ConnectionManager_i Class Reference
This class implements the interface Engines::ConnectionManager. More...
#include <ConnectionManager_i.hxx>
Inheritance diagram for ConnectionManager_i:
struct  connection_infos
 ConnectionManager_i (CORBA::ORB_ptr orb)
virtual ~ConnectionManager_i ()
Engines::ConnectionManager::connectionId connect (Engines::DSC_ptr uses_component, const char *uses_port_name, Engines::DSC_ptr provides_component, const char *provides_port_name)
 CORBA method : connect two ports of two components. More...
void disconnect (Engines::ConnectionManager::connectionId id, Engines::DSC::Message message)
 CORBA method : releases a connection performed with ConnectionManager_i::connect. More...
void ShutdownWithExit ()
 Shutdown the ConnectionManager process. More...
CORBA::Long getPID ()
 Returns the PID of the connection manager. More...
Static Public Attributes
static const char * _ConnectionManagerNameInNS = "/ConnectionManager"
CORBA::ORB_var _orb
SALOME_NamingService * _NS
Private Types
typedef std::map< Engines::ConnectionManager::connectionId, connection_infos * > ids_type
typedef std::map< Engines::ConnectionManager::connectionId, connection_infos * >::iterator ids_it_type
ids_type ids
ids_it_type ids_it
int current_id
pthread_mutex_t mutex
◆ ids_it_type
◆ ids_type
◆ ConnectionManager_i()
ConnectionManager_i::ConnectionManager_i ( CORBA::ORB_ptr  orb)
◆ ~ConnectionManager_i()
ConnectionManager_i::~ConnectionManager_i ( )
References _NS.
◆ connect()
Engines::ConnectionManager::connectionId ConnectionManager_i::connect ( Engines::DSC_ptr  uses_component,
const char *  uses_port_name,
const char *  provides_port_name
◆ disconnect()
◆ getPID()
CORBA::Long ConnectionManager_i::getPID ( )
◆ ShutdownWithExit()
void ConnectionManager_i::ShutdownWithExit ( )
◆ _ConnectionManagerNameInNS
const char * ConnectionManager_i::_ConnectionManagerNameInNS = "/ConnectionManager"
◆ _NS
SALOME_NamingService* ConnectionManager_i::_NS
◆ _orb
◆ current_id
int ConnectionManager_i::current_id
Referenced by connect(), and ConnectionManager_i().
◆ ids
ids_type ConnectionManager_i::ids
◆ ids_it
ids_it_type ConnectionManager_i::ids_it
Referenced by disconnect(), and ShutdownWithExit().
◆ mutex
pthread_mutex_t ConnectionManager_i::mutex
