Engines::ResourceParameters Struct Reference
Type to describe required properties of a resource. More...
import"SALOME_ResourcesManager.idl";
Inheritance diagram for Engines::ResourceParameters:
Data Fields
string name
 resource name - manual selection More...
string hostname
 host name More...
boolean can_launch_batch_jobs
 if true select only resources that can launch batch jobs More...
boolean can_run_containers
 if true select only resources that can run containers More...
string OS
 if given required operating system More...
CompoList componentList
 if given, list of components that could be loaded on a container. More...
long nb_proc
 required number of processors More...
long mem_mb
 required memory size More...
long cpu_clock
 required frequency More...
long nb_node
 required number of nodes. Can be used when submitting slurm jobs. More...
long nb_proc_per_node
 required number of proc per node More...
string policy
 resource management policy : first, cycl, altcycl or best (can be extended) More...
ResourceList resList
 restricted list of resources to search in More...
◆ can_launch_batch_jobs
boolean Engines::ResourceParameters::can_launch_batch_jobs
Referenced by SALOME_LifeCycleCORBA::preSet(), resourceParameters_CORBAtoCPP(), and SALOME_Launcher::testBatch().
◆ can_run_containers
◆ componentList
CompoList Engines::ResourceParameters::componentList
◆ cpu_clock
long Engines::ResourceParameters::cpu_clock
◆ hostname
◆ mem_mb
long Engines::ResourceParameters::mem_mb
This parameter must be specified explicitly, because it is not provided by the resource definition.
The parameter specifies the maximum memory value that could be allocated for executing the job. This takes into account not only the data that could be loaded by the batch process but also the linked dynamic library. A possible problem, for example in the case where you use the ssh emulation of a batch system, is to get an error message as below when libBatch tries to run the ssh command:
/usr/bin/ssh: error while loading shared libraries: libcrypto.so.0.9.8: failed
to map segment from shared object: Cannot allocate memory
In this example, the mem_mb was set to 1MB, value that is not sufficient to load the dynamic libraries linked to the ssh executable (libcrypto.so in the error message). So, even in the case of a simple test shell script, you should set this value at least to a standard threshold as 500MB.
Referenced by main(), SALOME_LifeCycleCORBA::preSet(), and resourceParameters_CORBAtoCPP().
◆ name
string Engines::ResourceParameters::name
If a name is provided, the resource will be imposed. If the name is an empty string, the resource will be chosen to match the other parameters.
Referenced by IDLparser.Tree::__repr__(), salomeContext.SalomeContext::_startSalome(), IDLparser.Tree::getNode(), IDLparser.Tree::output_xml(), SALOME_LifeCycleCORBA::preSet(), resourceParameters_CORBAtoCPP(), and resourceParameters_CPPtoCORBA().
◆ nb_node
long Engines::ResourceParameters::nb_node
◆ nb_proc
long Engines::ResourceParameters::nb_proc
Referenced by SALOME_LifeCycleCORBA::preSet(), and resourceParameters_CORBAtoCPP().
◆ nb_proc_per_node
long Engines::ResourceParameters::nb_proc_per_node
◆ OS
string Engines::ResourceParameters::OS
◆ policy
string Engines::ResourceParameters::policy
Referenced by SALOME_ContainerManager::GiveContainer(), main(), and SALOME_LifeCycleCORBA::preSet().
◆ resList
