SALOMEDS::AttributeParameter Interface Reference
Parameter attribute. More...
Inheritance diagram for SALOMEDS::AttributeParameter:
exception  InvalidIdentifier
 This exception is raised when an invalid identifier is passed as parameter. More...
void SetInt (in string ID, in long value)
 Associates integer value with the unique identifier. More...
long GetInt (in string ID) raises (InvalidIdentifier)
 Returns integer value associated with the specified identifier. More...
void SetReal (in string ID, in double value)
 Associates real value with the unique identifier. More...
double GetReal (in string ID) raises (InvalidIdentifier)
 Returns real value associated with the specified identifier. More...
void SetString (in string ID, in string value)
 Associates string value with the unique identifier. More...
string GetString (in string ID) raises (InvalidIdentifier)
 Returns string value associated with the specified identifier. More...
void SetBool (in string ID, in boolean value)
 Associates boolean value with the unique identifier. More...
boolean GetBool (in string ID) raises (InvalidIdentifier)
 Returns boolean value associated with the specified identifier. More...
void SetRealArray (in string ID, in DoubleSeq value)
 Associates real array value with the unique identifier. More...
DoubleSeq GetRealArray (in string ID) raises (InvalidIdentifier)
 Returns real array value associated with the specified identifier. More...
void SetIntArray (in string ID, in LongSeq value)
 Associates integer array value with the unique identifier. More...
LongSeq GetIntArray (in string ID) raises (InvalidIdentifier)
 Returns integer array value associated with the specified identifier. More...
void SetStrArray (in string ID, in StringSeq value)
 Associates string array value with the unique identifier. More...
StringSeq GetStrArray (in string ID) raises (InvalidIdentifier)
 Returns string array value associated with the specified identifier. More...
boolean IsSet (in string ID, in long ptype)
 Checks if the value of specified type is set for the identifier. More...
boolean RemoveID (in string ID, in long ptype)
 Removes value of specified type from the named parameter. More...
AttributeParameter GetFather ()
 Returns a father attribute of this attribute. More...
boolean HasFather ()
 Check if this attribute has parent parameter attribute. More...
boolean IsRoot ()
 Check if this attribute is a root (top-level) parameter attribute. More...
void Clear ()
 Clears the content of the attribute. More...
StringSeq GetIDs (in long ptype)
 Returns a sequence of parameters identifiers of the specified type stored in the attribute. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
This attribute is a universal container of arbitrary data of basic types (integer, real, string, array, etc).
Each parameter is identified by the unique name. Only one value of the specific type can be assigned to the parameter, though it is allowed to assign values of different types to the same name.
◆ CheckLocked()
Method CheckLocked.
◆ Clear()
void SALOMEDS::AttributeParameter::Clear ( )
◆ Destroy()
Use UnRegister() instead.
◆ GetBool()
boolean SALOMEDS::AttributeParameter::GetBool ( in string  ID)
Raises an exception if boolean parameter is not set for the specified parameter.
IDparameter name
boolean value assigned to the parameter
◆ GetClassType()
Get the class type.
◆ GetFather()
AttributeParameter SALOMEDS::AttributeParameter::GetFather ( )
father parameter attribute
◆ GetIDs()
StringSeq SALOMEDS::AttributeParameter::GetIDs ( in long  ptype)
ptypeparameter type [0(integer), 1(real), 2(boolean), 3(string), 4(real array), 5(integer array), 6(string array)]
list of parameters identifier
◆ GetInt()
long SALOMEDS::AttributeParameter::GetInt ( in string  ID)
Raises an exception if integer parameter is not set for the specified parameter.
IDparameter name
integer value assigned to the parameter
◆ GetIntArray()
LongSeq SALOMEDS::AttributeParameter::GetIntArray ( in string  ID)
Raises an exception if integer array parameter is not set for the specified parameter.
IDparameter name
integer array value assigned to the parameter
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetReal()
double SALOMEDS::AttributeParameter::GetReal ( in string  ID)
Raises an exception if real parameter is not set for the specified parameter.
IDparameter name
real value assigned to the parameter
◆ GetRealArray()
DoubleSeq SALOMEDS::AttributeParameter::GetRealArray ( in string  ID)
Raises an exception if real array parameter is not set for the specified parameter.
IDparameter name
real array value assigned to the parameter
◆ GetSObject()
Get SObject.
◆ GetStrArray()
StringSeq SALOMEDS::AttributeParameter::GetStrArray ( in string  ID)
Raises an exception if string array parameter is not set for the specified parameter.
IDparameter name
string array value assigned to the parameter
◆ GetString()
string SALOMEDS::AttributeParameter::GetString ( in string  ID)
Raises an exception if string parameter is not set for the specified parameter.
IDparameter name
string value assigned to the parameter
◆ HasFather()
boolean SALOMEDS::AttributeParameter::HasFather ( )
true if this attribute has parent parameter attribute
◆ IsRoot()
boolean SALOMEDS::AttributeParameter::IsRoot ( )
true if this attribute is a root parameter attribute
◆ IsSet()
boolean SALOMEDS::AttributeParameter::IsSet ( in string  ID,
in long  ptype
IDparameter name
true if the value of type ptype is associated with the parameter ID
◆ Register()
◆ RemoveID()
boolean SALOMEDS::AttributeParameter::RemoveID ( in string  ID,
in long  ptype
IDparameter name
true if value is successfully removed or false otherwise
◆ SetBool()
void SALOMEDS::AttributeParameter::SetBool ( in string  ID,
in boolean  value
IDparameter name
valueparameter value
◆ SetInt()
void SALOMEDS::AttributeParameter::SetInt ( in string  ID,
in long  value
IDparameter name
◆ SetIntArray()
void SALOMEDS::AttributeParameter::SetIntArray ( in string  ID,
in LongSeq  value
IDparameter name
◆ SetReal()
void SALOMEDS::AttributeParameter::SetReal ( in string  ID,
in double  value
IDparameter name
◆ SetRealArray()
void SALOMEDS::AttributeParameter::SetRealArray ( in string  ID,
in DoubleSeq  value
IDparameter name
◆ SetStrArray()
void SALOMEDS::AttributeParameter::SetStrArray ( in string  ID,
in StringSeq  value
IDparameter name
◆ SetString()
void SALOMEDS::AttributeParameter::SetString ( in string  ID,
in string  value
IDparameter name
◆ Type()
Get Type.
◆ UnRegister()
