SALOME_Launcher.idl
23#ifndef _SALOME_LAUNCHER_IDL_
24#define _SALOME_LAUNCHER_IDL_
26#include "SALOME_Exception.idl"
28
32module Engines
33{
34
36typedef sequence<string> FilesList;
37
40{
41 string name;
42 string value;
43};
45typedef sequence<Engines::Parameter> ParameterList;
46
48{
50 string job_name;
51
53
61 string job_type;
62
63 // Common values
65
70 string job_file;
71
73
77
79
81 string env_file;
82
84
89
91
99
101
112
114
118
120
127
129
133
135
141
143 string queue;
144
146
148 string partition;
149
154
156 boolean exclusive;
157
159 unsigned long mem_per_cpu;
160
162 string wckey;
163
166
168
180
185};
186
188{
189 long job_id;
191};
192typedef sequence<Engines::JobDescription> JobsList;
193
195{
196 void notify(in string event_name, in string event_data);
197};
198
200
208{
209 // Main methods
211
215
217
224
226
230 string getJobState (in long job_id) raises (SALOME::SALOME_Exception);
231
234
237
240
251 void getJobResults(in long job_id, in string directory) raises (SALOME::SALOME_Exception);
252
254
267 boolean getJobDumpState(in long job_id, in string directory) raises (SALOME::SALOME_Exception);
268
270
274
276
289 boolean getJobWorkFile(in long job_id, in string work_file, in string directory) raises (SALOME::SALOME_Exception);
290
292 void stopJob (in long job_id) raises (SALOME::SALOME_Exception);
295
297 string dumpJob(in long job_id) raises (SALOME::SALOME_Exception);
299
302 long restoreJob(in string dumpedJob) raises (SALOME::SALOME_Exception);
303
304 // Useful methods
305 long createJobWithFile(in string xmlJobFile, in string clusterName) raises (SALOME::SALOME_Exception);
307
308 // SALOME kernel service methods
310 void Shutdown();
312 long getPID();
313
314 // Observer and introspection methods
320
321 // Save and load methods
323 void loadJobs(in string jobs_file) raises (SALOME::SALOME_Exception);
325 void saveJobs(in string jobs_file) raises (SALOME::SALOME_Exception);
326};
327
328};
329
330#endif
This file contains the objects defining the main exception used in SALOME application.
interfaces for SALOME Resources Manager service
Definition: SALOME_Launcher.idl:195
Interface of the salome launcher.
Definition: SALOME_Launcher.idl:208
long createJob(in Engines::JobParameters job_parameters)
Create a job and set its parameters, without launching it.
Save the current list of jobs in an xml file.
Engines::JobsList getJobsList()
boolean testBatch(in ResourceParameters params)
void removeObserver(in Engines::SalomeLauncherObserver observer)
Get the job's serialization string.
Engines::JobParameters getJobParameters(in long job_id)
void clearJobWorkingDir(in long job_id)
Remove the working directory on the remote file system.
string getAssignedHostnames(in long job_id)
Get names or ids of hosts assigned to the job.
Create a job from its serialization string.
void exportInputFiles(in long job_id)
Copy all the in_files of the job to the work_directory.
void addObserver(in Engines::SalomeLauncherObserver observer)
Add an observer to be notified of the jobs list modifications.
Retrieve one single file from the working directory.
Copy the result files from the work directory of the job to a local directory.
Add to the current jobs list the jobs previously saved in an xml file.
void stopJob(in long job_id)
Kill the job and set its state to "FAILED".
void Shutdown()
Shutdow SalomeLauncher server.
string getJobState(in long job_id)
Get the execution state of the job.
void launchJob(in long job_id)
Launch an already created job (job's state should be "CREATED").
Try to copy the files named "dumpState*.xml" from the working directory.
void removeJob(in long job_id)
Kill the job and remove it from the jobs list.
long getPID()
Get the PID of the current process.
sequence< Engines::JobDescription > JobsList
Definition: SALOME_Launcher.idl:192
sequence< Engines::Parameter > ParameterList
Generic parameter list.
Definition: SALOME_Launcher.idl:45
sequence< string > FilesList
files list
Definition: SALOME_Launcher.idl:36
job_id
Definition: launcher_use_case.py:49
Definition: SALOME_Launcher.idl:188
Definition: SALOME_Launcher.idl:190
long job_id
Definition: SALOME_Launcher.idl:189
Definition: SALOME_Launcher.idl:48
Specifies the memory limit per cpu (exclusive with resource_required.mem_mb)
Definition: SALOME_Launcher.idl:159
string job_type
Type of the job.
Definition: SALOME_Launcher.idl:61
string extra_params
String that is added to the job submission file - optional.
Definition: SALOME_Launcher.idl:165
boolean exclusive
Specifies if the job must run in exclusive mode (without sharing nodes with other jobs)
Definition: SALOME_Launcher.idl:156
string job_file
Local path to the file to be executed by the job.
Definition: SALOME_Launcher.idl:70
string launcher_file
Parameter for COORM
Definition: SALOME_Launcher.idl:182
string env_file
Local path to a script to be sourced in the environment of the job.
Definition: SALOME_Launcher.idl:81
string local_directory
Prefix to be applied to in_files.
Definition: SALOME_Launcher.idl:117
string verbose_py_log_level
steer verbose level of log level of python executed inside SALOME_Containers
Definition: SALOME_Launcher.idl:153
string wckey
Workload Characterization Key - mandatory on some clusters.
Definition: SALOME_Launcher.idl:162
string maximum_duration
Maximum time for the batch execution (expected format : "hh:mm").
Definition: SALOME_Launcher.idl:132
string queue
Name of the batch queue chosen - optional.
Definition: SALOME_Launcher.idl:143
string launcher_args
Parameter for COORM
Definition: SALOME_Launcher.idl:184
string pre_command
Pre processing script.
Definition: SALOME_Launcher.idl:76
string job_name
Name of the job.
Definition: SALOME_Launcher.idl:50
string work_directory
Remote directory where the job will be executed.
Definition: SALOME_Launcher.idl:111
string partition
Name of the partition - optional.
Definition: SALOME_Launcher.idl:148
Engines::ParameterList specific_parameters
Specific parameters for each type of job - optional.
Definition: SALOME_Launcher.idl:179
FilesList in_files
List of local data files to be copied to work_directory.
Definition: SALOME_Launcher.idl:88
string result_directory
Local directory where to get result files.
Definition: SALOME_Launcher.idl:126
ResourceParameters resource_required
Specifies the rules to choose the resource where to execute the job.
Definition: SALOME_Launcher.idl:140
FilesList out_files
List of results to get back at the end of the job.
Definition: SALOME_Launcher.idl:98
A generic parameter.
Definition: SALOME_Launcher.idl:40
string value
Definition: SALOME_Launcher.idl:42
string name
Definition: SALOME_Launcher.idl:41
Type to describe required properties of a resource.
Definition: SALOME_ResourcesManager.idl:42
