SALOMEDS.idl
23// File : SALOMEDS.idl
24// Author : Yves FRICAUD
25//
30#ifndef _SALOMEDS_IDL_
31#define _SALOMEDS_IDL_
32
33#include "SALOME_Exception.idl"
34#include "SALOME_GenericObj.idl"
35
40module SALOMEDS
41{
44 typedef wstring URLPath;
45
48 typedef string ID;
49
52 typedef string PersistentReference;
53
56 typedef string SalomeReference;
57
59 typedef sequence<string> ListOfFileNames;
61 typedef sequence<string> ListOfDates ;
63 typedef sequence<string> ListOfStrings ;
65 typedef sequence<ListOfStrings> ListOfListOfStrings ;
67 typedef sequence<octet> TMPFile;
68
69 // Reference to other objects is treated with function AddReference
70 // and ReferencedObject
71 // All other type of attributes defined in AttributeType enum are
72 // treated with AddAdttribute and GetAttribute
73 // The difference is made because Reference attribute don't contain
74 // strings but reference to ID of other objects
75
76 interface GenericAttribute;
77 interface Study;
78 interface StudyBuilder;
79 interface SObject;
80 interface SComponent;
81 interface SComponentIterator;
82 interface ChildIterator;
83 interface Driver;
85 interface AttributeParameter;
86 interface UseCaseIterator;
87 interface UseCaseBuilder;
88
89 interface Observer
90 {
91 oneway void notifyObserverID(in string theID, in long event);
92 };
93
94
96 typedef sequence<GenericAttribute> ListOfAttributes;
97
99 exception NotImplemented {};
100
101 //==========================================================================
112 //==========================================================================
113
114 interface StudyBuilder
115 {
120 exception LockProtection {};
129 SComponent NewComponent(in string ComponentDataType) raises(LockProtection);
130
135 void DefineComponentInstance (in SComponent aComponent,in Object ComponentIOR) raises(LockProtection);
136
141 void RemoveComponent(in SComponent aComponent) raises(LockProtection);
142
154 SObject NewObject (in SObject theFatherObject) raises(LockProtection);
155
164 SObject NewObjectToTag (in SObject theFatherObject, in long atag) raises(LockProtection);
171 void RemoveObject (in SObject anObject) raises(LockProtection);
179
186 void LoadWith (in SComponent sco, in Driver Engine) raises (SALOME::SALOME_Exception);
192 void Load (in SObject sco);
193
204 in string aTypeOfAttribute) raises(LockProtection);
205
215 boolean FindAttribute(in SObject anObject,
216 out GenericAttribute anAttribute,
217 in string aTypeOfAttribute);
226 void RemoveAttribute(in SObject anObject,
227 in string aTypeOfAttribute) raises(LockProtection);
234 void Addreference(in SObject anObject,
235 in SObject theReferencedObject) ;
236
242 void RemoveReference(in SObject anObject) ;
243
252 void SetGUID(in SObject anObject, in string theGUID) raises(LockProtection);
259 boolean IsGUID(in SObject anObject, in string theGUID);
260
268 void NewCommand(); // command management
278 void CommitCommand() raises(LockProtection); // command management
282 boolean HasOpenCommand();
289 void AbortCommand(); // command management
294 attribute long UndoLimit;
304 void Undo() raises (LockProtection);
314 void Redo() raises (LockProtection);
321 boolean GetAvailableUndos();
328 boolean GetAvailableRedos();
335 void SetName(in SObject theSO, in string theValue) raises (LockProtection);
336
343 void SetComment(in SObject theSO, in string theValue) raises (LockProtection);
344
351 void SetIOR(in SObject theSO, in string theValue) raises (LockProtection);
352 };
353
354 //===========================================================================
370 interface Study
371 {
372
384 exception StudyNameError {};
386 exception StudyCommentError {};
387
391 void ping();
392 void Shutdown();
396 long getPID();
397
401 oneway void ShutdownWithExit();
402
407 attribute wstring Name; // equivalent to getName()
408
413 typedef sequence<SObject> ListOfSObject;
416
421 boolean IsEmpty() raises(StudyInvalidReference);
430 SComponent FindComponent (in string aComponentName) raises(StudyInvalidReference);
431
434 SComponent FindComponentID(in ID aComponentID) raises(StudyInvalidReference);
442 SObject FindObject (in string anObjectName) raises(StudyInvalidReference);
448 SObject FindObjectID (in ID aObjectID) raises(StudyInvalidReference);
454 SObject CreateObjectID (in ID aObjectID) raises(StudyInvalidReference);
460 SObject FindObjectIOR (in ID aObjectIOR) raises(StudyInvalidReference);
466 ListOfSObject FindObjectByName(in string anObjectName, in string aComponentName) raises(StudyInvalidReference);
472 SObject FindObjectByPath(in string thePath) raises(StudyInvalidReference);
475 string GetObjectPath(in Object theObject) raises(StudyInvalidReference);
476
482 ChildIterator NewChildIterator(in SObject aSO) raises(StudyInvalidReference);
483
488 SComponentIterator NewComponentIterator() raises(StudyInvalidReference);
489
501 void UpdateIORLabelMap(in string anIOR, in string anEntry) raises(StudyInvalidReference);
502
513 attribute boolean IsSaved;
518 boolean IsModified() raises(StudyInvalidReference);
519
522 void Modified() raises(StudyInvalidReference);
523
526 attribute wstring URL;
527
532 ListOfSObject FindDependances(in SObject anObject) raises(StudyInvalidReference);
533
538 string GetLastModificationDate() raises(StudyInvalidReference);
544 ListOfDates GetModificationsDate() raises(StudyInvalidReference);
550 string ConvertObjectToIOR(in Object theObject);
556 Object ConvertIORToObject(in string theIOR);
557
560 UseCaseBuilder GetUseCaseBuilder() raises(StudyInvalidReference);
561
564 void Clear() raises(StudyInvalidReference);
565
569
575 boolean Open (in URLPath aStudyUrl) raises (SALOME::SALOME_Exception);
576
582 boolean CanOpen (in URLPath aStudyUrl);
583
590 boolean Save(in boolean theMultiFile, in boolean theASCII) raises(StudyInvalidReference);
591
601 boolean SaveAs(in URLPath aUrl, // if the file already exists
602 in boolean theMultiFile, // overwrite (as option)
603 in boolean theASCII)
604 raises(StudyInvalidReference);
608 boolean CanCopy(in SObject theObject) raises(StudyInvalidReference);
613 boolean Copy(in SObject theObject) raises(StudyInvalidReference);
618 boolean CanPaste(in SObject theObject) raises(StudyInvalidReference);
625 SObject Paste(in SObject theObject) raises (SALOMEDS::StudyBuilder::LockProtection);
626
629 void EnableUseCaseAutoFilling(in boolean isEnabled) raises(StudyInvalidReference);
630
634 void AddPostponed(in string theIOR) raises(StudyInvalidReference);
635
636 void AddCreatedPostponed(in string theIOR) raises(StudyInvalidReference);
637
638 void RemovePostponed(in long theUndoLimit) raises(StudyInvalidReference);
639
640 void UndoPostponed(in long theWay) raises(StudyInvalidReference);
641
642 boolean DumpStudy(in string thePath,
643 in string theBaseName,
644 in boolean isPublished,
645 in boolean isMultiFile) raises(StudyInvalidReference);
646
649 string GetDumpPath();
650
656 AttributeParameter GetCommonParameters(in string theID, in long theSavePoint) raises(StudyInvalidReference);
657
664 AttributeParameter GetModuleParameters(in string theID, in string theModuleName, in long theSavePoint) raises(StudyInvalidReference);
665
666
672 string GetDefaultScript(in string theModuleName, in string indent) raises(StudyInvalidReference);
673
680 long long GetLocalImpl(in string theHostname, in long thePID, out boolean isLocal);
681
682
688 void SetStudyLock(in string theLockerID) raises(StudyInvalidReference);
689
694 boolean IsStudyLocked() raises(StudyInvalidReference);
695
701 void UnLockStudy(in string theLockerID) raises(StudyInvalidReference);
702
706
713 void SetReal( in string theVarName, in double theValue ) raises(StudyInvalidReference);
714
721 void SetInteger( in string theVarName, in long theValue ) raises(StudyInvalidReference);
728 void SetBoolean( in string theVarName, in boolean theValue ) raises(StudyInvalidReference);
729
736 void SetString( in string theVarName, in string theValue ) raises(StudyInvalidReference);
737
740 void SetStringAsDouble( in string theVarName, in double theValue ) raises(StudyInvalidReference);
741
746 double GetReal( in string theVarName ) raises(StudyInvalidReference);
747
752 long GetInteger( in string theVarName ) raises(StudyInvalidReference);
753
758 boolean GetBoolean( in string theVarName ) raises(StudyInvalidReference);
759
764 string GetString( in string theVarName ) raises(StudyInvalidReference);
765
766
772 boolean IsReal( in string theVarName ) raises(StudyInvalidReference);
773
779 boolean IsInteger( in string theVarName ) raises(StudyInvalidReference);
780
786 boolean IsBoolean( in string theVarName ) raises(StudyInvalidReference);
787
793 boolean IsString( in string theVarName ) raises(StudyInvalidReference);
794
801 boolean IsVariable( in string theVarName ) raises(StudyInvalidReference);
802
805 ListOfStrings GetVariableNames() raises(StudyInvalidReference);
806
814 boolean RemoveVariable( in string theVarName ) raises(StudyInvalidReference);
815
824 boolean RenameVariable( in string theVarName, in string theNewVarName ) raises(StudyInvalidReference);
825
833 boolean IsVariableUsed( in string theVarName ) raises(StudyInvalidReference);
834
840 ListOfListOfStrings ParseVariables( in string theVars ) raises(StudyInvalidReference);
841
849 void attach(in SALOMEDS::Observer theObserver, in boolean modify);
855 void detach(in SALOMEDS::Observer theObserver);
856 };
857
858 //==========================================================================
870 //==========================================================================
871
872 interface SObject : SALOME::GenericObj
873 {
876 attribute string Name; // equivalent to setName() & getName()
877
880 boolean IsNull();
881
886
891
896
900 short Tag();
901
906
910 short Depth();
911
916 boolean FindSubObject (in long atag, out SObject obj);
917
924 boolean FindAttribute(out GenericAttribute anAttribute,
925 in string aTypeOfAttribute);
926
931 boolean ReferencedObject(out SObject obj); // A REVOIR
932
940
945 Object GetObject();
946
951 string GetName();
952
957 string GetComment();
958
963 string GetIOR();
964
970 void SetAttrString(in string name, in string value);
971
978 long long GetLocalImpl(in string theHostname, in long thePID, out boolean isLocal);
979 };
980
981
982 //==========================================================================
987 //==========================================================================
989 {
994 exception LockProtection {};
1002
1004 string Type();
1005
1007 string GetClassType();
1008
1010 SObject GetSObject();
1011
1013
1018 long long GetLocalImpl(in string theHostname, in long thePID, out boolean isLocal);
1019 };
1020
1021
1022
1023 //==========================================================================
1030 //==========================================================================
1032 {
1042 boolean ComponentIOR (out ID theID); //returns True if there is an instance
1043 //In this case ID identifies this one
1044 };
1045
1046
1047 //==========================================================================
1053 //==========================================================================
1055 {
1059 void Init();
1064 boolean More();
1068 void Next();
1076 };
1077
1078 //==========================================================================
1084 //==========================================================================
1086 {
1091 void Init();
1098 void InitEx(in boolean allLevels);
1103 boolean More();
1107 void Next();
1112 };
1113
1114 //==========================================================================
1115 //==========================================================================
1121 {
1126 void Init(in boolean allLevels);
1131 boolean More();
1135 void Next();
1140 };
1141
1142 //==========================================================================
1143 //==========================================================================
1150 {
1157 boolean Append(in SObject theObject);
1164 boolean Remove(in SObject theObject);
1168 boolean AppendTo(in SObject theFather, in SObject theObject);
1172 long GetIndexInFather(in SObject theFather, in SObject theObject);
1176 boolean InsertBefore(in SObject theFirst, in SObject theNext);
1180 boolean SetCurrentObject(in SObject theObject);
1188 boolean HasChildren(in SObject theObject);
1192 boolean SortChildren(in SObject theObject, in boolean theAscendingOrder);
1200 boolean SetName(in string theName);
1204 string GetName();
1208 boolean IsUseCase(in SObject theObject);
1212 boolean IsUseCaseNode(in SObject theObject);
1220 SObject AddUseCase(in string theName);
1225 };
1226 //==========================================================================
1239 //==========================================================================
1240 interface Driver
1241 {
1242
1256 TMPFile Save(in SComponent theComponent, in string theURL, in boolean isMultiFile);
1257
1269 TMPFile SaveASCII(in SComponent theComponent, in string theURL, in boolean isMultiFile);
1270
1280 boolean Load(in SComponent theComponent, in TMPFile theStream, in string theURL, in boolean isMultiFile);
1281
1291 boolean LoadASCII(in SComponent theComponent, in TMPFile theStream, in string theURL, in boolean isMultiFile);
1292
1299 void Close (in SComponent aSComponent);
1300 //void Close ( in string aIORSComponent);
1301
1308
1309 // Driver Transient -> persistent called for each object in study
1324 string IORToLocalPersistentID (in SObject theSObject,
1325 in string IORString,
1326 in boolean isMultiFile,
1327 in boolean isASCII);
1343 string LocalPersistentIDToIOR (in SObject theSObject,
1344 in string aLocalPersistentID,
1345 in boolean isMultiFile,
1346 in boolean isASCII)
1347 raises (SALOME::SALOME_Exception);
1348
1349 // Publishing in the study
1355 boolean CanPublishInStudy(in Object theIOR) raises (SALOME::SALOME_Exception);
1367 SObject PublishInStudy(in SObject theSObject, in Object theObject, in string theName);
1368
1369 // copy/paste methods
1370
1376 boolean CanCopy(in SObject theObject);
1380 TMPFile CopyFrom(in SObject theObject, out long theObjectID);
1384 boolean CanPaste(in string theComponentName, in long theObjectID);
1388 SObject PasteInto(in TMPFile theStream, in long theObjectID, in SObject theObject);
1389
1390 };
1391};
1392
1393#endif
static std::ostream * out
Definition: DSC_interface.cxx:381
static void DumpStudy()
Function : Purpose :
Definition: SALOMEDS_Client.cxx:72
This file contains the objects defining the main exception used in SALOME application.
interface for common behavior of SALOME transient CORBA objects
Definition: SALOMEDSImpl_Attributes.hxx:34
Exception locking all changes.
Definition: SALOMEDS.idl:994
Exception indicating that this feature hasn't been implemented in SALOME application.
LockProtection Exception
Definition: SALOMEDS.idl:120
Invalid study comment.
Definition: SALOMEDS.idl:386
Invalid study component.
Definition: SALOMEDS.idl:376
Invalid directory of the study exception.
Definition: SALOMEDS.idl:378
Invalid study reference.
Definition: SALOMEDS.idl:374
Exception pointing that this name of the study has already been used.
Definition: SALOMEDS.idl:380
Invalid name of the study exception.
Definition: SALOMEDS.idl:384
study object already exists
Definition: SALOMEDS.idl:382
Parameter attribute.
Definition: SALOMEDS_Attributes.idl:1717
Study properties attribute
Definition: SALOMEDS_Attributes.idl:1535
ChildIterator interface
Definition: SALOMEDS.idl:1086
void Init()
Activates the ChildIterator.
Activates the ChildIterator for all child levels.
void Next()
Passes the iterator to the next level.
SObject Value()
Returns the SObject corresponding to the current object found by the iterator.
boolean More()
Method More.
Driver interface
Definition: SALOMEDS.idl:1241
string IORToLocalPersistentID(in SObject theSObject, in string IORString, in boolean isMultiFile, in boolean isASCII)
Transforms IOR of a given SObject into PersistentID.
Loading the data.
void Close(in SComponent aSComponent)
Closing of the study.
string LocalPersistentIDToIOR(in SObject theSObject, in string aLocalPersistentID, in boolean isMultiFile, in boolean isASCII)
Transforms PersistentID into IOR of the object.
Saving the data in ASCII format produced by a definite component.
Returns the object ID and the TMPFile of the object from the given SObject.
Publishing in the study.
Returns True, if the component can paste the object with given ID of the component with name theCompo...
Saving the data produced by a definite component.
Loading the data from files in ASCII format.
string ComponentDataType()
Gets the type of the data.
Returns True, if the given SObject can be copied to the clipboard.
Returns the SObject of the pasted object.
Generic attribute interface
Definition: SALOMEDS.idl:989
void CheckLocked()
Method CheckLocked.
Definition: SALOMEDS.idl:90
SComponentIterator interface
Definition: SALOMEDS.idl:1055
void Next()
Moves the iterator to the next SComponent in the list.
boolean More()
Method More.
void Init()
Activates the SComponentIterator.
SComponent interface
Definition: SALOMEDS.idl:1032
Gets the data type of the given SComponent.
boolean ComponentIOR(out ID theID)
Gets the IOR of the given component.
SObject interface
Definition: SALOMEDS.idl:873
SObject GetFather()
Acquisition of the father SObject of the SObject.
Object GetObject()
Gets the CORBA object by its own IOR attribute.
string GetName()
Returns the name attribute value of this SObject.
boolean FindSubObject(in long atag, out SObject obj)
Looks for subobjects of a given SObject.
boolean FindAttribute(out GenericAttribute anAttribute, in string aTypeOfAttribute)
Looks for attributes of a given SObject.
ID GetID()
Gets an object ID.
string GetComment()
Returns the comment attribute value of this SObject.
Name of the SObject.
Definition: SALOMEDS.idl:876
short Tag()
Gets the tag of a SObject.
SComponent GetFatherComponent()
Acquisition of the father Component of the SObject.
short Depth()
Gets the depth of a SObject.
string GetIOR()
Returns the IOR attribute value of this SObject.
boolean IsNull()
Returns true if the SObject does not belong to any Study.
Private method, returns an implementation of this SObject.
ListOfAttributes GetAllAttributes()
Gets all attributes of a given SObject.
Looks for a SObject which the given SObject refers to.
short GetLastChildTag()
Returns a tag of the last child SObject (if any) of this SObject.
Set an attribute value (of type string)
Study Builder Interface
Definition: SALOMEDS.idl:115
void NewCommand()
Creation of a new command.
Deletion of a SComponent.
Removes a reference from anObject to another object.
GenericAttribute FindOrCreateAttribute(in SObject anObject, in string aTypeOfAttribute)
Looking for or creating an attribute assigned to the SObject.
Execution of the command.
void DefineComponentInstance(in SComponent aComponent, in Object ComponentIOR)
Definition of the instance to the SComponent.
void RemoveObjectWithChildren(in SObject anObject)
Deletion of the SObject with all his child objects.
SObject NewObject(in SObject theFatherObject)
Creation of a new SObject.
void RemoveAttribute(in SObject anObject, in string aTypeOfAttribute)
Deleting the attribute assigned to the SObject.
Creation of a new SComponent.
void LoadWith(in SComponent sco, in Driver Engine)
Loads a SComponent.
void RemoveObject(in SObject anObject)
Deletion of the SObject.
Searches for a definite SObject with a definite GUID and returns True if it finds it.
SObject NewObjectToTag(in SObject theFatherObject, in long atag)
Creation of a new SObject with a definite tag.
void Load(in SObject sco)
Loads a SObject.
void Addreference(in SObject anObject, in SObject theReferencedObject)
Adds a reference between anObject and theReferencedObject.
Identification of the SObject's substructure.
boolean FindAttribute(in SObject anObject, out GenericAttribute anAttribute, in string aTypeOfAttribute)
Looking for an attribute assigned to a SObject.
Study Interface
Definition: SALOMEDS.idl:371
Shutdown the Study process.
long getPID()
Returns the PID of the server.
sequence< SObject > ListOfSObject
Indicate the file where the study has been saved.
Definition: SALOMEDS.idl:413
PersistentReference GetPersistentReference()
Get the persistent reference to the Study.
void ping()
Determines whether the server has already been loaded or not.
The name of the Study.
Definition: SALOMEDS.idl:407
Interface of the UseCaseBuilder.
Definition: SALOMEDS.idl:1150
Returns True if the given object theObject is included in the use cases tree on any level.
string GetName()
Gets the name of the use case.
Inserts in the use case the object theFirst before the object theNext.
Adds to the use case an object as a child of the current object of the use case.
Returns True if the given object theObject represents a use case.
UseCaseIterator GetUseCaseIterator(in SObject theObject)
Returns the UseCaseIterator for the given object theObject in the use case.
SObject GetFather(in SObject theObject)
Gets father object of the given object theObject in the use cases tree.
Removes an object from the use case.
boolean SetRootCurrent()
Makes the root object to be the current object of the use case.
Returns True if children of the given object theObject of the use case tree were sorted successfully.
Return index of a child among father children.
Sets the name of the use case.
Adds a child object theObject to the given father theFather object in the use case.
SObject GetCurrentObject()
Gets the current object of the use case.
Creates a new use case in the use case browser.
Sets the current object of the use case.
Returns True if the given object theObject of the use case has child objects.
Interface of the UseCaseIterator.
Definition: SALOMEDS.idl:1121
SObject Value()
Returns the SObject corresponding to the current object found by the Iterator.
void Next()
Passes the iterator to the next object.
Activates the UseCaseIterator.
boolean More()
Method More.
Definition: SALOME_GenericObj.idl:40
obj
Definition: batchmode_salome.py:275
def SetName(objId, name)
Definition: salome_ComponentGUI.py:89
def Init()
Definition: salome_ComponentGUI.py:84
This package contains the interfaces used for creation, management and modification of the Study.
Definition: SALOMEDS.hxx:37
sequence< string > ListOfFileNames
List of file names.
Definition: SALOMEDS.idl:59
sequence< string > ListOfDates
List of modification dates of a study.
Definition: SALOMEDS.idl:61
sequence< octet > TMPFile
A byte stream which is used for binary data transfer between different components.
Definition: SALOMEDS.idl:67
sequence< ListOfStrings > ListOfListOfStrings
An unbounded sequence of sequence of strings.
Definition: SALOMEDS.idl:65
wstring URLPath
Name of the file in which the Study is saved.
Definition: SALOMEDS.idl:44
IOR of the study in SALOME application.
Definition: SALOMEDS.idl:56
string ID
Main identifier of an object in SALOME application.
Definition: SALOMEDS.idl:48
While saving the data, IOR is transformed into persistent reference.
Definition: SALOMEDS.idl:52
sequence< string > ListOfStrings
An unbounded sequence of strings.
Definition: SALOMEDS.idl:63
sequence< GenericAttribute > ListOfAttributes
List of attributes of SObjects.
Definition: SALOMEDS.idl:96
string name
Definition: pythfilter.py:56
