port ( in string  uses_port_name)
PortNotConnected,
BadPortType
It can be used by the framework or the component himself. Actually, only the user layer of the component will use this operation. A uses port could be obtained if and only if the uses port is connected. The sequence contains all the connections since a uses port can have multiple connections.
There is a system of callbacks to prevent the user code that there is a new (or a deletion) of a connection (see DSC_Callbacks class).
uses port's sequence.
Exceptions
PortNotDefined
PortNotConnected
BadPortType
See also
DSC_Callbacks
◆ GetContainerRef()
Container Engines::EngineComponent::GetContainerRef ( )
◆ getInputFileToService()
Engines::Salome_file Engines::EngineComponent::getInputFileToService ( in string  service_name,
file_namename of the requested file.
CORBA Ref of the requested file.
Exceptions
containsinformation of what if the component cannot sends the file's reference.
◆ getObjectInfo()
string Engines::EngineComponent::getObjectInfo ( in string  entry)
This method is used to get the custom information about the given object. Should be redefined in the certain component in case of this component provides such information. It is worth using this method only if hasObjectInfo() method returns true.
entryobject's entry.
an information about the given object.
◆ GetOption()
string Engines::EngineComponent::GetOption ( in string  optionName)
This method is to get value of an option specific to a certain EngineComponent.
◆ getOutputFileToService()
Engines::Salome_file Engines::EngineComponent::getOutputFileToService ( in string  service_name,
Exceptions
◆ getProperties()
FieldsDict Engines::EngineComponent::getProperties ( )
returns a previously stored map (key=string,value=any) as a sequence. See setProperties(in FieldsDict dico).
◆ getVersion()
string Engines::EngineComponent::getVersion ( )
This method is supposed to be implemented in all derived classes; default implementation returns "unknown" string that means that no version information about the component is available.
The version of the component is stored to the study, as a part of general persistence mechanism; once stored, version information in the study cannot be changed.
string containing component's version, e.g. "1.0"
Referenced by SALOME_DriverPy.SALOME_DriverPy_i::Version().
◆ hasObjectInfo()
boolean Engines::EngineComponent::hasObjectInfo ( )
Returns true if the component provides custom information about its objects, false otherwise. Should be redefined in the certain component to return true in case of this component provides such information.
◆ is_connected()
boolean Engines::DSC::is_connected ( in string  port_name)
You can test a uses port or a provides port.
true if the uses port is connected.
Exceptions
PortNotDefined
◆ isSSLMode()
boolean Engines::EngineComponent::isSSLMode ( )
◆ Kill_impl()
boolean Engines::EngineComponent::Kill_impl ( )
Returns True if the Component has been killed.
◆ Names()
void Engines::EngineComponent::Names ( in string  aGraphName,
in string  aNodeName
This method is used by the SUPERVISOR component. It sets the names of the graph and of the node.
aGraphNameName of graph
aNodeNameName of node
◆ ping()
void Engines::EngineComponent::ping ( )
◆ Resume_impl()
boolean Engines::EngineComponent::Resume_impl ( )
Returns True if the activity of the Component has been resumed.
◆ setInputFileToService()
Engines::Salome_file Engines::EngineComponent::setInputFileToService ( in string  service_name,
Salome_file_namename of the Salome_file
a reference of the Salome_file
Exceptions
raisesan exception if there is already a Salome_file with this name for the service.
◆ SetOption()
void Engines::EngineComponent::SetOption ( in string  optionName,
in string  value
This method is to set an option specific to a certain EngineComponent.
◆ setOutputFileToService()
Engines::Salome_file Engines::EngineComponent::setOutputFileToService ( in string  service_name,
Exceptions
◆ setProperties()
void Engines::EngineComponent::setProperties ( in FieldsDict  dico)
Gives a sequence of (key=string,value=any) to the component. Base class component stores the sequence in a map. The map is cleared before. This map is for use by derived classes.
◆ Stop_impl()
boolean Engines::EngineComponent::Stop_impl ( )
Returns True if the activity of the Component has been stopped. (It's action can't be resumed)
◆ Suspend_impl()
boolean Engines::EngineComponent::Suspend_impl ( )
Returns True if the activity of the Component has been suspended. (It's action can be resumed)
◆ instanceName
readonly attribute string Engines::EngineComponent::instanceName
◆ interfaceName
readonly attribute string Engines::EngineComponent::interfaceName
