idl Directory Reference
Files
file  DSC_Engines.idl [code]
 interfaces that permits to add a dynamic port model to the SALOME object model.
file  Logger.idl [code]
 interfaces for SALOME logger
file  nstest.idl [code]
 interfaces for naming service test
file  Palm_Ports.idl [code]
 This file contains IDL palm ports declarations.
file  SALOME_Comm.idl [code]
 This file contains a set of interfaces used for communication between components.
file  SALOME_CommonTypes.idl [code]
file  SALOME_Component.idl [code]
 interfaces for EngineComponent and Container
file  SALOME_ContainerManager.idl [code]
 interfaces for SALOME Container Manager service
file  SALOME_Embedded_NamingService.idl [code]
file  SALOME_Exception.idl [code]
 This file contains the objects defining the main exception used in SALOME application.
file  SALOME_ExternalServerLauncher.idl [code]
file  SALOME_GenericObj.idl [code]
 interface for common behavior of SALOME transient CORBA objects
file  SALOME_Launcher.idl [code]
 Interfaces for SALOME Launcher service.
file  SALOME_Locker.idl [code]
file  SALOME_LogManager.idl [code]
file  SALOME_ModuleCatalog.idl [code]
 interfaces used for
getting information from module catalog in SALOME application
file  SALOME_MPIContainer.idl [code]
 interfaces for parallel container
file  SALOME_MPIObject.idl [code]
 interfaces for parallel (MPI) objects
file  SALOME_PACOExtension.idl [code]
 Interfaces for Parallel Component and Container using PaCO++.
file  SALOME_Parametric.idl [code]
file  SALOME_ParamPorts.idl [code]
file  SALOME_Ports.idl [code]
 This file contains the IDL base interfaces for ports in the SALOME component model.
file  SALOME_PyNode.idl [code]
 interface for remote python execution
file  SALOME_Registry.idl [code]
 interfaces for SALOME registry
file  SALOME_ResourcesManager.idl [code]
 interfaces for SALOME Resources Manager service
file  SALOME_SDS.idl [code]
file  SALOME_Session.idl [code]
 file that contains interface of the session
file  SALOME_TestComponent.idl [code]
 an interface for testing EngineComponent and Container
file  SALOME_TestModuleCatalog.idl [code]
 interfaces for SALOME module catalog test
file  SALOME_TestMPIComponent.idl [code]
 interface to test MPIObject and MPIContainer
file  SALOME_Types.idl [code]
file  SALOMEDS.idl [code]
 This file contains a set of interfaces used for creation, management and modification of the Study.
file  SALOMEDS_Attributes.idl [code]
 This file contains a set of interfaces for the attributes which can be assigned to SObject.
file  TestNotif.idl [code]
 for testing notification service
file  TypeData.idl [code]
 data definition for tests
