python_test_driver Namespace Reference
class  TimeoutException
def runTestBegin (command)
def runTestEffective (process)
def processResult (res, out, err)
def installHook (hook=None)
def timeoutHandler (signum, frame)
Variables
 subPIDToKill = None
 timeout_delay = sys.argv[1]
 args = sys.argv[2:]
 index = args.index('--hook')
 hook = args.pop(index)
 _
 ext
list test_and_args = [sys.executable] + args
 timeout_sec = abs(int(timeout_delay)-10)
 timer = Timer(timeout_sec, timeoutHandler)
int res = 1
def process = runTestBegin(test_and_args)
 out
 err
◆ installHook()
def python_test_driver.installHook (   hook = None)
Install custome hook to process test result.
◆ processResult()
def python_test_driver.processResult (   res,
  out,
  err
◆ runTestBegin()
def python_test_driver.runTestBegin (   command)
◆ runTestEffective()
def python_test_driver.runTestEffective (   process)
◆ timeoutHandler()
def python_test_driver.timeoutHandler (   signum,
  frame
Variable Documentation
◆ _
python_test_driver._
◆ args
python_test_driver.args = sys.argv[2:]
◆ err
◆ ext
python_test_driver.ext
◆ hook
python_test_driver.hook = args.pop(index)
◆ index
◆ out
python_test_driver.out
◆ process
def python_test_driver.process = runTestBegin(test_and_args)
◆ res
def python_test_driver.res = 1
◆ subPIDToKill
def python_test_driver.subPIDToKill = None
◆ test_and_args
python_test_driver.test_and_args = [sys.executable] + args
◆ timeout_delay
python_test_driver.timeout_delay = sys.argv[1]
◆ timeout_sec
python_test_driver.timeout_sec = abs(int(timeout_delay)-10)
◆ timer
python_test_driver.timer = Timer(timeout_sec, timeoutHandler)
Referenced by container_common_main(), and main().
