SALOMEDSImpl_IParameters Class Reference
Class which an interface to store the parameters of the objects. More...
#include <SALOMEDSImpl_IParameters.hxx>
 SALOMEDSImpl_IParameters (SALOMEDSImpl_AttributeParameter *ap)
virtual ~SALOMEDSImpl_IParameters ()
virtual int append (const std::string &listName, const std::string &value)
 Appends a string value to a named list. More...
virtual int nbValues (const std::string &listName)
 Returns a number elements in the list. More...
virtual std::vector< std::string > getValues (const std::string &listName)
 Returns a list of values in the list. More...
virtual std::string getValue (const std::string &listName, int index)
 Returns a value with given index, where index is in range [0:nbValues-1]. More...
virtual std::vector< std::string > getLists ()
 Returns a list all entries lists. More...
virtual void setParameter (const std::string &entry, const std::string &parameterName, const std::string &value)
 Sets a new named parameter value for the given entry. More...
virtual std::string getParameter (const std::string &entry, const std::string &parameterName)
 Gets a named parameter value for the given entry. More...
virtual void setIdParameter (const std::string &entry, const std::string &value)
 Sets an id parameter value for the given entry. More...
virtual std::string getIdParameter (const std::string &entry)
 Gets an id parameter value for the given entry. More...
virtual std::vector< std::string > getAllParameterNames (const std::string &entry)
 Returns all parameter names of the given entry. More...
virtual std::vector< std::string > getAllParameterValues (const std::string &entry)
 Returns all parameter values of the given entry. More...
virtual int getNbParameters (const std::string &entry)
 Returns a number of parameters of the given entry. More...
virtual std::vector< std::string > getEntries ()
 Returns a list all entries. More...
 Sets a global named property value. More...
 Gets a value of global named property. More...
virtual std::vector< std::string > getProperties ()
 Returns a list all properties. More...
virtual std::string decodeEntry (const std::string &entry)
 Returns decoded entry that is an absolute entry. More...
static bool isDumpPython (SALOMEDSImpl_Study *study, const std::string &theID="")
 Returns whether there is the dumping visual parameters. More...
static int getLastSavePoint (SALOMEDSImpl_Study *study, const std::string &theID="")
 Returns an ID of the last save point. More...
static std::string getStudyScript (SALOMEDSImpl_Study *study, int savePoint, const std::string &theID="")
 Returns a Python script for the study, which sets up visual parameters. More...
static std::string getDefaultScript (SALOMEDSImpl_Study *study, const std::string &moduleName, const std::string &shift, const std::string &theID="")
 Returns a default Python script that sets up visual parameters for the given module shift is a string that contain spaces to make valid Python script indentation. More...
static std::string getDefaultVisualComponent ()
 Returns a default name of the component where the visula parameters are stored. More...
SALOMEDSImpl_AttributeParameter * _ap
std::map< std::string, std::string > _compNames
◆ SALOMEDSImpl_IParameters()
SALOMEDSImpl_IParameters::SALOMEDSImpl_IParameters ( SALOMEDSImpl_AttributeParameter *  ap)
References _ap.
Referenced by getDefaultScript().
◆ ~SALOMEDSImpl_IParameters()
SALOMEDSImpl_IParameters::~SALOMEDSImpl_IParameters ( )
References _compNames.
◆ append()
int SALOMEDSImpl_IParameters::append ( const std::string &  listName,
const std::string &  value
◆ decodeEntry()
std::string SALOMEDSImpl_IParameters::decodeEntry ( const std::string &  entry)
◆ getAllParameterNames()
std::vector< std::string > SALOMEDSImpl_IParameters::getAllParameterNames ( const std::string &  entry)
References _ap, SALOMEDSImpl_AttributeParameter::GetStrArray(), SALOMEDSImpl_AttributeParameter::IsSet(), and PT_STRARRAY.
◆ getAllParameterValues()
std::vector< std::string > SALOMEDSImpl_IParameters::getAllParameterValues ( const std::string &  entry)
◆ getDefaultScript()
std::string SALOMEDSImpl_IParameters::getDefaultScript ( SALOMEDSImpl_Study *  study,
const std::string &  moduleName,
const std::string &  shift,
const std::string &  theID = ""
◆ getDefaultVisualComponent()
std::string SALOMEDSImpl_IParameters::getDefaultVisualComponent ( )
Referenced by getDefaultScript(), SALOMEDS_DriverFactory_i::GetDriverByType(), getLastSavePoint(), getStudyScript(), isDumpPython(), and SALOMEDSImpl_Study::Open().
◆ getEntries()
std::vector< std::string > SALOMEDSImpl_IParameters::getEntries ( )
◆ getIdParameter()
std::string SALOMEDSImpl_IParameters::getIdParameter ( const std::string &  entry)
References _ap, _PT_ID_, SALOMEDSImpl_AttributeParameter::GetStrArray(), SALOMEDSImpl_AttributeParameter::IsSet(), and PT_STRARRAY.
◆ getLastSavePoint()
◆ getLists()
std::vector< std::string > SALOMEDSImpl_IParameters::getLists ( )
◆ getNbParameters()
int SALOMEDSImpl_IParameters::getNbParameters ( const std::string &  entry)
< TODO: conversion from size_t to int
◆ getParameter()
std::string SALOMEDSImpl_IParameters::getParameter ( const std::string &  entry,
const std::string &  parameterName
◆ getProperties()
std::vector< std::string > SALOMEDSImpl_IParameters::getProperties ( )
◆ getProperty()
std::string SALOMEDSImpl_IParameters::getProperty ( const std::string &  name)
◆ getStudyScript()
std::string SALOMEDSImpl_IParameters::getStudyScript ( SALOMEDSImpl_Study *  study,
int  savePoint,
References pythfilter::dump(), SALOMEDSImpl_Study::GetCommonParameters(), getDefaultVisualComponent(), getLists(), getProperties(), getProperty(), and getValues().
Referenced by SALOMEDSImpl_Study::DumpStudy().
◆ getValue()
std::string SALOMEDSImpl_IParameters::getValue ( const std::string &  listName,
int  index
References _ap, SALOMEDSImpl_AttributeParameter::GetStrArray(), python_test_driver::index, SALOMEDSImpl_AttributeParameter::IsSet(), and PT_STRARRAY.
◆ getValues()
std::vector< std::string > SALOMEDSImpl_IParameters::getValues ( const std::string &  listName)
◆ isDumpPython()
bool SALOMEDSImpl_IParameters::isDumpPython ( SALOMEDSImpl_Study *  study,
◆ nbValues()
int SALOMEDSImpl_IParameters::nbValues ( const std::string &  listName)
◆ setIdParameter()
void SALOMEDSImpl_IParameters::setIdParameter ( const std::string &  entry,
◆ setParameter()
void SALOMEDSImpl_IParameters::setParameter ( const std::string &  entry,
const std::string &  parameterName,
◆ setProperty()
void SALOMEDSImpl_IParameters::setProperty ( const std::string &  name,
◆ _ap
◆ _compNames
std::map<std::string, std::string> SALOMEDSImpl_IParameters::_compNames
