SALOME_NamingServicePy.SALOME_NamingServicePy_i Class Reference
def __init__ (self, orb=None, steps=240, spy=False)
def Register (self, ObjRef, Path)
def Resolve (self, Path)
def Resolve_Dir (self, Path)
def Create_Directory (self, ObjRef, Path)
def Destroy_Name (self, Path)
def Destroy_FullDirectory (self, Path)
Static Private Attributes
 _orb = None
 _root_context = None
 _current_context = None
 _obj = None
  A class to manage SALOME naming service from python code
◆ __init__()
def SALOME_NamingServicePy.SALOME_NamingServicePy_i.__init__ (   self,
  orb = None,
  steps = 240,
  spy = False
Standard Constructor, with ORB reference.
Initializes the naming service root context
References SALOME_NamingService._current_context, SALOME_NamingServicePy.SALOME_NamingServicePy_i._current_context, Engines_Component_i._orb, SALOME_ComponentPy.SALOME_ComponentPy_Gen_i._orb, SALOME_Container.SALOME_Container_Abstract_i._orb, Abstract_Engines_Container_i._orb, SALOME_ContainerManager._orb, SALOME_ContainerPy.SALOME_ContainerPy_Gen_i._orb, SALOME_PyNode.ExchangeContextUsingTCP._orb, ConnectionManager_i._orb, Param_Double_Port_uses_i._orb, SALOME_Launcher._orb, LifeCycleCORBATest._orb, Logger._orb, SALOME_ModuleCatalogImpl._orb, SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy._orb, SALOME_NamingService._orb, SALOME_NamingServicePy.SALOME_NamingServicePy_i._orb, NamingServiceTest._orb, Engines_Parallel_Component_i._orb, Engines_Parallel_Container_i._orb, RegistryService._orb, SALOME_ResourcesManager._orb, SALOMEDS_ChildIterator_i._orb, SALOMEDS_Driver_i._orb, SALOMEDS_DriverFactory_i._orb, SALOMEDS_GenericAttribute_i._orb, SALOMEDS_SComponentIterator_i._orb, SALOMEDS_SObject._orb, SALOMEDS_SObject_i._orb, SALOMEDS_Study._orb, SALOMEDS::Notifier._orb, SALOMEDS::GenObjRegister._orb, SALOMEDS_Study_i._orb, SALOMEDS_StudyBuilder._orb, SALOMEDS_StudyBuilder_i._orb, SALOMEDS_UseCaseBuilder_i._orb, SALOMEDS_UseCaseIterator_i._orb, SALOMEDSTest._orb, SALOMESDS::DataScopeKiller._orb, SALOMESDS::DataScopeServerBase._orb, SALOMESDS::DataServerManager._orb, ORB_INIT._orb, SALOME_NamingService._root_context, SALOME_NamingServicePy.SALOME_NamingServicePy_i._root_context, and MESSAGE.
◆ Create_Directory()
def SALOME_NamingServicePy.SALOME_NamingServicePy_i.Create_Directory (   self,
  ObjRef,
  Path
◆ Destroy_FullDirectory()
def SALOME_NamingServicePy.SALOME_NamingServicePy_i.Destroy_FullDirectory (   self,
  Path
 ns.Destroy_FullDirectory(Path)
  remove recursively a directory
References SALOME_NamingService._root_context, and SALOME_NamingServicePy.SALOME_NamingServicePy_i._root_context.
◆ Destroy_Name()
def SALOME_NamingServicePy.SALOME_NamingServicePy_i.Destroy_Name (   self,
  Path
 ns.Destroy_Name(Path)
  remove a name in naming service
◆ Register()
def SALOME_NamingServicePy.SALOME_NamingServicePy_i.Register (   self,
  ObjRef,
  Path
◆ Resolve()
◆ Resolve_Dir()
◆ _current_context
◆ _obj
◆ _orb
◆ _root_context
