SALOMEDS::AttributeStudyProperties Interface Reference
Study properties attribute More...
Inheritance diagram for SALOMEDS::AttributeStudyProperties:
void SetUserName (in string author)
 Sets the name of the study author to the attribute. More...
string GetUserName ()
 Returns the name of the study author. More...
void SetCreationDate (in long minute, in long hour, in long day, in long month, in long year)
 Sets creation date of the study. More...
boolean GetCreationDate (out long minute, out long hour, out long day, out long month, out long year)
 Returns creation date of the study. More...
void SetCreationMode (in string mode)
 Sets creation mode of the study. More...
string GetCreationMode ()
 Returns creation mode of the study. More...
void SetModified (in long modified)
 Sets the number of transactions executed after the last saving of the study. More...
boolean IsModified ()
 Check if study has been modified since last saving operation. More...
long GetModified ()
 Returns the number of transactions executed after the last saving of the study. More...
void SetLocked (in boolean lock)
 Lock/unlock the study for modifications. More...
boolean IsLocked ()
 Check if study is locked. More...
void SetModification (in string author, in long minute, in long hour, in long day, in long month, in long year)
 Appends modification record to the list of study modifications. More...
void GetModificationsList (out StringSeq authors, out LongSeq minutes, out LongSeq hours, out LongSeq days, out LongSeq months, out LongSeq years, in boolean withCreator)
 Returns list of all the study modification records. More...
void SetComment (in string comment)
 Sets the comment of the study. More...
string GetComment ()
 Returns comment of the study. More...
void SetUnits (in string units)
 Sets the units of the study. More...
string GetUnits ()
 Returns units of the study. More...
StringSeq GetStoredComponents ()
 Returns list of components which data was stored (after previous sessions) in the study. More...
string GetComponentVersion (in string comp)
 Returns version of component data stored in the study. More...
StringSeq GetComponentVersions (in string comp)
 Returns all versions of component data stored in the study. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
This attribute is used to store study properties: user name, creation date, creation mode, modified flag, locked flag.
See example20 for an example of usage of this attribute in batchmode of SALOME application.
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetComment()
string SALOMEDS::AttributeStudyProperties::GetComment ( )
comment
◆ GetComponentVersion()
string SALOMEDS::AttributeStudyProperties::GetComponentVersion ( in string  comp)
compcomponent name
version of stored component data
◆ GetComponentVersions()
StringSeq SALOMEDS::AttributeStudyProperties::GetComponentVersions ( in string  comp)
compcomponent name
versions of stored component data
◆ GetCreationDate()
boolean SALOMEDS::AttributeStudyProperties::GetCreationDate ( out long  minute,
out long  hour,
out long  day,
out long  month,
out long  year
minuteused to return minutes part of the date (undefined if creation date is not set)
hourused to return hour part of the date (undefined if creation date is not set)
dayused to return day number part of the date (undefined if creation date is not set)
monthused to return month part of the date (undefined if creation date is not set)
yearused to return year part of the date (undefined if creation date is not set)
true if creation date is set or false otherwise
◆ GetCreationMode()
string SALOMEDS::AttributeStudyProperties::GetCreationMode ( )
The following values are allowed for creation mode: "from scratch", "copy from", empty string (if not set).
creation mode description
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetModificationsList()
void SALOMEDS::AttributeStudyProperties::GetModificationsList ( out StringSeq  authors,
out LongSeq  hours,
out LongSeq  days,
out LongSeq  months,
out LongSeq  years,
authorsused to return authors of the modification records
minutesused to return minutes parts of the modification records
hoursused to return hour parts of the modification records
daysused to return day number parts of the modification records
monthsused to return month parts of the modification records
yearsused to return year parts of the modification records
withCreatortrue if creation record should be also added to the resulting list or false otherwise
◆ GetModified()
long SALOMEDS::AttributeStudyProperties::GetModified ( )
transaction count
◆ GetSObject()
Get SObject.
◆ GetStoredComponents()
StringSeq SALOMEDS::AttributeStudyProperties::GetStoredComponents ( )
list of component names
◆ GetUnits()
string SALOMEDS::AttributeStudyProperties::GetUnits ( )
units
◆ GetUserName()
string SALOMEDS::AttributeStudyProperties::GetUserName ( )
study author name (empty string if not set)
◆ IsLocked()
boolean SALOMEDS::AttributeStudyProperties::IsLocked ( )
true if study is locked or false otherwise
◆ IsModified()
boolean SALOMEDS::AttributeStudyProperties::IsModified ( )
true, if the study has been modified and not saved or false otherwise
◆ Register()
◆ SetComment()
void SALOMEDS::AttributeStudyProperties::SetComment ( in string  comment)
commentcomment of the study.
◆ SetCreationDate()
void SALOMEDS::AttributeStudyProperties::SetCreationDate ( in long  minute,
in long  hour,
in long  day,
in long  month,
in long  year
minuteminutes part of the date
hourhour part of the date
dayday number part of the date
monthmonth part of the date
yearyear part of the date
◆ SetCreationMode()
void SALOMEDS::AttributeStudyProperties::SetCreationMode ( in string  mode)
Creation mode must be either "from scratch" or "copy from".
modecreation mode description
◆ SetLocked()
void SALOMEDS::AttributeStudyProperties::SetLocked ( in boolean  lock)
This parameter is not recursive.
If the study is locked, any attempt to modify study contents leads to the raising of the LockProtection exception.
locktrue if study should be locked or false if study should be unlocked
◆ SetModification()
void SALOMEDS::AttributeStudyProperties::SetModification ( in string  author,
in long  minute,
in long  hour,
in long  day,
in long  month,
in long  year
authorauthor of the modification
minuteminutes part of the modification date
hourhour part of the modification date
dayday number part of the modification date
monthmonth part of the modification date
yearyear part of the modification date
◆ SetModified()
void SALOMEDS::AttributeStudyProperties::SetModified ( in long  modified)
modifiedtransaction count
◆ SetUnits()
void SALOMEDS::AttributeStudyProperties::SetUnits ( in string  units)
unitsunits of the study.
◆ SetUserName()
void SALOMEDS::AttributeStudyProperties::SetUserName ( in string  author)
authorstudy author name
◆ Type()
Get Type.
◆ UnRegister()
