Engines::JobParameters Struct Reference
import"SALOME_Launcher.idl";
Inheritance diagram for Engines::JobParameters:
Data Fields
string job_name
 Name of the job. More...
string job_type
 Type of the job. More...
string job_file
 Local path to the file to be executed by the job. More...
string pre_command
 Pre processing script. More...
string env_file
 Local path to a script to be sourced in the environment of the job. More...
FilesList in_files
 List of local data files to be copied to work_directory. More...
FilesList out_files
 List of results to get back at the end of the job. More...
string work_directory
 Remote directory where the job will be executed. More...
string local_directory
 Prefix to be applied to in_files. More...
string result_directory
 Local directory where to get result files. More...
string maximum_duration
 Maximum time for the batch execution (expected format : "hh:mm"). More...
ResourceParameters resource_required
 Specifies the rules to choose the resource where to execute the job. More...
string queue
 Name of the batch queue chosen - optional. More...
string partition
 Name of the partition - optional. More...
string verbose_py_log_level
 steer verbose level of log level of python executed inside SALOME_Containers More...
boolean exclusive
 Specifies if the job must run in exclusive mode (without sharing nodes with other jobs) More...
unsigned long mem_per_cpu
 Specifies the memory limit per cpu (exclusive with resource_required.mem_mb) More...
string wckey
 Workload Characterization Key - mandatory on some clusters. More...
string extra_params
 String that is added to the job submission file - optional. More...
Engines::ParameterList specific_parameters
 Specific parameters for each type of job - optional. More...
string launcher_file
 Parameter for COORM More...
string launcher_args
◆ env_file
string Engines::JobParameters::env_file
It may contain modifications of environment variables.
Referenced by SALOME_Launcher::JobParameters_CORBA2CPP().
◆ exclusive
boolean Engines::JobParameters::exclusive
◆ extra_params
string Engines::JobParameters::extra_params
◆ in_files
FilesList Engines::JobParameters::in_files
job_file and env_file are automatically copied, without adding them to this list. If basenames are specified, then the files are supposed to be located in local_directory.
◆ job_file
string Engines::JobParameters::job_file
The type of the file depends on job_type. If job_type is "command", the job_file must be a single filename specifying a self-consistent script to be executed without any argument, on the remote host.
◆ job_name
string Engines::JobParameters::job_name
◆ job_type
string Engines::JobParameters::job_type
Type of the job.
There are three supported types:
  • "command" : execute job_file script without SALOME environment
  • "command_salome" : execute job_file script within SALOME environment (salome shell) but the SALOME application is not launched
  • "python_salome" : execute job_file python script by SALOME
  • "yacs_file" : execute job_file by YACS module as a xml YACS schema
◆ launcher_args
string Engines::JobParameters::launcher_args
Parameter for COORM
◆ launcher_file
string Engines::JobParameters::launcher_file
Parameter for COORM
◆ local_directory
string Engines::JobParameters::local_directory
It can be used to specify where to find the local input files. It's optional if you specify the absolute path name of input files.
◆ maximum_duration
string Engines::JobParameters::maximum_duration
Could be empty, in this case, default value of the selected resource will be used.
◆ mem_per_cpu
unsigned long Engines::JobParameters::mem_per_cpu
◆ out_files
FilesList Engines::JobParameters::out_files
These results can be names of files or directories, produced by the job in work_directory. Directories will be copied recursively. It is also possible to use an absolute path instead of the simple name, (string beginning with '/') and this absolute path will be used instead of result_directory when SalomeLauncher::getJobResults is called.
See also
◆ partition
string Engines::JobParameters::partition
It can be used only for slurm batch managers.
◆ pre_command
string Engines::JobParameters::pre_command
This script is called on the remote resource, from work_directory, after the copy of in_files and before submiting the job.
◆ queue
string Engines::JobParameters::queue
◆ resource_required
ResourceParameters Engines::JobParameters::resource_required
The additional two following parameters MUST be specified explicitly, because they are not provided by the resource definition:
  • mem_mb -> Memory expressed in megabytes.
  • nb_proc -> Number of Processors.
◆ result_directory
string Engines::JobParameters::result_directory
It must be used to specify where to download the output files on the local file system. If not specified (empty string), the value of $HOME environment variable will be used.
See also
◆ specific_parameters
Engines::ParameterList Engines::JobParameters::specific_parameters
This is a list of parameters (key - value pairs of strings) useful in some specific situations. Known parameters:
  • EnableDumpYACS : value of the "dump" option of the "driver" command when the job type is "yacs_file". It gives the number of seconds between two updates of the state dump file. There will be no dump file if this parameter is missing or if its value is less than 1.
  • YACSDriverOptions : options of the driver command when the job type is "yacs_file".
  • LoalLevelerJobType : LL_JOBTYPE.
◆ verbose_py_log_level
string Engines::JobParameters::verbose_py_log_level
◆ wckey
string Engines::JobParameters::wckey
◆ work_directory
string Engines::JobParameters::work_directory
It must be used to specify the remote directory where to put all the stuff to run the job. Note that the job will be executed from within this directory. A change directory toward this working directory is done by the batch system before running the job. If not specified (empty string), the launcher will use the working directory of the chosen resource and if this is also an empty string the value used will be $HOME/Batch/workdir_"date" where $HOME is the value of the environment variable on the remote resource and "date" is the current date.
