Utils_Identity Namespace Reference
Module to get information about user and version. More...
class  Identity
def getShortHostName ()
def getapplipath ()
def version ()
Variables
 file = open(os.path.join(os.environ["KERNEL_ROOT_DIR"],"bin","salome","VERSION"), "r")
 s = file.readline()
 versnb = string.strip(string.split(s, ":")[1])
string dirname = ".salome_"+versnb
◆ getapplipath()
def Utils_Identity.getapplipath ( )
  Gives short application path (the complete path is $HOME/$APPLI)
◆ getShortHostName()
def Utils_Identity.getShortHostName ( )
gives Hostname without domain extension.
SALOME naming service needs short Hostnames (without domain extension).
HOSTNAME is not always defined in environment,
socket.gethostname() gives short or complete Hostname, depending on
defined aliases.
Referenced by killSalomeWithPort.__guessPiDictFilename(), runSession.configureSession(), SALOME_ContainerPy.SALOME_ContainerPy_i.start_impl(), runSalomeOld.startSalome(), LifeCycleCORBA_SWIGTest.LifeCycleCORBA_SWIGTest.test006_FindOrLoad_Component_LaunchContainerHostname(), and LifeCycleCORBA_SWIGTest.LifeCycleCORBA_SWIGTest.test007_FindOrLoad_Component_SameContainer().
◆ version()
def Utils_Identity.version ( )
  Gives salome version number
Referenced by SALOMEDS_AttributeStudyProperties_i.GetComponentVersion().
Variable Documentation
◆ dirname
string Utils_Identity.dirname = ".salome_"+versnb
◆ file
◆ s
◆ versnb
string Utils_Identity.versnb = string.strip(string.split(s, ":")[1])
