SALOMEDS::Study Interface Reference
Study Interface More...
import"SALOMEDS.idl";
exception  StudyCommentError
 Invalid study comment. More...
exception  StudyInvalidComponent
 Invalid study component. More...
exception  StudyInvalidDirectory
 Invalid directory of the study exception. More...
exception  StudyInvalidReference
 Invalid study reference. More...
exception  StudyNameAlreadyUsed
 Exception pointing that this name of the study has already been used. More...
exception  StudyNameError
 Invalid name of the study exception. More...
exception  StudyObjectAlreadyExists
 study object already exists More...
typedef sequence< SObject > ListOfSObject
 Indicate the file where the study has been saved. More...
void ping ()
 Determines whether the server has already been loaded or not. More...
void Shutdown ()
long getPID ()
 Returns the PID of the server. More...
oneway void ShutdownWithExit ()
 Shutdown the Study process. More...
PersistentReference GetPersistentReference () raises (StudyInvalidReference)
 Get the persistent reference to the Study. More...
boolean IsEmpty () raises (StudyInvalidReference)
 indicate whether the Study is empty More...
SComponent FindComponent (in string aComponentName) raises (StudyInvalidReference)
 Find a SComponent by its name. More...
SComponent FindComponentID (in ID aComponentID) raises (StudyInvalidReference)
 Find a SComponent by ID of the according SObject. More...
SObject FindObject (in string anObjectName) raises (StudyInvalidReference)
 Find a SObject by the Name Attribute of this SObject. More...
SObject FindObjectID (in ID aObjectID) raises (StudyInvalidReference)
 Find a SObject by its ID. More...
SObject CreateObjectID (in ID aObjectID) raises (StudyInvalidReference)
 Create a SObject by its ID. More...
SObject FindObjectIOR (in ID aObjectIOR) raises (StudyInvalidReference)
 Find a SObject by IOR of the object belonging to this SObject. More...
ListOfSObject FindObjectByName (in string anObjectName, in string aComponentName) raises (StudyInvalidReference)
 Find in the study all SObjects produced by a given Component. More...
SObject FindObjectByPath (in string thePath) raises (StudyInvalidReference)
 Find a SObject by the path to it. More...
string GetObjectPath (in Object theObject) raises (StudyInvalidReference)
 Get the path to the SObject. More...
ChildIterator NewChildIterator (in SObject aSO) raises (StudyInvalidReference)
 Create a new iterator of child levels of the given SObject. More...
SComponentIterator NewComponentIterator () raises (StudyInvalidReference)
 Create a new iterator of the SComponents. More...
StudyBuilder NewBuilder () raises (StudyInvalidReference)
 Create a new StudyBuilder to add or modify an object in the study. More...
void UpdateIORLabelMap (in string anIOR, in string anEntry) raises (StudyInvalidReference)
 Labels dependency. More...
AttributeStudyProperties GetProperties () raises (StudyInvalidReference)
 Getting properties of the study. More...
boolean IsModified () raises (StudyInvalidReference)
 Indicate whether the study has been modified and not saved. More...
void Modified () raises (StudyInvalidReference)
 Mark the study as being modified and not saved. More...
ListOfSObject FindDependances (in SObject anObject) raises (StudyInvalidReference)
 List of SObjects. More...
string GetLastModificationDate () raises (StudyInvalidReference)
 The date of the last saving of the study. More...
ListOfDates GetModificationsDate () raises (StudyInvalidReference)
 The list of modification dates of the study. More...
string ConvertObjectToIOR (in Object theObject)
 Object conversion. More...
Object ConvertIORToObject (in string theIOR)
UseCaseBuilder GetUseCaseBuilder () raises (StudyInvalidReference)
 Get a new UseCaseBuilder. More...
void Clear () raises (StudyInvalidReference)
 Clear a study object. More...
void Init () raises (StudyInvalidReference)
 Initialization a study object. More...
boolean Open (in URLPath aStudyUrl) raises (SALOME::SALOME_Exception)
 Open a study by url. More...
boolean CanOpen (in URLPath aStudyUrl)
 Check if study can be opened. More...
boolean Save (in boolean theMultiFile, in boolean theASCII) raises (StudyInvalidReference)
 Saving the study in a file (or files). More...
boolean SaveAs (in URLPath aUrl, in boolean theMultiFile, in boolean theASCII) raises (StudyInvalidReference)
 Saving the study in a specified file (or files). More...
boolean CanCopy (in SObject theObject) raises (StudyInvalidReference)
 Returns True, if the given SObject can be copied to the clipboard. More...
boolean Copy (in SObject theObject) raises (StudyInvalidReference)
 Returns True, if the given SObject is copied to the clipboard. More...
boolean CanPaste (in SObject theObject) raises (StudyInvalidReference)
 Returns True, if the object from the clipboard can be pasted to the given SObject. More...
SObject Paste (in SObject theObject) raises (SALOMEDS::StudyBuilder::LockProtection)
 Returns the SObject in which the object from the clipboard was pasted to. More...
void EnableUseCaseAutoFilling (in boolean isEnabled) raises (StudyInvalidReference)
 Enable (if isEnabled = True)/disable automatic addition of new SObjects to the use case. More...
void AddPostponed (in string theIOR) raises (StudyInvalidReference)
 Functions for internal usage only. More...
void AddCreatedPostponed (in string theIOR) raises (StudyInvalidReference)
void RemovePostponed (in long theUndoLimit) raises (StudyInvalidReference)
void UndoPostponed (in long theWay) raises (StudyInvalidReference)
boolean DumpStudy (in string thePath, in string theBaseName, in boolean isPublished, in boolean isMultiFile) raises (StudyInvalidReference)
string GetDumpPath ()
 Returns the folder of the python script which is currently dumped. More...
AttributeParameter GetCommonParameters (in string theID, in long theSavePoint) raises (StudyInvalidReference)
 Get an AttributeParameter used to store common parameters for given theSavePoint. More...
AttributeParameter GetModuleParameters (in string theID, in string theModuleName, in long theSavePoint) raises (StudyInvalidReference)
 Get an AttributeParameter used to store parameters for given theModuleName. More...
string GetDefaultScript (in string theModuleName, in string indent) raises (StudyInvalidReference)
 Get a default Python script to restore visual parameters for given theModuleName. More...
 Private method, returns an implementation of this Study. More...
void SetStudyLock (in string theLockerID) raises (StudyInvalidReference)
 Mark this Study as being locked by the given locker. More...
boolean IsStudyLocked () raises (StudyInvalidReference)
 Indicate if the Study is locked. More...
void UnLockStudy (in string theLockerID) raises (StudyInvalidReference)
 Mark this Study as being unlocked by the given locker. More...
ListOfStrings GetLockerID () raises (StudyInvalidReference)
 Get the list of IDs of the Study's lockers. More...
void SetReal (in string theVarName, in double theValue) raises (StudyInvalidReference)
 Create real variable with Name theVarName and value theValue. More...
void SetInteger (in string theVarName, in long theValue) raises (StudyInvalidReference)
 Create integer variable with Name theVarName and value theValue. More...
void SetBoolean (in string theVarName, in boolean theValue) raises (StudyInvalidReference)
 Create boolean variable with Name theVarName and value theValue. More...
void SetString (in string theVarName, in string theValue) raises (StudyInvalidReference)
 Create string variable with Name theVarName and value theValue. More...
void SetStringAsDouble (in string theVarName, in double theValue) raises (StudyInvalidReference)
 Set current value as double for string variable. More...
double GetReal (in string theVarName) raises (StudyInvalidReference)
 Get value of a real variable. More...
long GetInteger (in string theVarName) raises (StudyInvalidReference)
 Get value of an integer variable. More...
boolean GetBoolean (in string theVarName) raises (StudyInvalidReference)
 Get value of a boolean variable. More...
string GetString (in string theVarName) raises (StudyInvalidReference)
 Get value of a string variable. More...
boolean IsReal (in string theVarName) raises (StudyInvalidReference)
 Indicate if a variable is real. More...
boolean IsInteger (in string theVarName) raises (StudyInvalidReference)
 Indicate if a variable is integer. More...
boolean IsBoolean (in string theVarName) raises (StudyInvalidReference)
 Indicate if a variable is boolean. More...
boolean IsString (in string theVarName) raises (StudyInvalidReference)
 Indicate if a variable is string. More...
boolean IsVariable (in string theVarName) raises (StudyInvalidReference)
 Indicate if a variable exists in the study. More...
ListOfStrings GetVariableNames () raises (StudyInvalidReference)
 Get names of all variables from the study. More...
boolean RemoveVariable (in string theVarName) raises (StudyInvalidReference)
 Remove a variable. More...
boolean RenameVariable (in string theVarName, in string theNewVarName) raises (StudyInvalidReference)
 Rename a variable. More...
boolean IsVariableUsed (in string theVarName) raises (StudyInvalidReference)
 Indicate whether variable is used. More...
ListOfListOfStrings ParseVariables (in string theVars) raises (StudyInvalidReference)
 Parse variables used for object creation. More...
void attach (in SALOMEDS::Observer theObserver, in boolean modify)
 Attach an observer to the Study. More...
void detach (in SALOMEDS::Observer theObserver)
 Detach an observer from the Study. More...
Data Fields
attribute wstring Name
 The name of the Study. More...
attribute boolean IsSaved
 Indicate whether the study has been saved. More...
attribute wstring URL
Study Interface
The purpose of the Study is to manage the data produced by various components of SALOME platform. Most of the Study operations are handled by the StudyBuilder. What is left in the Study interface are elementary inquiries. (Incidentally, we recall that a CORBA attribute is implemented as a pair of get and set methods.) A Study is explored by a set of tools, mainly iterators , which are described further. Nevertheless, the Study interface allows the search of an object by name or by ID.
The Path of an object in SALOME application is much alike a standard path of a file. In general it's a string of names of directories divided by a slash '/'.
The Context is the current directory of an object.
◆ ListOfSObject
Sequence containing SObjects
◆ AddCreatedPostponed()
void SALOMEDS::Study::AddCreatedPostponed ( in string  theIOR)
◆ AddPostponed()
void SALOMEDS::Study::AddPostponed ( in string  theIOR)
◆ attach()
void SALOMEDS::Study::attach ( in SALOMEDS::Observer  theObserver,
in boolean  modify
theObserverobserver being attached
modifywhen true, observer receives any object's modification events; otherwise observer receives object's creation events only
◆ CanCopy()
boolean SALOMEDS::Study::CanCopy ( in SObject  theObject)
◆ CanOpen()
boolean SALOMEDS::Study::CanOpen ( in URLPath  aStudyUrl)
Tries to open and read given url.
aStudyUrlThe path to the study
◆ CanPaste()
boolean SALOMEDS::Study::CanPaste ( in SObject  theObject)
theObjectThe SObject stored in the clipboard.
◆ Clear()
void SALOMEDS::Study::Clear ( )
◆ ConvertIORToObject()
Object SALOMEDS::Study::ConvertIORToObject ( in string  theIOR)
Object conversion.
Converts IOR into an object.
An object
◆ ConvertObjectToIOR()
string SALOMEDS::Study::ConvertObjectToIOR ( in Object  theObject)
Object conversion.
Converts an object into IOR.
IOR
◆ Copy()
boolean SALOMEDS::Study::Copy ( in SObject  theObject)
theObjectThe SObject which will be copied
◆ CreateObjectID()
SObject SALOMEDS::Study::CreateObjectID ( in ID  aObjectID)
aObjectIDThis parameter defines the ID of the required object
The created SObject
◆ detach()
void SALOMEDS::Study::detach ( in SALOMEDS::Observer  theObserver)
theObserverobserver to be detached
◆ DumpStudy()
boolean SALOMEDS::Study::DumpStudy ( in string  thePath,
◆ EnableUseCaseAutoFilling()
void SALOMEDS::Study::EnableUseCaseAutoFilling ( in boolean  isEnabled)
◆ FindComponent()
SComponent SALOMEDS::Study::FindComponent ( in string  aComponentName)
aComponentNameIt's a string value in the Comment Attribute of the Component, which is looked for, defining the data type of this Component.
See example1 for an example of this method usage in batchmode of SALOME application.
◆ FindComponentID()
SComponent SALOMEDS::Study::FindComponentID ( in ID  aComponentID)
◆ FindDependances()
ListOfSObject SALOMEDS::Study::FindDependances ( in SObject  anObject)
List of SObjects.
Returns the list of SObjects which refers to anObject.
◆ FindObject()
SObject SALOMEDS::Study::FindObject ( in string  anObjectName)
anObjectNameString parameter defining the name of the object
The obtained SObject
See example19 for an example of this method usage in batchmode of SALOME application.
◆ FindObjectByName()
ListOfSObject SALOMEDS::Study::FindObjectByName ( in string  anObjectName,
anObjectNameThe Name Attribute of the searched SObjects should correspond to anObjectName.
aComponentNameThe name of the component, which objects are searched for.
◆ FindObjectByPath()
SObject SALOMEDS::Study::FindObjectByPath ( in string  thePath)
thePathThe path to the required SObject.
The obtained SObject.
◆ FindObjectID()
SObject SALOMEDS::Study::FindObjectID ( in ID  aObjectID)
◆ FindObjectIOR()
SObject SALOMEDS::Study::FindObjectIOR ( in ID  aObjectIOR)
anObjectNameThis parameter defines the IOR of the object
◆ GetBoolean()
boolean SALOMEDS::Study::GetBoolean ( in string  theVarName)
theVarNameis a name of the variable.
◆ GetCommonParameters()
AttributeParameter SALOMEDS::Study::GetCommonParameters ( in string  theID,
theIDidentifies a common parameters set (Example: "Interface Applicative")
theSavePointis number of a set of parameters as there can be several sets
◆ GetDefaultScript()
string SALOMEDS::Study::GetDefaultScript ( in string  theModuleName,
in string  indent
theModuleNameis a name of the module (Example: "Geometry")
indentis a string to use for script indentation
◆ GetDumpPath()
string SALOMEDS::Study::GetDumpPath ( )
◆ GetInteger()
long SALOMEDS::Study::GetInteger ( in string  theVarName)
◆ GetLastModificationDate()
string SALOMEDS::Study::GetLastModificationDate ( )
Returns the date of the last saving of study with format: "DD/MM/YYYY HH:MM"
◆ GetLocalImpl()
long long SALOMEDS::Study::GetLocalImpl ( in string  theHostname,
in long  thePID,
out boolean  isLocal
isLocalis set True if the Study is launched locally with the caller
◆ GetLockerID()
ListOfStrings SALOMEDS::Study::GetLockerID ( )
◆ GetModificationsDate()
ListOfDates SALOMEDS::Study::GetModificationsDate ( )
Returns the list of modification dates (without creation date) with format "DD/MM/YYYY HH:MM". Note : the first modification begins the list.
◆ GetModuleParameters()
AttributeParameter SALOMEDS::Study::GetModuleParameters ( in string  theID,
◆ GetObjectPath()
string SALOMEDS::Study::GetObjectPath ( in Object  theObject)
◆ GetPersistentReference()
PersistentReference SALOMEDS::Study::GetPersistentReference ( )
◆ getPID()
long SALOMEDS::Study::getPID ( )
◆ GetProperties()
AttributeStudyProperties SALOMEDS::Study::GetProperties ( )
Returns the attribute, which contains the properties of this study.
See example20 for an example of this method usage in batchmode of SALOME application.
◆ GetReal()
double SALOMEDS::Study::GetReal ( in string  theVarName)
◆ GetString()
string SALOMEDS::Study::GetString ( in string  theVarName)
◆ GetUseCaseBuilder()
UseCaseBuilder SALOMEDS::Study::GetUseCaseBuilder ( )
◆ GetVariableNames()
ListOfStrings SALOMEDS::Study::GetVariableNames ( )
◆ Init()
void SALOMEDS::Study::Init ( )
◆ IsBoolean()
boolean SALOMEDS::Study::IsBoolean ( in string  theVarName)
Return true if variable is boolean otherwise return false.
◆ IsEmpty()
boolean SALOMEDS::Study::IsEmpty ( )
True if the Study is empty
◆ IsInteger()
boolean SALOMEDS::Study::IsInteger ( in string  theVarName)
Return true if variable is integer otherwise return false.
◆ IsModified()
boolean SALOMEDS::Study::IsModified ( )
Returns True if the study has been modified and not saved.
◆ IsReal()
boolean SALOMEDS::Study::IsReal ( in string  theVarName)
Return true if variable is real otherwise return false.
Referenced by KERNEL_PY.salome_notebook.PseudoStudyForNoteBook::IsString().
◆ IsString()
boolean SALOMEDS::Study::IsString ( in string  theVarName)
Return true if variable is string otherwise return false.
◆ IsStudyLocked()
boolean SALOMEDS::Study::IsStudyLocked ( )
Returns True if the Study was marked locked.
◆ IsVariable()
boolean SALOMEDS::Study::IsVariable ( in string  theVarName)
Return true if variable exists in the study, otherwise return false.
◆ IsVariableUsed()
boolean SALOMEDS::Study::IsVariableUsed ( in string  theVarName)
Check that variable is used in the study.
theVarNameName of the variable.
Variable usage.
◆ Modified()
void SALOMEDS::Study::Modified ( )
◆ NewBuilder()
StudyBuilder SALOMEDS::Study::NewBuilder ( )
A new StudyBuilder.
◆ NewChildIterator()
ChildIterator SALOMEDS::Study::NewChildIterator ( in SObject  aSO)
aSOThe given SObject
A new iterator of child levels of the given SObject.
◆ NewComponentIterator()
SComponentIterator SALOMEDS::Study::NewComponentIterator ( )
A new iterator of the SComponents.
◆ Open()
boolean SALOMEDS::Study::Open ( in URLPath  aStudyUrl)
Reads and activates the structure of the study Objects.
◆ ParseVariables()
ListOfListOfStrings SALOMEDS::Study::ParseVariables ( in string  theVars)
stringwith variables, separated by special symbol.
Variables list.
◆ Paste()
SObject SALOMEDS::Study::Paste ( in SObject  theObject)
theObjectThe SObject which will be pasted
Exceptions
SALOMEDS::StudyBuilder::LockProtectionThis exception is raised, when trying to paste an object into a study, which is protected for modifications.
◆ ping()
void SALOMEDS::Study::ping ( )
◆ RemovePostponed()
void SALOMEDS::Study::RemovePostponed ( in long  theUndoLimit)
◆ RemoveVariable()
boolean SALOMEDS::Study::RemoveVariable ( in string  theVarName)
Remove a variable.
Remove variable with the specified name from the study with substitution of its value.
Status of operation.
◆ RenameVariable()
boolean SALOMEDS::Study::RenameVariable ( in string  theVarName,
Rename a variable.
Rename variable with the specified name within the study.
theNewVarNameNew name for the variable.
◆ Save()
boolean SALOMEDS::Study::Save ( in boolean  theMultiFile,
in boolean  theASCII
Saves a study.
theMultiFileIf this parameter is True the study will be saved in several files.
theASCIIIf this parameter is True the study will be saved in ASCII format, otherwise in HDF format.
Referenced by SALOME_DriverPy.SALOME_DriverPy_i::SaveASCII().
◆ SaveAs()
boolean SALOMEDS::Study::SaveAs ( in URLPath  aUrl,
in boolean  theASCII
Saves the study in a specified file (or files).
aUrlThe path to the definite file in which the study will be saved
◆ SetBoolean()
void SALOMEDS::Study::SetBoolean ( in string  theVarName,
in boolean  theValue
(or set if variable value into theValue already exists)
theVarNameis a value of the variable.
◆ SetInteger()
void SALOMEDS::Study::SetInteger ( in string  theVarName,
in long  theValue
◆ SetReal()
void SALOMEDS::Study::SetReal ( in string  theVarName,
in double  theValue
◆ SetString()
void SALOMEDS::Study::SetString ( in string  theVarName,
in string  theValue
◆ SetStringAsDouble()
void SALOMEDS::Study::SetStringAsDouble ( in string  theVarName,
in double  theValue
◆ SetStudyLock()
void SALOMEDS::Study::SetStudyLock ( in string  theLockerID)
The lock status can be checked by method IsStudyLocked
theLockerIDidentifies a locker of the study can be for ex. IOR of the engine that locks the study.
◆ Shutdown()
void SALOMEDS::Study::Shutdown ( )
◆ ShutdownWithExit()
oneway void SALOMEDS::Study::ShutdownWithExit ( )
◆ UndoPostponed()
void SALOMEDS::Study::UndoPostponed ( in long  theWay)
◆ UnLockStudy()
void SALOMEDS::Study::UnLockStudy ( in string  theLockerID)
theLockerIDidentifies a locker of the study can be for ex. IOR of the engine that unlocks the study.
◆ UpdateIORLabelMap()
void SALOMEDS::Study::UpdateIORLabelMap ( in string  anIOR,
in string  anEntry
Labels dependency.
Updates the map with IOR attribute. It's an inner method used for optimization.
◆ IsSaved
attribute boolean SALOMEDS::Study::IsSaved
◆ Name
attribute wstring SALOMEDS::Study::Name
This is equivalent to the methods setName() & getName()
◆ URL
attribute wstring SALOMEDS::Study::URL
