runSalomeOld Namespace Reference
def killLocalPort ()
def givenPortKill (port)
def kill_salome (args)
def startGUI (clt)
def startSalome (args, modules_list, modules_root_dir)
def useSalome (args, modules_list, modules_root_dir)
def execScript (script_path)
def registerEnv (args, modules_list, modules_root_dir)
def no_main ()
def addToPidict (args)
def main (exeName=None)
def foreGround (clt, args)
def runSalome ()
Variables
 session = clt.waitNS("/Kernel/Session",SALOME.Session)
 end_time = os.times()
int nbaddi = 0
 anInterp = InterpServer(args)
 port
 killSalomeWithPort
◆ addToPidict()
def runSalomeOld.addToPidict (   args)
Referenced by startSalome().
◆ execScript()
def runSalomeOld.execScript (   script_path)
◆ foreGround()
def runSalomeOld.foreGround (   clt,
  args
◆ givenPortKill()
def runSalomeOld.givenPortKill (   port)
kill servers from a previous SALOME execution, if needed,
on the same CORBA port
References killSalomeWithPort.killMyPort().
Referenced by kill_salome(), and useSalome().
◆ kill_salome()
def runSalomeOld.kill_salome (   args)
Kill servers from previous SALOME executions, if needed;
depending on args 'killall' or 'portkill', kill all executions,
or only execution on the same CORBA port
References givenPortKill(), and killSalome.killAllPorts().
Referenced by main(), and no_main().
◆ killLocalPort()
def runSalomeOld.killLocalPort ( )
on the CORBA port given in args of runSalome
Referenced by useSalome().
◆ main()
def runSalomeOld.main (   exeName = None)
◆ no_main()
def runSalomeOld.no_main ( )
Salome Launch, when embedded in other application
References kill_salome(), and useSalome().
◆ registerEnv()
def runSalomeOld.registerEnv (   args,
  modules_list,
  modules_root_dir
Register args, modules_list, modules_root_dir in a file
for further use, when SALOME is launched embedded in an other application.
References salome_utils.getTmpDir(), and salome_utils.getUserName().
◆ runSalome()
def runSalomeOld.runSalome ( )
◆ startGUI()
def runSalomeOld.startGUI (   clt)
Salome Session Graphic User Interface activation
◆ startSalome()
def runSalomeOld.startSalome (   args,
  modules_list,
  modules_root_dir
◆ useSalome()
def runSalomeOld.useSalome (   args,
  modules_list,
  modules_root_dir
Launch all SALOME servers requested by args,
save list of process, give info to user,
show registered objects in Naming Service.
References killSalomeWithPort.getPiDict(), givenPortKill(), killSalome.killAllPorts(), killLocalPort(), startSalome(), and salome_utils.verbose().
Variable Documentation
◆ anInterp
runSalomeOld.anInterp = InterpServer(args)
◆ end_time
runSalomeOld.end_time = os.times()
◆ killSalomeWithPort
runSalomeOld.killSalomeWithPort
◆ nbaddi
runSalomeOld.nbaddi = 0
◆ port
runSalomeOld.port
◆ session
