SALOMEDS::StudyBuilder Interface Reference
Study Builder Interface More...
import"SALOMEDS.idl";
exception  LockProtection
 LockProtection Exception More...
SComponent NewComponent (in string ComponentDataType) raises (LockProtection)
 Creation of a new SComponent. More...
void DefineComponentInstance (in SComponent aComponent, in Object ComponentIOR) raises (LockProtection)
 Definition of the instance to the SComponent. More...
void RemoveComponent (in SComponent aComponent) raises (LockProtection)
 Deletion of a SComponent. More...
SObject NewObject (in SObject theFatherObject) raises (LockProtection)
 Creation of a new SObject. More...
SObject NewObjectToTag (in SObject theFatherObject, in long atag) raises (LockProtection)
 Creation of a new SObject with a definite tag. More...
void RemoveObject (in SObject anObject) raises (LockProtection)
 Deletion of the SObject. More...
void RemoveObjectWithChildren (in SObject anObject) raises (LockProtection)
 Deletion of the SObject with all his child objects. More...
void LoadWith (in SComponent sco, in Driver Engine) raises (SALOME::SALOME_Exception)
 Loads a SComponent. More...
void Load (in SObject sco)
 Loads a SObject. More...
GenericAttribute FindOrCreateAttribute (in SObject anObject, in string aTypeOfAttribute) raises (LockProtection)
 Looking for or creating an attribute assigned to the SObject. More...
boolean FindAttribute (in SObject anObject, out GenericAttribute anAttribute, in string aTypeOfAttribute)
 Looking for an attribute assigned to a SObject. More...
void RemoveAttribute (in SObject anObject, in string aTypeOfAttribute) raises (LockProtection)
 Deleting the attribute assigned to the SObject. More...
void Addreference (in SObject anObject, in SObject theReferencedObject)
 Adds a reference between anObject and theReferencedObject. More...
void RemoveReference (in SObject anObject)
 Removes a reference from anObject to another object. More...
void SetGUID (in SObject anObject, in string theGUID) raises (LockProtection)
 Identification of the SObject's substructure. More...
boolean IsGUID (in SObject anObject, in string theGUID)
 Searches for a definite SObject with a definite GUID and returns True if it finds it. More...
void NewCommand ()
 Creation of a new command. More...
void CommitCommand () raises (LockProtection)
 Execution of the command. More...
boolean HasOpenCommand ()
 Returns True if at this moment there is a command under execution. More...
void AbortCommand ()
 Cancellation of the command. More...
void Undo () raises (LockProtection)
 Undo method. More...
void Redo () raises (LockProtection)
 Redo method. More...
boolean GetAvailableUndos ()
boolean GetAvailableRedos ()
void SetName (in SObject theSO, in string theValue) raises (LockProtection)
 Puts name attribute with the given string value to the given SObject. More...
void SetComment (in SObject theSO, in string theValue) raises (LockProtection)
 Puts comment attribute with the given string value to the given SObject. More...
void SetIOR (in SObject theSO, in string theValue) raises (LockProtection)
 Puts IOR attribute with the given string value to the given SObject. More...
Data Fields
attribute long UndoLimit
 Undolimit. More...
The purpose of the Builder is to add and/or remove objects and attributes. A StudyBuilder is linked to a Study. A command management is provided for the undo/redo functionalities.
The Tag of an item in SALOME application is a symbolic description of item's position in the tree-type structure of the browser. In general it has the following form: 0:2:1:1
◆ AbortCommand()
void SALOMEDS::StudyBuilder::AbortCommand ( )
Cancels all actions declared within the command.
See example17 for an example of this method usage in batchmode of SALOME application.
◆ Addreference()
void SALOMEDS::StudyBuilder::Addreference ( in SObject  anObject,
anObjectThe SObject which will get a reference
theReferencedObjectThe SObject having a reference
◆ CommitCommand()
void SALOMEDS::StudyBuilder::CommitCommand ( )
Commits all actions declared within this command.
Exceptions
LockProtectionThis exception is raised, when trying to perform this command a study, which is protected for modifications.
See example16 for an example of this method usage in batchmode of SALOME application.
◆ DefineComponentInstance()
void SALOMEDS::StudyBuilder::DefineComponentInstance ( in SComponent  aComponent,
Defines the instance to the SComponent.
◆ FindAttribute()
boolean SALOMEDS::StudyBuilder::FindAttribute ( in SObject  anObject,
Allows to find an attribute of a specific type which is assigned to the object.
anObjectThe SObject corresponding to the attribute which is looked for.
aTypeOfAttributeType of the attribute.
anAttributeWhere the attribute is placed if it's found.
True if it finds an attribute.
◆ FindOrCreateAttribute()
GenericAttribute SALOMEDS::StudyBuilder::FindOrCreateAttribute ( in SObject  anObject,
Allows to find or create an attribute of a specific type which is assigned to the object.
See example1 for an example of this method usage in batchmode of SALOME application.
◆ GetAvailableRedos()
boolean SALOMEDS::StudyBuilder::GetAvailableRedos ( )
Returns True if at this moment there are any actions which can be redone.
See example3 for an example of this method usage in batchmode of SALOME application.
◆ GetAvailableUndos()
boolean SALOMEDS::StudyBuilder::GetAvailableUndos ( )
Returns True if at this moment there are any actions which can be canceled.
◆ HasOpenCommand()
boolean SALOMEDS::StudyBuilder::HasOpenCommand ( )
◆ IsGUID()
boolean SALOMEDS::StudyBuilder::IsGUID ( in SObject  anObject,
in string  theGUID
anObjectA definite SObject which will be identified
theGUIDGUID has the following format "00000000-0000-0000-0000-000000000000"
◆ Load()
void SALOMEDS::StudyBuilder::Load ( in SObject  sco)
Loads a SObject.
scoSObject to be loaded.
Referenced by SALOME_DriverPy.SALOME_DriverPy_i::LoadASCII().
◆ LoadWith()
void SALOMEDS::StudyBuilder::LoadWith ( in SComponent  sco,
in Driver  Engine
Loads a SComponent.
See example19 for an example of this method usage in batchmode of SALOME application.
◆ NewCommand()
void SALOMEDS::StudyBuilder::NewCommand ( )
Creates a new command which can contain several different actions.
◆ NewComponent()
SComponent SALOMEDS::StudyBuilder::NewComponent ( in string  ComponentDataType)
Creates a new SComponent
ComponentDataTypeData type of the SComponent which will be created.
◆ NewObject()
SObject SALOMEDS::StudyBuilder::NewObject ( in SObject  theFatherObject)
Creates a new SObject under a definite father SObject.
theFatherObjectThe father SObject under which this one should be created.
New SObject
See example18 for an example of this method usage in batchmode of SALOME application.
◆ NewObjectToTag()
SObject SALOMEDS::StudyBuilder::NewObjectToTag ( in SObject  theFatherObject,
in long  atag
Creates a new SObject with a definite tag.
atagLong value corresponding to the tag of the new SObject.
New SObject
◆ Redo()
void SALOMEDS::StudyBuilder::Redo ( )
Redo method.
Redoes all actions of the last command.
Exceptions
◆ RemoveAttribute()
void SALOMEDS::StudyBuilder::RemoveAttribute ( in SObject  anObject,
Removes the attribute of a specific type which is assigned to the object.
anObjectThe SObject corresponding to the attribute.
◆ RemoveComponent()
void SALOMEDS::StudyBuilder::RemoveComponent ( in SComponent  aComponent)
Removes a SComponent.
◆ RemoveObject()
void SALOMEDS::StudyBuilder::RemoveObject ( in SObject  anObject)
Removes a SObject from the StudyBuilder.
anObjectThe SObject to be deleted.
◆ RemoveObjectWithChildren()
void SALOMEDS::StudyBuilder::RemoveObjectWithChildren ( in SObject  anObject)
Removes the SObject with all his child objects.
anObjectThe SObject to be deleted with all child objects.
◆ RemoveReference()
void SALOMEDS::StudyBuilder::RemoveReference ( in SObject  anObject)
anObjectThe SObject which contains a reference
◆ SetComment()
void SALOMEDS::StudyBuilder::SetComment ( in SObject  theSO,
in string  theValue
theSOExisting SObject to set comment attribute.
theValueThe value to be set to the comment attribute.
◆ SetGUID()
void SALOMEDS::StudyBuilder::SetGUID ( in SObject  anObject,
in string  theGUID
Identification of the SObject's substructure by GUID.
anObjectThe SObject which will be identified
◆ SetIOR()
void SALOMEDS::StudyBuilder::SetIOR ( in SObject  theSO,
in string  theValue
theSOExisting SObject to set IOR attribute.
theValueThe value to be set to the IOR attribute.
◆ SetName()
void SALOMEDS::StudyBuilder::SetName ( in SObject  theSO,
in string  theValue
theSOExisting SObject to set name attribute.
theValueThe value to be set to the name attribute.
◆ Undo()
void SALOMEDS::StudyBuilder::Undo ( )
Undo method.
Cancels all actions of the last command.
Exceptions
◆ UndoLimit
attribute long SALOMEDS::StudyBuilder::UndoLimit
Undolimit.
The number of actions which can be undone
