SALOMEDS::UseCaseBuilder Interface Reference
Interface of the UseCaseBuilder. More...
import"SALOMEDS.idl";
Inheritance diagram for SALOMEDS::UseCaseBuilder:
boolean Append (in SObject theObject)
 Adds to the use case an object as a child of the current object of the use case. More...
boolean Remove (in SObject theObject)
 Removes an object from the use case. More...
boolean AppendTo (in SObject theFather, in SObject theObject)
 Adds a child object theObject to the given father theFather object in the use case. More...
long GetIndexInFather (in SObject theFather, in SObject theObject)
 Return index of a child among father children. More...
boolean InsertBefore (in SObject theFirst, in SObject theNext)
 Inserts in the use case the object theFirst before the object theNext. More...
boolean SetCurrentObject (in SObject theObject)
 Sets the current object of the use case. More...
boolean SetRootCurrent ()
 Makes the root object to be the current object of the use case. More...
boolean HasChildren (in SObject theObject)
 Returns True if the given object theObject of the use case has child objects. More...
boolean SortChildren (in SObject theObject, in boolean theAscendingOrder)
 Returns True if children of the given object theObject of the use case tree were sorted successfully. More...
SObject GetFather (in SObject theObject)
 Gets father object of the given object theObject in the use cases tree. More...
boolean SetName (in string theName)
 Sets the name of the use case. More...
string GetName ()
 Gets the name of the use case. More...
boolean IsUseCase (in SObject theObject)
 Returns True if the given object theObject represents a use case. More...
boolean IsUseCaseNode (in SObject theObject)
 Returns True if the given object theObject is included in the use cases tree on any level. More...
SObject GetCurrentObject ()
 Gets the current object of the use case. More...
SObject AddUseCase (in string theName)
 Creates a new use case in the use case browser. More...
UseCaseIterator GetUseCaseIterator (in SObject theObject)
 Returns the UseCaseIterator for the given object theObject in the use case. More...
void Register ()
void UnRegister ()
void Destroy ()
Use case in the study represents a user-managed subtree, containing all or some of the objects which exist in the study. The UseCaseBuilder interface contains a set of methods used for management of the use case in the study.
◆ AddUseCase()
SObject SALOMEDS::UseCaseBuilder::AddUseCase ( in string  theName)
◆ Append()
boolean SALOMEDS::UseCaseBuilder::Append ( in SObject  theObject)
theObjectThe added SObject.
True if this SObject has been added in the use case.
◆ AppendTo()
boolean SALOMEDS::UseCaseBuilder::AppendTo ( in SObject  theFather,
◆ Destroy()
Use UnRegister() instead.
◆ GetCurrentObject()
SObject SALOMEDS::UseCaseBuilder::GetCurrentObject ( )
◆ GetFather()
SObject SALOMEDS::UseCaseBuilder::GetFather ( in SObject  theObject)
◆ GetIndexInFather()
long SALOMEDS::UseCaseBuilder::GetIndexInFather ( in SObject  theFather,
◆ GetName()
string SALOMEDS::UseCaseBuilder::GetName ( )
◆ GetUseCaseIterator()
UseCaseIterator SALOMEDS::UseCaseBuilder::GetUseCaseIterator ( in SObject  theObject)
◆ HasChildren()
boolean SALOMEDS::UseCaseBuilder::HasChildren ( in SObject  theObject)
◆ InsertBefore()
boolean SALOMEDS::UseCaseBuilder::InsertBefore ( in SObject  theFirst,
in SObject  theNext
◆ IsUseCase()
boolean SALOMEDS::UseCaseBuilder::IsUseCase ( in SObject  theObject)
◆ IsUseCaseNode()
boolean SALOMEDS::UseCaseBuilder::IsUseCaseNode ( in SObject  theObject)
◆ Register()
◆ Remove()
boolean SALOMEDS::UseCaseBuilder::Remove ( in SObject  theObject)
theObjectThe deleted SObject
True if this SObject has been deleted from the use case.
◆ SetCurrentObject()
boolean SALOMEDS::UseCaseBuilder::SetCurrentObject ( in SObject  theObject)
◆ SetName()
boolean SALOMEDS::UseCaseBuilder::SetName ( in string  theName)
◆ SetRootCurrent()
boolean SALOMEDS::UseCaseBuilder::SetRootCurrent ( )
◆ SortChildren()
boolean SALOMEDS::UseCaseBuilder::SortChildren ( in SObject  theObject,
◆ UnRegister()
