SALOMEDS::SComponentIterator Interface Reference
SComponentIterator interface More...
import"SALOMEDS.idl";
Inheritance diagram for SALOMEDS::SComponentIterator:
void Init ()
 Activates the SComponentIterator. More...
boolean More ()
 Method More. More...
void Next ()
 Moves the iterator to the next SComponent in the list. More...
SComponent Value ()
void Register ()
void UnRegister ()
void Destroy ()
This interface contains the methods allowing to iterate over all components in the list. The search is started from the first SComponent in the list.
◆ Destroy()
Use UnRegister() instead.
◆ Init()
void SALOMEDS::SComponentIterator::Init ( )
◆ More()
boolean SALOMEDS::SComponentIterator::More ( )
Method More.
True if there is one more SComponent in the list.
◆ Next()
void SALOMEDS::SComponentIterator::Next ( )
◆ Register()
◆ UnRegister()
◆ Value()
SComponent SALOMEDS::SComponentIterator::Value ( )
\brief Returns the %SComponent corresponding to the current %SComponent found by the iterator.
See example1 for an example of this method usage in batchmode of SALOME application.
