SALOME_ContainerManager Class Reference
#include <SALOME_ContainerManager.hxx>
Inheritance diagram for SALOME_ContainerManager:
 SALOME_ContainerManager (CORBA::ORB_ptr orb, PortableServer::POA_var poa, SALOME_NamingService_Abstract *ns)
 ~SALOME_ContainerManager ()
 destructor More...
Engines::Container_ptr GiveContainer (const Engines::ContainerParameters &params) override
 Give a suitable Container given constraints. More...
void ShutdownContainers () override
void ShutdownContainersNow () override
void SetOverrideEnvForContainers (const Engines::KeyValDict &env) override
Engines::KeyValDict * GetOverrideEnvForContainers () override
void SetCodeOnContainerStartUp (const char *code) override
char * GetCodeOnContainerStartUp () override
void Shutdown ()
 shutdown all the containers, then the ContainerManager servant More...
void DeclareUsingSalomeSession ()
CORBA::Long GetTimeOutToLaunchServerInSecond () override
void SetTimeOutToLaunchServerInSecond (CORBA::Long timeInSecond) override
CORBA::Long GetDeltaTimeBetweenNSLookupAtLaunchTimeInMilliSecond () override
void SetDeltaTimeBetweenNSLookupAtLaunchTimeInMilliSecond (CORBA::Long timeInMS) override
CORBA::Long GetDeltaTimeBetweenCPUMemMeasureInMilliSecond () override
void SetDeltaTimeBetweenCPUMemMeasureInMilliSecond (CORBA::Long timeInMS) override
void SetBigObjOnDiskThreshold (CORBA::Long thresholdInByte) override
void SetBigObjOnDiskDirectory (const char *directory) override
void SetDirectoryForReplayFiles (const char *directory) override
void SetNumberOfRetry (CORBA::Long nbRetry) override
CORBA::Long GetNumberOfRetry () override
static char * GetenvThreadSafe (const char *name)
static std::string GetenvThreadSafeAsString (const char *name)
static int SystemThreadSafe (const char *command)
static long SystemWithPIDThreadSafe (const std::vector< std::string > &command)
static void AddOmninamesParams (std::ostream &fileStream, SALOME_NamingService_Abstract *ns)
 add to command all options relative to naming service. More...
static void MakeTheCommandToBeLaunchedASync (std::string &command)
static int GetTimeOutToLoaunchServer ()
 Return in second the time out to give chance to server to be launched and to register into NS. More...
static void SleepInSecond (int ellapseTimeInSecond)
Static Public Attributes
static const char * _ContainerManagerNameInNS = "/ContainerManager"
Protected Types
typedef std::vector< std::string > actual_launch_machine_t
Engines::Container_ptr FindContainer (const Engines::ContainerParameters &params, const Engines::ResourceList &possibleResources)
 Find a container given constraints (params) on a list of machines (possibleComputers) agy : this method is ThreadSafe. More...
Engines::Container_ptr FindContainer (const Engines::ContainerParameters &params, const std::string &resource)
 Find a container given constraints (params) on a machine (theMachine) agy : this method is ThreadSafe. More...
std::string GetCppBinaryOfKernelSSLContainer () const
std::string GetCppBinaryOfKernelContainer () const
std::string GetRunRemoteExecutableScript () const
std::string BuildCommandToLaunchRemoteContainer (const std::string &resource_name, const Engines::ContainerParameters &params, const std::string &container_exe="SALOME_Container") const
 Builds the script to be launched. More...
std::string BuildCommandToLaunchLocalContainer (const Engines::ContainerParameters &params, const std::string &machinesFile, const std::string &container_exe, std::string &tmpFileName) const
 builds the command to be launched. More...
std::string BuildTempFileToLaunchRemoteContainer (const std::string &resource_name, const Engines::ContainerParameters &params, std::string &tmpFileName) const
 Builds in a temporary file the script to be launched. More...
void AddOmninamesParams (std::string &command) const
void AddOmninamesParams (std::ostream &fileStream) const
std::string GetMPIZeroNode (const std::string machine, const std::string machinesFile) const
std::string machinesFile (const int nbproc)
std::string getCommandToRunRemoteProcessCommon (const std::string &templateName, const std::string &remoteScript, AccessProtocolType protocol, const std::string &hostname, const std::string &username, const std::string &applipath, const std::string &workdir) const
std::string getCommandToRunRemoteProcess (AccessProtocolType protocol, const std::string &hostname, const std::string &username, const std::string &applipath, const std::string &workdir="") const
std::string getCommandToRunRemoteProcessNoAppli (AccessProtocolType protocol, const std::string &hostname, const std::string &username, const std::string &applipath, const std::string &workdir="") const
Engines::Container_ptr LaunchContainer (const Engines::ContainerParameters &params, const std::string &resource_selected, const std::string &hostname, const std::string &machFile, const std::string &containerNameInNS)
bool checkPaCOParameters (Engines::ContainerParameters &params, std::string resource_selected)
Engines::Container_ptr StartPaCOPPContainer (const Engines::ContainerParameters &params, std::string resource_selected)
std::string BuildCommandToLaunchPaCOProxyContainer (const Engines::ContainerParameters &params, std::string machine_file_name, std::string &proxy_hostname)
std::string BuildCommandToLaunchPaCONodeContainer (const Engines::ContainerParameters &params, const std::string &machine_file_name, SALOME_ContainerManager::actual_launch_machine_t &vect_machine, const std::string &proxy_hostname)
void LogConfiguration (const std::string &log_type, const std::string &exe_type, const std::string &container_name, const std::string &hostname, std::string &begin, std::string &end)
CORBA::Object_ptr LaunchPaCOProxyContainer (const std::string &command, const Engines::ContainerParameters &params, const std::string &hostname)
bool LaunchPaCONodeContainer (const std::string &command, const Engines::ContainerParameters &params, const std::string &name, SALOME_ContainerManager::actual_launch_machine_t &vect_machine)
static void RmTmpFile (std::string &tmpFile)
 removes the generated temporary file in case of a remote launch. More...
static std::string BuildTemporaryFileName ()
 generate a file name in /tmp directory More...
CORBA::ORB_var _orb
PortableServer::POA_var _poa
SALOME_ResourcesManager_Client * _resManager
SALOME_NamingService_Abstract * _NS
bool _isAppliSalomeDefined
 different behaviour if $APPLI exists (SALOME Application) More...
int _nbprocUsed
 attribute that contains the number of processes used in batch mode by MPI containers More...
bool _isSSL = true
 attribute that specifies the launch mode. More...
Utils_Mutex _giveContainerMutex1
 attributes to allow concurrency for // GiveContainer More...
pid_t _pid_mpiServer
Static Protected Attributes
static omni_mutex _numInstanceMutex
void ShutdownContainersGeneric (std::function< void(Engines::Container_ptr)> funcToBeCalledOnContainer)
 Loop on all the containers listed in naming service, ask shutdown on each. More...
std::vector< std::pair< std::string, std::string > > _override_env
int _time_out_in_second
int _delta_time_ns_lookup_in_ms
int _delta_time_measure_in_ms
std::string _code_to_exe_on_startup
Static Private Attributes
static const int TIME_OUT_TO_LAUNCH_CONT =60
static const int DFT_DELTA_TIME_NS_LOOKUP_IN_MS =1000
static Utils_Mutex _getenvMutex
static Utils_Mutex _systemMutex
◆ actual_launch_machine_t
typedef std::vector<std::string> SALOME_ContainerManager::actual_launch_machine_t
◆ SALOME_ContainerManager()
SALOME_ContainerManager::SALOME_ContainerManager ( CORBA::ORB_ptr  orb,
SALOME_NamingService_Abstract *  ns
orbDefine a CORBA single thread policy for the server, which avoid to deal with non thread-safe usage like Change_Directory in SALOME naming service
References _ContainerManagerNameInNS, _isAppliSalomeDefined, _NS, _orb, _pid_mpiServer, _poa, _resManager, _time_out_in_second, GetenvThreadSafe(), GetenvThreadSafeAsString(), GetTimeOutToLoaunchServer(), KERNEL_PY.batchmode_salome::obj, salome::orb, SALOME_ContainerPy::poa, and SALOME_NamingService_Container_Abstract::Register().
◆ ~SALOME_ContainerManager()
SALOME_ContainerManager::~SALOME_ContainerManager ( )
◆ AddOmninamesParams() [1/3]
void SALOME_ContainerManager::AddOmninamesParams ( std::ostream &  fileStream) const
References _NS, and AddOmninamesParams().
◆ AddOmninamesParams() [2/3]
void SALOME_ContainerManager::AddOmninamesParams ( std::ostream &  fileStream,
References SALOME_NamingService::getIORaddr().
◆ AddOmninamesParams() [3/3]
void SALOME_ContainerManager::AddOmninamesParams ( std::string &  command) const
◆ BuildCommandToLaunchLocalContainer()
◆ BuildCommandToLaunchPaCONodeContainer()
std::string SALOME_ContainerManager::BuildCommandToLaunchPaCONodeContainer ( const Engines::ContainerParameters &  params,
const std::string &  machine_file_name,
SALOME_ContainerManager::actual_launch_machine_t &  vect_machine,
const std::string &  proxy_hostname
◆ BuildCommandToLaunchPaCOProxyContainer()
std::string SALOME_ContainerManager::BuildCommandToLaunchPaCOProxyContainer ( const Engines::ContainerParameters &  params,
◆ BuildCommandToLaunchRemoteContainer()
std::string SALOME_ContainerManager::BuildCommandToLaunchRemoteContainer ( const std::string &  resource_name,
const std::string &  container_exe = "SALOME_Container"
If SALOME Application not defined ($APPLI), see BuildTempFileToLaunchRemoteContainer()
Else rely on distant configuration. Command is under the form (example): ssh user@machine distantPath/runRemote.sh hostNS portNS WORKINGDIR workingdir \ SALOME_Container containerName &"
  • where user is omitted if not specified in CatalogResources,
  • where distant path is always relative to user@machine $HOME, and equal to $APPLI if not specified in CatalogResources,
  • where hostNS is the hostname of CORBA naming server (set by scripts to use to launch SALOME and servers in $APPLI: runAppli.sh, runRemote.sh)
  • where portNS is the port used by CORBA naming server (set by scripts to use to launch SALOME and servers in $APPLI: runAppli.sh, runRemote.sh)
  • where workingdir is the requested working directory for the container. If WORKINGDIR (and workingdir) is not present the working dir will be $HOME
References _isAppliSalomeDefined, _isSSL, _NS, _orb, _resManager, AddOmninamesParams(), ParserResourcesType::AppliPath, TestKernelHelpers::command, SALOME_NamingService_Abstract::ContainerName(), getCommandToRunRemoteProcess(), getCommandToRunRemoteProcessNoAppli(), GetEmbeddedNamingService(), GetenvThreadSafe(), GetenvThreadSafeAsString(), SALOME_ResourcesManager_Client::GetResourceDefinition(), ParserResourcesType::HostName, Engines::ContainerParameters::isMPI, MESSAGE, Engines::ContainerParameters::nb_proc, ParserResourcesType::Protocol, ParserResourcesType::UserName, and Engines::ContainerParameters::workingdir.
Referenced by LaunchContainer().
◆ BuildTempFileToLaunchRemoteContainer()
std::string SALOME_ContainerManager::BuildTempFileToLaunchRemoteContainer ( const std::string &  resource_name,
std::string &  tmpFileName
◆ BuildTemporaryFileName()
std::string SALOME_ContainerManager::BuildTemporaryFileName ( )
staticprotected
Referenced by BuildCommandToLaunchLocalContainer(), BuildTempFileToLaunchRemoteContainer(), and GetMPIZeroNode().
◆ checkPaCOParameters()
◆ DeclareUsingSalomeSession()
void SALOME_ContainerManager::DeclareUsingSalomeSession ( )
◆ FindContainer() [1/2]
Engines::Container_ptr SALOME_ContainerManager::FindContainer ( const Engines::ContainerParameters &  params,
const Engines::ResourceList &  possibleResources
References FindContainer(), and MESSAGE.
Referenced by FindContainer(), and GiveContainer().
◆ FindContainer() [2/2]
◆ GetCodeOnContainerStartUp()
char * SALOME_ContainerManager::GetCodeOnContainerStartUp ( )
override
◆ getCommandToRunRemoteProcess()
std::string SALOME_ContainerManager::getCommandToRunRemoteProcess ( AccessProtocolType  protocol,
const std::string &  hostname,
const std::string &  username,
const std::string &  applipath,
const std::string &  workdir = ""
◆ getCommandToRunRemoteProcessCommon()
std::string SALOME_ContainerManager::getCommandToRunRemoteProcessCommon ( const std::string &  templateName,
const std::string &  remoteScript,
◆ getCommandToRunRemoteProcessNoAppli()
std::string SALOME_ContainerManager::getCommandToRunRemoteProcessNoAppli ( AccessProtocolType  protocol,
◆ GetCppBinaryOfKernelContainer()
std::string SALOME_ContainerManager::GetCppBinaryOfKernelContainer ( ) const
◆ GetCppBinaryOfKernelSSLContainer()
std::string SALOME_ContainerManager::GetCppBinaryOfKernelSSLContainer ( ) const
◆ GetDeltaTimeBetweenCPUMemMeasureInMilliSecond()
CORBA::Long SALOME_ContainerManager::GetDeltaTimeBetweenCPUMemMeasureInMilliSecond ( )
override
◆ GetDeltaTimeBetweenNSLookupAtLaunchTimeInMilliSecond()
CORBA::Long SALOME_ContainerManager::GetDeltaTimeBetweenNSLookupAtLaunchTimeInMilliSecond ( )
override
◆ GetenvThreadSafe()
◆ GetenvThreadSafeAsString()
◆ GetMPIZeroNode()
◆ GetNumberOfRetry()
CORBA::Long SALOME_ContainerManager::GetNumberOfRetry ( )
override
◆ GetOverrideEnvForContainers()
Engines::KeyValDict * SALOME_ContainerManager::GetOverrideEnvForContainers ( )
override
◆ GetRunRemoteExecutableScript()
std::string SALOME_ContainerManager::GetRunRemoteExecutableScript ( ) const
◆ GetTimeOutToLaunchServerInSecond()
CORBA::Long SALOME_ContainerManager::GetTimeOutToLaunchServerInSecond ( )
override
References _time_out_in_second.
◆ GetTimeOutToLoaunchServer()
int SALOME_ContainerManager::GetTimeOutToLoaunchServer ( )
References GetenvThreadSafe(), GetenvThreadSafeAsString(), and TIME_OUT_TO_LAUNCH_CONT.
Referenced by CreateDataScope(), and SALOME_ContainerManager().
◆ GiveContainer()
◆ LaunchContainer()
◆ LaunchPaCONodeContainer()
bool SALOME_ContainerManager::LaunchPaCONodeContainer ( const std::string &  command,
const std::string &  name,
◆ LaunchPaCOProxyContainer()
CORBA::Object_ptr SALOME_ContainerManager::LaunchPaCOProxyContainer ( const std::string &  command,
◆ LogConfiguration()
void SALOME_ContainerManager::LogConfiguration ( const std::string &  log_type,
const std::string &  exe_type,
const std::string &  container_name,
std::string &  begin,
std::string &  end
◆ machinesFile()
std::string SALOME_ContainerManager::machinesFile ( const int  nbproc)
◆ MakeTheCommandToBeLaunchedASync()
void SALOME_ContainerManager::MakeTheCommandToBeLaunchedASync ( std::string &  command)
◆ RmTmpFile()
void SALOME_ContainerManager::RmTmpFile ( std::string &  tmpFileName)
staticprotected
This method is thread safe
References TestKernelHelpers::command, and SystemThreadSafe().
Referenced by GetMPIZeroNode(), and LaunchContainer().
◆ SetBigObjOnDiskDirectory()
void SALOME_ContainerManager::SetBigObjOnDiskDirectory ( const char *  directory)
override
◆ SetBigObjOnDiskThreshold()
void SALOME_ContainerManager::SetBigObjOnDiskThreshold ( CORBA::Long  thresholdInByte)
override
◆ SetCodeOnContainerStartUp()
void SALOME_ContainerManager::SetCodeOnContainerStartUp ( const char *  code)
override
◆ SetDeltaTimeBetweenCPUMemMeasureInMilliSecond()
void SALOME_ContainerManager::SetDeltaTimeBetweenCPUMemMeasureInMilliSecond ( CORBA::Long  timeInMS)
override
◆ SetDeltaTimeBetweenNSLookupAtLaunchTimeInMilliSecond()
void SALOME_ContainerManager::SetDeltaTimeBetweenNSLookupAtLaunchTimeInMilliSecond ( CORBA::Long  timeInMS)
override
◆ SetDirectoryForReplayFiles()
void SALOME_ContainerManager::SetDirectoryForReplayFiles ( const char *  directory)
override
◆ SetNumberOfRetry()
void SALOME_ContainerManager::SetNumberOfRetry ( CORBA::Long  nbRetry)
override
◆ SetOverrideEnvForContainers()
void SALOME_ContainerManager::SetOverrideEnvForContainers ( const Engines::KeyValDict &  env)
override
References _override_env.
◆ SetTimeOutToLaunchServerInSecond()
void SALOME_ContainerManager::SetTimeOutToLaunchServerInSecond ( CORBA::Long  timeInSecond)
override
◆ Shutdown()
void SALOME_ContainerManager::Shutdown ( )
CORBA method:
References _ContainerManagerNameInNS, _NS, _poa, SALOME_NamingService_Container_Abstract::Destroy_Name(), MESSAGE, and ShutdownContainers().
Referenced by SALOME_Launcher::Shutdown().
◆ ShutdownContainers()
void SALOME_ContainerManager::ShutdownContainers ( )
override
References ShutdownContainersGeneric().
Referenced by Shutdown().
◆ ShutdownContainersGeneric()
void SALOME_ContainerManager::ShutdownContainersGeneric ( std::function< void(Engines::Container_ptr)>  funcToBeCalledOnContainer)
◆ ShutdownContainersNow()
void SALOME_ContainerManager::ShutdownContainersNow ( )
override
◆ SleepInSecond()
void SALOME_ContainerManager::SleepInSecond ( int  ellapseTimeInSecond)
Referenced by CreateDataScope().
◆ StartPaCOPPContainer()
Engines::Container_ptr SALOME_ContainerManager::StartPaCOPPContainer ( const Engines::ContainerParameters &  params,
References TestKernelHelpers::ret.
◆ SystemThreadSafe()
int SALOME_ContainerManager::SystemThreadSafe ( const char *  command)
◆ SystemWithPIDThreadSafe()
long SALOME_ContainerManager::SystemWithPIDThreadSafe ( const std::vector< std::string > &  command)
◆ _code_to_exe_on_startup
std::string SALOME_ContainerManager::_code_to_exe_on_startup
◆ _ContainerManagerNameInNS
const char * SALOME_ContainerManager::_ContainerManagerNameInNS = "/ContainerManager"
◆ _delta_time_measure_in_ms
int SALOME_ContainerManager::_delta_time_measure_in_ms
◆ _delta_time_ns_lookup_in_ms
int SALOME_ContainerManager::_delta_time_ns_lookup_in_ms
◆ _getenvMutex
Utils_Mutex SALOME_ContainerManager::_getenvMutex
staticprivate
Referenced by GetenvThreadSafe().
◆ _giveContainerMutex1
Utils_Mutex SALOME_ContainerManager::_giveContainerMutex1
Referenced by GiveContainer(), and LaunchContainer().
◆ _isAppliSalomeDefined
bool SALOME_ContainerManager::_isAppliSalomeDefined
Referenced by BuildCommandToLaunchRemoteContainer(), GetMPIZeroNode(), LaunchContainer(), and SALOME_ContainerManager().
◆ _isSSL
bool SALOME_ContainerManager::_isSSL = true
◆ _nbprocUsed
int SALOME_ContainerManager::_nbprocUsed
Referenced by machinesFile().
◆ _NS
◆ _numInstanceMutex
omni_mutex SALOME_ContainerManager::_numInstanceMutex
staticprotected
◆ _orb
◆ _override_env
std::vector< std::pair<std::string, std::string> > SALOME_ContainerManager::_override_env
◆ _pid_mpiServer
pid_t SALOME_ContainerManager::_pid_mpiServer
◆ _poa
◆ _resManager
◆ _systemMutex
Utils_Mutex SALOME_ContainerManager::_systemMutex
staticprivate
◆ _time_out_in_second
int SALOME_ContainerManager::_time_out_in_second
◆ DFT_DELTA_TIME_NS_LOOKUP_IN_MS
const int SALOME_ContainerManager::DFT_DELTA_TIME_NS_LOOKUP_IN_MS =1000
staticprivate
◆ TIME_OUT_TO_LAUNCH_CONT
const int SALOME_ContainerManager::TIME_OUT_TO_LAUNCH_CONT =60
staticprivate
