Functions | |
| def | getPiDict (port, appname='salome', full=True, hidden=True, hostname=None) |
| def | appliCleanOmniOrbConfig (port) |
| def | shutdownMyPort (port, cleanup=True) |
| def | __killProcesses (processes) |
| def | __killPids (pids) |
| def | __killMyPort (port, filedict) |
| def | __guessPiDictFilename (port) |
| def | killProcessSSL (port, pids_list) |
| def | killMyPort (*ports) |
| def | cleanApplication (port) |
| def | killMyPortSpy (pid, port) |
| def | __checkUnkilledProcesses () |
| def | killUnkilledProcesses () |
| def | main () |
Variables | |
| logger = logging.getLogger() | |
private |
Check all unkilled SALOME processes (internal). :return: list of unkilled processes
References salome_utils.getUserName().
Referenced by killUnkilledProcesses(), and main().
private |
Guess and return pidict file for given `port` (internal). :param port : port number :return pidict file's path
References SalomeOnDemandTK.extension_utilities.format, salome_utils.getHostName(), getPiDict(), Utils_Identity.getShortHostName(), and salome_utils.verbose().
Referenced by killMyPort().
private |
Kill processes for given port (internal). :param port : port number :param filedict : pidict file
References __killPids(), and SalomeOnDemandTK.extension_utilities.format.
Referenced by killMyPort(), and shutdownMyPort().
private |
Kill processes with given `pids`. :param pids : processes IDs
References __killProcesses(), and SalomeOnDemandTK.extension_utilities.format.
Referenced by __killMyPort(), and killProcessSSL().
private |
Terminate and kill all given processes (inernal). :param processes : list of processes, each one is an instance of psutil.Process
Referenced by __killPids(), and killUnkilledProcesses().
| def killSalomeWithPort.appliCleanOmniOrbConfig | ( | port | ) |
Remove omniorb config files related to given `port` in SALOME application:
- ${OMNIORB_USER_PATH}/.omniORB_${USER}_${HOSTNAME}_${NSPORT}.cfg
- ${OMNIORB_USER_PATH}/.omniORB_${USER}_last.cfg
the last is removed only if the link points to the first file.
References SalomeOnDemandTK.extension_utilities.format, salome_utils.generateFileName(), and salome_utils.getUserName().
Referenced by cleanApplication(), killMyPort(), and killProcessSSL().
| def killSalomeWithPort.cleanApplication | ( | port | ) |
Clean application running on the specified port. :param port : port number
References appliCleanOmniOrbConfig(), and getPiDict().
| def killSalomeWithPort.getPiDict | ( | port, | |
appname = 'salome', |
full = True, |
hidden = True, |
hostname = None |
Get path to the file that stores the list of SALOME processes.
This file is located in the user's home directory
and named .<user>_<host>_<port>_SALOME_pidict
where
- <user> is user name
- <host> is host name
- <port> is port number
:param appname : application name (default: 'salome')
:param full : if True, full path to the file is returned,
otherwise only file name is returned
:param hidden : if True, file name is prefixed with . (dot) symbol;
this internal parameter is only used to support
compatibility with older versions of SALOME
:param hostname : host name (if not given, it is auto-detected)
:return pidict file's name or path
References salome_utils.generateFileName(), and salome_utils.getLogDir().
Referenced by __guessPiDictFilename(), addToKillList.addToKillList(), cleanApplication(), killSalome.killAllPorts(), addToKillList.killList(), killMyPort(), killMyPortSpy(), killProcessSSL(), shutdownMyPort(), and runSalomeOld.useSalome().
| def killSalomeWithPort.killMyPort | ( | * | ports | ) |
Kill SALOME session running on the specified port. :param ports : port numbers
References __guessPiDictFilename(), __killMyPort(), appliCleanOmniOrbConfig(), SalomeOnDemandTK.extension_utilities.format, getPiDict(), PortManager.releasePort(), and salome_utils.verbose().
Referenced by runSalomeOld.foreGround(), runSalomeOld.givenPortKill(), killSalome.killAllPorts(), runSalomeOld.killLocalPort(), killMyPortSpy(), and main().
| def killSalomeWithPort.killMyPortSpy | ( | pid, | |
| port | |||
Start daemon process which watches for given process and kills session when process exits. :param pid : process ID :param port : port number (to kill)
References getPiDict(), killMyPort(), and salome_utils.killPid().
Referenced by main().
| def killSalomeWithPort.killProcessSSL | ( | port, | |
| pids_list | |||
Called by runSalome.py after CTRL-C. This method : - Kill all PIDS in pids - update file of pidict
References __killPids(), appliCleanOmniOrbConfig(), SalomeOnDemandTK.extension_utilities.format, and getPiDict().
| def killSalomeWithPort.killUnkilledProcesses | ( | ) |
Kill processes which could remain even after shutdowning SALOME sessions.
References __checkUnkilledProcesses(), and __killProcesses().
Referenced by killSalome.killAllPorts().
| def killSalomeWithPort.main | ( | void | ) |
Main function
References __checkUnkilledProcesses(), SalomeOnDemandTK.extension_utilities.format, killMyPort(), killMyPortSpy(), main(), salomeContextUtils.setOmniOrbUserPath(), and salome_utils.verbose().
| def killSalomeWithPort.shutdownMyPort | ( | port, | |
cleanup = True |
Shutdown SALOME session running on the specified port. :param port : port number :param cleanup : perform additional cleanup actions (kill omniNames, etc.)
References __killMyPort(), SalomeOnDemandTK.extension_utilities.format, salome_utils.generateFileName(), getPiDict(), salome_utils.killOmniNames(), PortManager.releasePort(), and salome_utils.verbose().
| killSalomeWithPort.logger = logging.getLogger() |
