DSC_Callbacks Class Referenceabstract
This is an abstract class that defines methods that the component uses to notify the component user code that the state of the component has changed. More...
#include <DSC_Callbacks.hxx>
Inheritance diagram for DSC_Callbacks:
 DSC_Callbacks ()
virtual ~DSC_Callbacks ()
virtual void provides_port_changed (const char *provides_port_name, int connection_nbr, const Engines::DSC::Message message)=0
 This method is used by the component when the number of connection on a provides port changes. More...
virtual void uses_port_changed (const char *uses_port_name, Engines::DSC::uses_port *new_uses_port, const Engines::DSC::Message message)=0
 This method is used by the component when the number of connection on a uses port changes. More...
Currently only port's connection modifications are signaled.
◆ DSC_Callbacks()
DSC_Callbacks::DSC_Callbacks ( )
◆ ~DSC_Callbacks()
virtual DSC_Callbacks::~DSC_Callbacks ( )
◆ provides_port_changed()
virtual void DSC_Callbacks::provides_port_changed ( const char *  provides_port_name,
int  connection_nbr,
pure virtual
This information helps the user code to detect operation on its ports.
provides_port_namethe name of the provides name that has changed.
connection_nbrthe new number of connection on the provides port.
messagecontains informations about the modification of the port.
Implemented in Superv_Component_i.
Referenced by Engines_DSC_interface::connect_provides_port(), and Engines_DSC_interface::disconnect_provides_port().
◆ uses_port_changed()
virtual void DSC_Callbacks::uses_port_changed ( const char *  uses_port_name,
Engines::DSC::uses_port *  new_uses_port,
pure virtual
uses_port_namethe name of the uses name that has changed.
new_uses_portthe new sequence representing the uses port.
Referenced by Engines_DSC_interface::connect_uses_port(), and Engines_DSC_interface::disconnect_uses_port().
