SALOMEDS::ChildIterator Interface Reference
ChildIterator interface More...
import"SALOMEDS.idl";
Inheritance diagram for SALOMEDS::ChildIterator:
void Init ()
 Activates the ChildIterator. More...
void InitEx (in boolean allLevels)
 Activates the ChildIterator for all child levels. More...
boolean More ()
 Method More. More...
void Next ()
 Passes the iterator to the next level. More...
SObject Value ()
 Returns the SObject corresponding to the current object found by the iterator. More...
void Register ()
void UnRegister ()
void Destroy ()
This interface contains methods which allow to iterate over all child levels.
◆ Destroy()
Use UnRegister() instead.
◆ Init()
void SALOMEDS::ChildIterator::Init ( )
◆ InitEx()
void SALOMEDS::ChildIterator::InitEx ( in boolean  allLevels)
allLevelsIf this boolean parameter is True, the ChildIterator will be activated for all child levels.
◆ More()
boolean SALOMEDS::ChildIterator::More ( )
Method More.
True if there is one more ChildIterator in the list.
◆ Next()
void SALOMEDS::ChildIterator::Next ( )
◆ Register()
◆ UnRegister()
◆ Value()
SObject SALOMEDS::ChildIterator::Value ( )
