DSC_Engines.idl
23// File : DSC_Engines.idl
24// Author : Andre RIBES, EDF
25// $Header:
26//
27#ifndef _DSC_ENGINES_IDL_
28#define _DSC_ENGINES_IDL_
30#include "SALOME_Component.idl"
31#include "SALOME_Ports.idl"
32
36module Engines {
37
62
63/*--------------------------------------------------------------------------------------------*/
64/*-------------------------------------- Types Part ------------------------------------------*/
65
67
73 typedef sequence<Ports::Port> uses_port;
74
76
81 ApplicationError};
82
84 exception PortNotDefined {};
85
87 exception PortAlreadyDefined {};
88
90 exception PortNotConnected {};
91
93
97 exception BadPortType {
98 string expected;
99 string received;
100 };
101
103 exception NilPort {};
104
106 exception BadPortReference {};
107
109 exception BadProperty {};
110
111
112/*--------------------------------------------------------------------------------------------*/
113/*-------------------------------------- Operation Part --------------------------------------*/
114
116
131 in string provides_port_name,
132 in Ports::PortProperties port_prop) raises(PortAlreadyDefined,
133 NilPort,
135
137
151 void add_uses_port(in string repository_id,
152 in string uses_port_name,
153 in Ports::PortProperties port_prop) raises(PortAlreadyDefined,
155
157
176 Ports::Port get_provides_port(in string provides_port_name,
177 in boolean connection_error) raises(PortNotDefined,
180
182
200 uses_port get_uses_port(in string uses_port_name) raises(PortNotDefined,
203
204
206
214 void connect_provides_port(in string provides_port_name) raises(PortNotDefined);
215
217
226 void connect_uses_port(in string uses_port_name,
227 in Ports::Port provides_port_ref) raises(PortNotDefined,
229 NilPort);
230
232
240 boolean is_connected(in string port_name) raises(PortNotDefined);
241
243
251 void disconnect_provides_port(in string provides_port_name,
252 in Engines::DSC::Message message) raises(PortNotDefined,
254
256
266 void disconnect_uses_port(in string uses_port_name,
267 in Ports::Port provides_port_ref,
268 in Engines::DSC::Message message) raises(PortNotDefined,
272
280
281 };
282
288
290 exception BadId {};
291
293 typedef short connectionId;
294
296
312 in string uses_port_name,
313 in Engines::DSC provides_component,
314 in string provides_port_name) raises(Engines::DSC::PortNotDefined,
317
319
332
334 oneway void ShutdownWithExit();
335
337 long getPID();
338 };
339
340/*--------------------------------------------------------------------------------------------*/
341
349
351
358 boolean init_service(in string service_name);
359
361 string name;
362 long number;
363 };
364
365 typedef sequence<multiple_param> seq_multiple_param;
366
376 boolean init_service_with_multiple(in string service_name, in seq_multiple_param params);
377 };
378};
379
380#endif
interfaces for EngineComponent and Container
This file contains the IDL base interfaces for ports in the SALOME component model.
The Id given to the disconnect method is bad.
Definition: DSC_Engines.idl:290
Port's reference is not the right reference.
Definition: DSC_Engines.idl:106
This exception is raised if the type of the provides port is bad.
Definition: DSC_Engines.idl:97
string expected
Definition: DSC_Engines.idl:98
string received
Definition: DSC_Engines.idl:99
Object property is not good for the port.
Definition: DSC_Engines.idl:109
Port's reference is Nil !
Definition: DSC_Engines.idl:103
This exception is raised if you try to add a port with the same name than a previous defined port.
Definition: DSC_Engines.idl:87
This exception is raised when you try to use a port that is not connected.
Definition: DSC_Engines.idl:90
This exception is raised when a port is used before it is added to the component.
Definition: DSC_Engines.idl:84
Interface of the ConnectionManager.
Definition: DSC_Engines.idl:287
Shutdown the ConnectionManager process.
short connectionId
A connection Id. It's unique.
Definition: DSC_Engines.idl:293
connectionId connect(in Engines::DSC uses_component, in string uses_port_name, in Engines::DSC provides_component, in string provides_port_name)
Connect a uses port with a provides port.
long getPID()
Return the PID of the connection manager.
void disconnect(in connectionId id, in Engines::DSC::Message message)
Release a connection that has been previously created by the ConnectionManager.
Interface of a DSC component.
Definition: DSC_Engines.idl:61
void connect_uses_port(in string uses_port_name, in Ports::Port provides_port_ref)
Ports::PortProperties get_port_properties(in string port_name)
Get port's property object.
Get a uses port of the component.
Message
This enumeration is used when the connection of a port (uses or provides) is changed.
Definition: DSC_Engines.idl:79
@ AddingConnection
@ RemovingConnection
Definition: DSC_Engines.idl:80
sequence< Ports::Port > uses_port
a uses port
Definition: DSC_Engines.idl:73
void disconnect_uses_port(in string uses_port_name, in Ports::Port provides_port_ref, in Engines::DSC::Message message)
Disconnect a provides port from a uses port.
void disconnect_provides_port(in string provides_port_name, in Engines::DSC::Message message)
Disconnect a uses port from a provides port.
Ports::Port get_provides_port(in string provides_port_name, in boolean connection_error)
Get a provides port of the component.
Connect a provides port with a uses port.
void add_provides_port(in Ports::Port ref, in string provides_port_name, in Ports::PortProperties port_prop)
This operation adds a provides port to the component.
void add_uses_port(in string repository_id, in string uses_port_name, in Ports::PortProperties port_prop)
This operation adds a uses port to the component.
Check if a port is connected.
Interface of the component.
Definition: SALOME_Component.idl:328
Interface of the Superv_Component.
Definition: DSC_Engines.idl:348
Operation to create the service ports before it is executed.
sequence< multiple_param > seq_multiple_param
Definition: DSC_Engines.idl:365
YACS module call this method before starting the service.
Interface of a PortProperties.
Definition: SALOME_Ports.idl:87
Interface of a DSC Port.
Definition: SALOME_Ports.idl:42
Definition: DSC_Engines.idl:360
long number
Definition: DSC_Engines.idl:362
string name
Definition: DSC_Engines.idl:361
