SALOMEDS::UseCaseIterator Interface Reference
Interface of the UseCaseIterator. More...
import"SALOMEDS.idl";
Inheritance diagram for SALOMEDS::UseCaseIterator:
void Init (in boolean allLevels)
 Activates the UseCaseIterator. More...
boolean More ()
 Method More. More...
void Next ()
 Passes the iterator to the next object. More...
SObject Value ()
 Returns the SObject corresponding to the current object found by the Iterator. More...
void Register ()
void UnRegister ()
void Destroy ()
This interface contains a set of methods used for iteration over the objects in the use case.
◆ Destroy()
Use UnRegister() instead.
◆ Init()
void SALOMEDS::UseCaseIterator::Init ( in boolean  allLevels)
allLevelsIf the value of this parameter is True the Iterator is activated for all subobjects.
◆ More()
boolean SALOMEDS::UseCaseIterator::More ( )
Method More.
True if the UseCaseIterator finds one more object.
◆ Next()
void SALOMEDS::UseCaseIterator::Next ( )
◆ Register()
◆ UnRegister()
◆ Value()
SObject SALOMEDS::UseCaseIterator::Value ( )
