SALOMEDSImpl_AttributeParameter Class Reference
Class: SALOMEDSImpl_AttributeParameter Description : AttributeParameter is a universal container of basic types. More...
#include <SALOMEDSImpl_AttributeParameter.hxx>
Inheritance diagram for SALOMEDSImpl_AttributeParameter:
 SALOMEDSImpl_AttributeParameter ()
void SetInt (const std::string &theID, const int &theValue)
 Function : SetInt Purpose : Associates a integer value with the ID. More...
int GetInt (const std::string &theID)
 Function : GetInt Purpose : Returns a int value associated with the given ID. More...
void SetReal (const std::string &theID, const double &theValue)
 Function : SetReal Purpose : Associates a double value with the ID. More...
double GetReal (const std::string &theID)
 Function : GetReal Purpose : Returns a double value associated with the given ID. More...
void SetString (const std::string &theID, const std::string &theValue)
 Function : SetString Purpose : Associates a string with the ID. More...
std::string GetString (const std::string &theID)
 Function : GetString Purpose : Returns a string associated with the given ID. More...
void SetBool (const std::string &theID, const bool &theValue)
 Function : SetBool Purpose : Associates a bool value with the ID. More...
bool GetBool (const std::string &theID)
 Function : GetBool Purpose : Returns a bool value associated with the ID. More...
void SetRealArray (const std::string &theID, const std::vector< double > &theArray)
 Function : SetRealArray Purpose : Associates an array of double values with the given ID. More...
std::vector< double > GetRealArray (const std::string &theID)
 Function : GetRealArray Purpose : Returns double values associated with the ID. More...
void SetIntArray (const std::string &theID, const std::vector< int > &theArray)
 Function : SetIntArray Purpose : Associates an array of int values with the given ID. More...
std::vector< int > GetIntArray (const std::string &theID)
 Function : GetIntArray Purpose : Returns int values associated with the ID. More...
void SetStrArray (const std::string &theID, const std::vector< std::string > &theArray)
 Function : SetStrArray Purpose : Associates an array of string values with the given ID. More...
std::vector< std::string > GetStrArray (const std::string &theID)
 Function : GetStrArray Purpose : Returns string values associated with the ID. More...
bool IsSet (const std::string &theID, const Parameter_Types theType)
 Function : IsSet Purpose : Returns true if for the ID of given type was assigned
a value in the attribute. More...
bool RemoveID (const std::string &theID, const Parameter_Types theType)
 Function : RemoveID Purpose : Removes a parameter with given ID. More...
SALOMEDSImpl_AttributeParameter * GetFather ()
 Function : GetFather Purpose : Returns a father attribute for this attribute. More...
bool HasFather ()
 Function : HasFather Purpose : Returns True if the attribute has a father attribute. More...
bool IsRoot ()
 Function : IsRoot Purpose : Returns True is the attribute is highest in an hierarchy. More...
std::vector< std::string > GetIDs (const Parameter_Types theType)
 Function : GetIDs Purpose : Returns an array of all ID's of the given type. More...
void Clear ()
 Function : Clear Purpose : Clears the content of the attribute. More...
virtual std::string Save ()
 Function : Save Purpose : Saves a content of the attribute as a string. More...
virtual void Load (const std::string &theValue)
 Function : Load Purpose : Restores the attribute from the string. More...
const std::string & ID () const
 Function : ID Purpose : Rteurns an GUID of the attribute. More...
void Restore (DF_Attribute *with)
 Function : Restore Purpose : Restors the content of the attribute from another. More...
DF_Attribute * NewEmpty () const
void Paste (DF_Attribute *into)
 Function : Paste Purpose : Pastes the content of attribute to another. More...
 ~SALOMEDSImpl_AttributeParameter ()
virtual std::string Type ()
virtual void CheckLocked ()
std::string GetClassType ()
SALOMEDSImpl_SObject GetSObject ()
void SetModifyFlag (int reason=0)
 Set modification flag of the Attribute. More...
DF_Label Label () const
DF_Attribute * FindAttribute (const std::string &theID) const
virtual void AfterAddition ()
virtual void BeforeForget ()
static const std::string & GetID ()
 Function : GetID Purpose : Returns GUID of the attribute. More...
static SALOMEDSImpl_AttributeParameter * Set (const DF_Label &L)
 Function : Set Purpose : Adds an attribute to the label. More...
static std::string Impl_GetType (DF_Attribute *theAttr)
static std::string Impl_GetClassType (DF_Attribute *theAttr)
static void Impl_CheckLocked (DF_Attribute *theAttr)
void Backup ()
std::string _type
DF_LabelNode * _node
std::map< std::string, int > _ints
std::map< std::string, double > _reals
std::map< std::string, std::string > _strings
std::map< std::string, bool > _bools
std::map< std::string, std::vector< double > > _realarrays
std::map< std::string, std::vector< int > > _intarrays
std::map< std::string, std::vector< std::string > > _strarrays
◆ SALOMEDSImpl_AttributeParameter()
SALOMEDSImpl_AttributeParameter::SALOMEDSImpl_AttributeParameter ( )
Referenced by NewEmpty(), and Set().
◆ ~SALOMEDSImpl_AttributeParameter()
SALOMEDSImpl_AttributeParameter::~SALOMEDSImpl_AttributeParameter ( )
◆ AfterAddition()
virtual void DF_Attribute::AfterAddition ( )
Reimplemented in SALOMEDSImpl_AttributeTreeNode.
Referenced by DF_Label::AddAttribute().
◆ Backup()
void DF_Attribute::Backup ( )
Referenced by SALOMEDSImpl_AttributeSequenceOfReal::Add(), SALOMEDSImpl_AttributeSequenceOfInteger::Add(), SALOMEDSImpl_AttributeTarget::Add(), SALOMEDSImpl_AttributeSequenceOfReal::Assign(), SALOMEDSImpl_AttributeSequenceOfInteger::Assign(), SALOMEDSImpl_AttributeTextColor::ChangeArray(), SALOMEDSImpl_AttributeTextHighlightColor::ChangeArray(), SALOMEDSImpl_AttributeStudyProperties::ChangeCreatorName(), SALOMEDSImpl_AttributeSequenceOfReal::ChangeValue(), SALOMEDSImpl_AttributeSequenceOfInteger::ChangeValue(), Clear(), SALOMEDSImpl_AttributeTableOfInteger::Load(), SALOMEDSImpl_AttributeTableOfReal::Load(), SALOMEDSImpl_AttributeTableOfString::Load(), Load(), SALOMEDSImpl_AttributeSequenceOfInteger::Remove(), SALOMEDSImpl_AttributeSequenceOfReal::Remove(), SALOMEDSImpl_AttributeTarget::Remove(), RemoveID(), SALOMEDSImpl_AttributeReference::Set(), SALOMEDSImpl_AttributeFlags::Set(), SetBool(), SALOMEDSImpl_AttributeTableOfReal::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnData(), SALOMEDSImpl_AttributeTableOfString::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfReal::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfString::SetColumnTitle(), SALOMEDSImpl_AttributeStudyProperties::SetComment(), SALOMEDSImpl_AttributeStudyProperties::SetComponentVersion(), SALOMEDSImpl_AttributeStudyProperties::SetCreationMode(), SALOMEDSImpl_AttributeDrawable::SetDrawable(), SALOMEDSImpl_AttributeExpandable::SetExpandable(), SALOMEDSImpl_AttributeTreeNode::SetFather(), SALOMEDSImpl_AttributeTreeNode::SetFirst(), SetInt(), SetIntArray(), SALOMEDSImpl_AttributeStudyProperties::SetModification(), SALOMEDSImpl_AttributeTableOfInteger::SetNbColumns(), SALOMEDSImpl_AttributeTableOfReal::SetNbColumns(), SALOMEDSImpl_AttributeTableOfString::SetNbColumns(), SALOMEDSImpl_AttributeTreeNode::SetNext(), SALOMEDSImpl_AttributePythonObject::SetObject(), SALOMEDSImpl_AttributeOpened::SetOpened(), SALOMEDSImpl_AttributePixMap::SetPixMap(), SALOMEDSImpl_AttributeTreeNode::SetPrevious(), SetReal(), SetRealArray(), SALOMEDSImpl_AttributeTarget::SetRelation(), SALOMEDSImpl_AttributeTableOfReal::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowData(), SALOMEDSImpl_AttributeTableOfString::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowTitle(), SALOMEDSImpl_AttributeTableOfReal::SetRowTitle(), SALOMEDSImpl_AttributeTableOfString::SetRowTitle(), SALOMEDSImpl_AttributeTableOfInteger::SetRowUnit(), SALOMEDSImpl_AttributeTableOfReal::SetRowUnit(), SALOMEDSImpl_AttributeTableOfString::SetRowUnit(), SALOMEDSImpl_AttributeSelectable::SetSelectable(), SetStrArray(), SetString(), SALOMEDSImpl_AttributeTextColor::SetTextColor(), SALOMEDSImpl_AttributeTextHighlightColor::SetTextHighlightColor(), SALOMEDSImpl_AttributeTableOfInteger::SetTitle(), SALOMEDSImpl_AttributeTableOfReal::SetTitle(), SALOMEDSImpl_AttributeTableOfString::SetTitle(), SALOMEDSImpl_AttributeStudyProperties::SetUnits(), SALOMEDSImpl_AttributeReal::SetValue(), SALOMEDSImpl_AttributeInteger::SetValue(), SALOMEDSImpl_AttributeLocalID::SetValue(), SALOMEDSImpl_AttributeComment::SetValue(), SALOMEDSImpl_AttributeString::SetValue(), SALOMEDSImpl_AttributeName::SetValue(), SALOMEDSImpl_AttributeIOR::SetValue(), SALOMEDSImpl_AttributeExternalFileDef::SetValue(), SALOMEDSImpl_AttributeFileType::SetValue(), SALOMEDSImpl_AttributePersistentRef::SetValue(), SALOMEDSImpl_AttributeUserID::SetValue(), and SALOMEDSImpl_AttributeGraphic::SetVisibility().
◆ BeforeForget()
virtual void DF_Attribute::BeforeForget ( )
◆ CheckLocked()
void SALOMEDSImpl_GenericAttribute::CheckLocked ( )
References SALOMEDSImpl_Study::_errorCode, SALOMEDSImpl_Study::GetStudyImpl(), SALOMEDSImpl_Study::IsLocked(), DF_Label::IsNull(), and DF_Attribute::Label().
Referenced by SALOMEDSImpl_AttributeSequenceOfReal::Add(), SALOMEDSImpl_AttributeSequenceOfInteger::Add(), SALOMEDSImpl_AttributeTreeNode::Append(), SALOMEDSImpl_AttributeSequenceOfReal::Assign(), SALOMEDSImpl_AttributeSequenceOfInteger::Assign(), SALOMEDSImpl_AttributeStudyProperties::ChangeCreatorName(), SALOMEDSImpl_AttributeSequenceOfReal::ChangeValue(), SALOMEDSImpl_AttributeSequenceOfInteger::ChangeValue(), SALOMEDS_GenericAttribute::CheckLocked(), SALOMEDSImpl_GenericAttribute::Impl_CheckLocked(), SALOMEDSImpl_AttributeTreeNode::InsertAfter(), SALOMEDSImpl_AttributeTreeNode::InsertBefore(), SALOMEDSImpl_AttributeTreeNode::Prepend(), SALOMEDSImpl_AttributeTableOfReal::PutValue(), SALOMEDSImpl_AttributeTableOfInteger::PutValue(), SALOMEDSImpl_AttributeTableOfString::PutValue(), SALOMEDSImpl_AttributeTreeNode::Remove(), SALOMEDSImpl_AttributeSequenceOfInteger::Remove(), SALOMEDSImpl_AttributeSequenceOfReal::Remove(), SALOMEDSImpl_AttributeTableOfInteger::RemoveValue(), SALOMEDSImpl_AttributeTableOfReal::RemoveValue(), SALOMEDSImpl_AttributeTableOfString::RemoveValue(), SALOMEDSImpl_AttributeReference::Set(), SetBool(), SALOMEDSImpl_AttributeTableOfReal::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnData(), SALOMEDSImpl_AttributeTableOfString::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfReal::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfString::SetColumnTitle(), SALOMEDSImpl_AttributeStudyProperties::SetComment(), SALOMEDSImpl_AttributeStudyProperties::SetComponentVersion(), SALOMEDSImpl_AttributeStudyProperties::SetCreationMode(), SALOMEDSImpl_AttributeDrawable::SetDrawable(), SALOMEDSImpl_AttributeExpandable::SetExpandable(), SALOMEDSImpl_AttributeTreeNode::SetFather(), SALOMEDSImpl_AttributeTreeNode::SetFirst(), SetInt(), SetIntArray(), SALOMEDSImpl_AttributeStudyProperties::SetModification(), SALOMEDSImpl_AttributeTableOfInteger::SetNbColumns(), SALOMEDSImpl_AttributeTableOfReal::SetNbColumns(), SALOMEDSImpl_AttributeTableOfString::SetNbColumns(), SALOMEDSImpl_AttributeTreeNode::SetNext(), SALOMEDSImpl_AttributePythonObject::SetObject(), SALOMEDSImpl_AttributePixMap::SetPixMap(), SALOMEDSImpl_AttributeTreeNode::SetPrevious(), SetReal(), SetRealArray(), SALOMEDSImpl_AttributeTarget::SetRelation(), SALOMEDSImpl_AttributeTableOfReal::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowData(), SALOMEDSImpl_AttributeTableOfString::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowTitle(), SALOMEDSImpl_AttributeTableOfReal::SetRowTitle(), SALOMEDSImpl_AttributeTableOfString::SetRowTitle(), SALOMEDSImpl_AttributeTableOfInteger::SetRowUnit(), SALOMEDSImpl_AttributeTableOfReal::SetRowUnit(), SALOMEDSImpl_AttributeTableOfString::SetRowUnit(), SetStrArray(), SetString(), SALOMEDSImpl_AttributeTextColor::SetTextColor(), SALOMEDSImpl_AttributeTextHighlightColor::SetTextHighlightColor(), SALOMEDSImpl_AttributeTableOfInteger::SetTitle(), SALOMEDSImpl_AttributeTableOfReal::SetTitle(), SALOMEDSImpl_AttributeTableOfString::SetTitle(), SALOMEDSImpl_AttributeStudyProperties::SetUnits(), SALOMEDSImpl_AttributeReal::SetValue(), SALOMEDSImpl_AttributeLocalID::SetValue(), SALOMEDSImpl_AttributeComment::SetValue(), SALOMEDSImpl_AttributeString::SetValue(), SALOMEDSImpl_AttributeName::SetValue(), SALOMEDSImpl_AttributeIOR::SetValue(), SALOMEDSImpl_AttributeExternalFileDef::SetValue(), SALOMEDSImpl_AttributeFileType::SetValue(), SALOMEDSImpl_AttributePersistentRef::SetValue(), SALOMEDSImpl_AttributeUserID::SetValue(), SALOMEDSImpl_AttributeTableOfInteger::SortByColumn(), SALOMEDSImpl_AttributeTableOfReal::SortByColumn(), SALOMEDSImpl_AttributeTableOfString::SortByColumn(), SALOMEDSImpl_AttributeTableOfInteger::SortByRow(), SALOMEDSImpl_AttributeTableOfReal::SortByRow(), SALOMEDSImpl_AttributeTableOfString::SortByRow(), SALOMEDSImpl_AttributeTableOfInteger::SortColumn(), SALOMEDSImpl_AttributeTableOfReal::SortColumn(), SALOMEDSImpl_AttributeTableOfString::SortColumn(), SALOMEDSImpl_AttributeTableOfInteger::SortRow(), SALOMEDSImpl_AttributeTableOfReal::SortRow(), SALOMEDSImpl_AttributeTableOfString::SortRow(), SALOMEDSImpl_AttributeTableOfInteger::SwapCells(), SALOMEDSImpl_AttributeTableOfReal::SwapCells(), SALOMEDSImpl_AttributeTableOfString::SwapCells(), SALOMEDSImpl_AttributeTableOfInteger::SwapColumns(), SALOMEDSImpl_AttributeTableOfReal::SwapColumns(), SALOMEDSImpl_AttributeTableOfString::SwapColumns(), SALOMEDSImpl_AttributeTableOfInteger::SwapRows(), SALOMEDSImpl_AttributeTableOfReal::SwapRows(), and SALOMEDSImpl_AttributeTableOfString::SwapRows().
◆ Clear()
void SALOMEDSImpl_AttributeParameter::Clear ( )
References _bools, _intarrays, _ints, _realarrays, _reals, _strarrays, _strings, DF_Attribute::Backup(), and SALOMEDSImpl_GenericAttribute::SetModifyFlag().
◆ FindAttribute()
◆ GetBool()
bool SALOMEDSImpl_AttributeParameter::GetBool ( const std::string &  theID)
References _bools, IsSet(), and PT_BOOLEAN.
Referenced by SALOMEDSImpl_IParameters::isDumpPython(), main(), and SALOMEDSImplTest::testAttributeParameter().
◆ GetClassType()
std::string SALOMEDSImpl_GenericAttribute::GetClassType ( )
◆ GetFather()
SALOMEDSImpl_AttributeParameter * SALOMEDSImpl_AttributeParameter::GetFather ( )
References DF_Label::Father(), DF_Label::FindAttribute(), GetID(), DF_Label::IsRoot(), and DF_Attribute::Label().
◆ GetID()
const std::string & SALOMEDSImpl_AttributeParameter::GetID ( )
Referenced by GetFather(), SALOMEDSImpl_Study::GetModuleParameters(), HasFather(), ID(), and Set().
◆ GetIDs()
std::vector< std::string > SALOMEDSImpl_AttributeParameter::GetIDs ( const Parameter_Types  theType)
References _bools, _intarrays, _ints, _realarrays, _reals, _strarrays, _strings, PT_BOOLEAN, PT_INTARRAY, PT_INTEGER, PT_REAL, PT_REALARRAY, PT_STRARRAY, and PT_STRING.
Referenced by SALOMEDS_AttributeParameter::GetIDs().
◆ GetInt()
int SALOMEDSImpl_AttributeParameter::GetInt ( const std::string &  theID)
References _ints, IsSet(), and PT_INTEGER.
Referenced by main(), and SALOMEDSImplTest::testAttributeParameter().
◆ GetIntArray()
std::vector< int > SALOMEDSImpl_AttributeParameter::GetIntArray ( const std::string &  theID)
References _intarrays, IsSet(), and PT_INTARRAY.
◆ GetReal()
double SALOMEDSImpl_AttributeParameter::GetReal ( const std::string &  theID)
References _reals, IsSet(), and PT_REAL.
◆ GetRealArray()
std::vector< double > SALOMEDSImpl_AttributeParameter::GetRealArray ( const std::string &  theID)
References _realarrays, IsSet(), and PT_REALARRAY.
◆ GetSObject()
◆ GetStrArray()
◆ GetString()
std::string SALOMEDSImpl_AttributeParameter::GetString ( const std::string &  theID)
◆ HasFather()
bool SALOMEDSImpl_AttributeParameter::HasFather ( )
References DF_Label::Father(), GetID(), DF_Label::IsAttribute(), DF_Label::IsRoot(), and DF_Attribute::Label().
Referenced by IsRoot().
◆ ID()
const std::string & SALOMEDSImpl_AttributeParameter::ID ( ) const
Implements DF_Attribute.
References GetID().
◆ Impl_CheckLocked()
void SALOMEDSImpl_GenericAttribute::Impl_CheckLocked ( DF_Attribute *  theAttr)
◆ Impl_GetClassType()
std::string SALOMEDSImpl_GenericAttribute::Impl_GetClassType ( DF_Attribute *  theAttr)
◆ Impl_GetType()
std::string SALOMEDSImpl_GenericAttribute::Impl_GetType ( DF_Attribute *  theAttr)
◆ IsRoot()
bool SALOMEDSImpl_AttributeParameter::IsRoot ( )
References HasFather().
◆ IsSet()
◆ Label()
DF_Label DF_Attribute::Label ( ) const
◆ Load()
void SALOMEDSImpl_AttributeParameter::Load ( const std::string &  theValue)
Reimplemented from DF_Attribute.
References _bools, _intarrays, _ints, _realarrays, _reals, _strarrays, _strings, DF_Attribute::Backup(), restoreString(), and Utils_Identity::s.
Referenced by SALOME_DriverPy.SALOME_DriverPy_i::LoadASCII(), and main().
◆ NewEmpty()
DF_Attribute * SALOMEDSImpl_AttributeParameter::NewEmpty ( ) const
◆ Paste()
void SALOMEDSImpl_AttributeParameter::Paste ( DF_Attribute *  into)
References DF_Attribute::Restore().
◆ RemoveID()
bool SALOMEDSImpl_AttributeParameter::RemoveID ( const std::string &  theID,
◆ Restore()
void SALOMEDSImpl_AttributeParameter::Restore ( DF_Attribute *  with)
References _bools, _intarrays, _ints, _realarrays, _reals, _strarrays, and _strings.
◆ Save()
std::string SALOMEDSImpl_AttributeParameter::Save ( )
References _bools, _intarrays, _ints, _realarrays, _reals, _strarrays, _strings, and convertString().
Referenced by main(), and SALOME_DriverPy.SALOME_DriverPy_i::SaveASCII().
◆ Set()
SALOMEDSImpl_AttributeParameter * SALOMEDSImpl_AttributeParameter::Set ( const DF_Label &  L)
References DF_Label::AddAttribute(), DF_Label::FindAttribute(), GetID(), and SALOMEDSImpl_AttributeParameter().
◆ SetBool()
void SALOMEDSImpl_AttributeParameter::SetBool ( const std::string &  theID,
const bool &  theValue
References _bools, DF_Attribute::Backup(), SALOMEDSImpl_GenericAttribute::CheckLocked(), and SALOMEDSImpl_GenericAttribute::SetModifyFlag().
◆ SetInt()
void SALOMEDSImpl_AttributeParameter::SetInt ( const std::string &  theID,
const int &  theValue
References _ints, DF_Attribute::Backup(), SALOMEDSImpl_GenericAttribute::CheckLocked(), and SALOMEDSImpl_GenericAttribute::SetModifyFlag().
◆ SetIntArray()
void SALOMEDSImpl_AttributeParameter::SetIntArray ( const std::string &  theID,
const std::vector< int > &  theArray
References _intarrays, DF_Attribute::Backup(), SALOMEDSImpl_GenericAttribute::CheckLocked(), and SALOMEDSImpl_GenericAttribute::SetModifyFlag().
◆ SetModifyFlag()
void SALOMEDSImpl_GenericAttribute::SetModifyFlag ( int  reason = 0)
param reason reason of the modification (by default equal to 0)
References SALOMEDSImpl_GenericAttribute::GetSObject(), SALOMEDSImpl_Study::GetStudyImpl(), DF_Label::IsNull(), DF_Attribute::Label(), SALOMEDSImpl_Study::Modify(), and SALOMEDSImpl_Study::modifySO_Notification().
Referenced by SALOMEDSImpl_AttributeSequenceOfReal::Add(), SALOMEDSImpl_AttributeSequenceOfInteger::Add(), SALOMEDSImpl_AttributeTarget::Add(), SALOMEDSImpl_AttributeTreeNode::Append(), SALOMEDSImpl_AttributeSequenceOfReal::Assign(), SALOMEDSImpl_AttributeSequenceOfInteger::Assign(), SALOMEDSImpl_AttributeTextColor::ChangeArray(), SALOMEDSImpl_AttributeTextHighlightColor::ChangeArray(), SALOMEDSImpl_AttributeSequenceOfReal::ChangeValue(), SALOMEDSImpl_AttributeSequenceOfInteger::ChangeValue(), Clear(), SALOMEDSImpl_AttributeTreeNode::InsertAfter(), SALOMEDSImpl_AttributeTreeNode::InsertBefore(), SALOMEDSImpl_AttributeTreeNode::Prepend(), SALOMEDSImpl_AttributeTableOfReal::PutValue(), SALOMEDSImpl_AttributeTableOfInteger::PutValue(), SALOMEDSImpl_AttributeTableOfString::PutValue(), SALOMEDSImpl_AttributeTreeNode::Remove(), SALOMEDSImpl_AttributeSequenceOfInteger::Remove(), SALOMEDSImpl_AttributeSequenceOfReal::Remove(), SALOMEDSImpl_AttributeTarget::Remove(), RemoveID(), SALOMEDSImpl_AttributeTableOfInteger::RemoveValue(), SALOMEDSImpl_AttributeTableOfReal::RemoveValue(), SALOMEDSImpl_AttributeTableOfString::RemoveValue(), SALOMEDSImpl_AttributeReference::Set(), SetBool(), SALOMEDSImpl_AttributeTableOfReal::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnData(), SALOMEDSImpl_AttributeTableOfString::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfReal::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfString::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnTitles(), SALOMEDSImpl_AttributeTableOfReal::SetColumnTitles(), SALOMEDSImpl_AttributeTableOfString::SetColumnTitles(), SALOMEDSImpl_AttributeDrawable::SetDrawable(), SALOMEDSImpl_AttributeExpandable::SetExpandable(), SALOMEDSImpl_AttributeTreeNode::SetFather(), SALOMEDSImpl_AttributeTreeNode::SetFirst(), SetInt(), SetIntArray(), SALOMEDSImpl_AttributeTableOfInteger::SetNbColumns(), SALOMEDSImpl_AttributeTableOfReal::SetNbColumns(), SALOMEDSImpl_AttributeTableOfString::SetNbColumns(), SALOMEDSImpl_AttributeTreeNode::SetNext(), SALOMEDSImpl_AttributePythonObject::SetObject(), SALOMEDSImpl_AttributePixMap::SetPixMap(), SALOMEDSImpl_AttributeTreeNode::SetPrevious(), SetReal(), SetRealArray(), SALOMEDSImpl_AttributeTarget::SetRelation(), SALOMEDSImpl_AttributeTableOfReal::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowData(), SALOMEDSImpl_AttributeTableOfString::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowTitle(), SALOMEDSImpl_AttributeTableOfReal::SetRowTitle(), SALOMEDSImpl_AttributeTableOfString::SetRowTitle(), SALOMEDSImpl_AttributeTableOfInteger::SetRowTitles(), SALOMEDSImpl_AttributeTableOfReal::SetRowTitles(), SALOMEDSImpl_AttributeTableOfString::SetRowTitles(), SALOMEDSImpl_AttributeTableOfInteger::SetRowUnit(), SALOMEDSImpl_AttributeTableOfReal::SetRowUnit(), SALOMEDSImpl_AttributeTableOfString::SetRowUnit(), SALOMEDSImpl_AttributeTableOfInteger::SetRowUnits(), SALOMEDSImpl_AttributeTableOfReal::SetRowUnits(), SetStrArray(), SetString(), SALOMEDSImpl_AttributeTextColor::SetTextColor(), SALOMEDSImpl_AttributeTextHighlightColor::SetTextHighlightColor(), SALOMEDSImpl_AttributeTableOfInteger::SetTitle(), SALOMEDSImpl_AttributeTableOfReal::SetTitle(), SALOMEDSImpl_AttributeTableOfString::SetTitle(), SALOMEDSImpl_AttributeTreeNode::SetTreeID(), SALOMEDSImpl_AttributeReal::SetValue(), SALOMEDSImpl_AttributeInteger::SetValue(), SALOMEDSImpl_AttributeLocalID::SetValue(), SALOMEDSImpl_AttributeComment::SetValue(), SALOMEDSImpl_AttributeString::SetValue(), SALOMEDSImpl_AttributeName::SetValue(), SALOMEDSImpl_AttributeIOR::SetValue(), SALOMEDSImpl_AttributeExternalFileDef::SetValue(), SALOMEDSImpl_AttributeFileType::SetValue(), SALOMEDSImpl_AttributePersistentRef::SetValue(), SALOMEDSImpl_AttributeUserID::SetValue(), SALOMEDSImpl_AttributeTableOfInteger::SwapCells(), SALOMEDSImpl_AttributeTableOfReal::SwapCells(), and SALOMEDSImpl_AttributeTableOfString::SwapCells().
◆ SetReal()
void SALOMEDSImpl_AttributeParameter::SetReal ( const std::string &  theID,
const double &  theValue
References _reals, DF_Attribute::Backup(), SALOMEDSImpl_GenericAttribute::CheckLocked(), and SALOMEDSImpl_GenericAttribute::SetModifyFlag().
◆ SetRealArray()
void SALOMEDSImpl_AttributeParameter::SetRealArray ( const std::string &  theID,
const std::vector< double > &  theArray
References _realarrays, DF_Attribute::Backup(), SALOMEDSImpl_GenericAttribute::CheckLocked(), and SALOMEDSImpl_GenericAttribute::SetModifyFlag().
◆ SetStrArray()
void SALOMEDSImpl_AttributeParameter::SetStrArray ( const std::string &  theID,
const std::vector< std::string > &  theArray
◆ SetString()
void SALOMEDSImpl_AttributeParameter::SetString ( const std::string &  theID,
◆ Type()
◆ _bools
std::map<std::string, bool> SALOMEDSImpl_AttributeParameter::_bools
◆ _intarrays
std::map< std::string, std::vector<int> > SALOMEDSImpl_AttributeParameter::_intarrays
◆ _ints
std::map<std::string, int> SALOMEDSImpl_AttributeParameter::_ints
◆ _node
◆ _realarrays
std::map< std::string, std::vector<double> > SALOMEDSImpl_AttributeParameter::_realarrays
◆ _reals
std::map<std::string, double> SALOMEDSImpl_AttributeParameter::_reals
◆ _strarrays
std::map< std::string, std::vector<std::string> > SALOMEDSImpl_AttributeParameter::_strarrays
◆ _strings
std::map<std::string, std::string> SALOMEDSImpl_AttributeParameter::_strings
◆ _type
