SALOME_ModuleCatalogImpl Class Reference
#include <SALOME_ModuleCatalog_impl.hxx>
Inheritance diagram for SALOME_ModuleCatalogImpl:
class  Private
 SALOME_ModuleCatalogImpl (int artgc, char **argv, CORBA::ORB_ptr orb=NULL)
 standard constructor More...
virtual ~SALOME_ModuleCatalogImpl ()
 standard destructor More...
virtual SALOME_ModuleCatalog::ListOfComputers * GetComputerList ()
 method to get a component list More...
virtual SALOME_ModuleCatalog::ListOfTypeDefinition * GetTypes ()
 method to get the list of all types of the catalog More...
virtual char * GetPathPrefix (const char *machinename)
 method to get the PathPrefix of a computer More...
virtual void ImportXmlCatalogFile (const char *xmlFileName)
 method to read a XML file and import new components into the component list More...
virtual SALOME_ModuleCatalog::ListOfComponents * GetComponentList ()
virtual SALOME_ModuleCatalog::ListOfIAPP_Affich * GetComponentIconeList ()
 method to get a component list of component name and component icone More...
virtual SALOME_ModuleCatalog::ListOfComponents * GetTypedComponentList (SALOME_ModuleCatalog::ComponentType component_type)
 method to get a component list of a wanted type More...
virtual SALOME_ModuleCatalog::Acomponent_ptr GetComponent (const char *componentname)
 method to get a component More...
virtual SALOME_ModuleCatalog::ComponentDef * GetComponentInfo (const char *name)
 method to get a component description More...
void ping ()
 method to check the server is alive More...
CORBA::Long getPID ()
 get PID of the server More...
void ShutdownWithExit ()
 shutdown server and exit More...
void shutdown ()
 shutdown server More...
Static Public Attributes
static const char ENTRY_IN_NS [] = "/Kernel/ModulCatalog"
virtual bool _parseArguments (int argc, char **argv, char **_general, char **_personal)
 method to parse arguments to get general and personal catalog files More...
CORBA::ORB_ptr _orb
Private * myPrivate
◆ SALOME_ModuleCatalogImpl()
◆ ~SALOME_ModuleCatalogImpl()
SALOME_ModuleCatalogImpl::~SALOME_ModuleCatalogImpl ( )
standard destructor
References MESSAGE, and myPrivate.
◆ _parseArguments()
bool SALOME_ModuleCatalogImpl::_parseArguments ( int  argc,
char **  argv,
char **  _general,
char **  _personal
privatevirtual
argcint arguments
argvchar** arguments
_generalchar** arguments
true if parsing is OK
References envSalome::argv.
Referenced by SALOME_ModuleCatalogImpl().
◆ GetComponent()
SALOME_ModuleCatalog::Acomponent_ptr SALOME_ModuleCatalogImpl::GetComponent ( const char *  componentname)
componentnameconst char* arguments
the wanted component
References SALOME_ModuleCatalogImpl::Private::duplicate(), SALOME_ModuleCatalogImpl::Private::findComponent(), MESSAGE, myPrivate, pythfilter::name, and Utils_Identity::s.
◆ GetComponentIconeList()
SALOME_ModuleCatalog::ListOfIAPP_Affich * SALOME_ModuleCatalogImpl::GetComponentIconeList ( )
a list of couple (component name, component icone)
References SALOME_ModuleCatalogImpl::Private::_general_module_list, SALOME_ModuleCatalogImpl::Private::_personal_module_list, MESSAGE, and myPrivate.
◆ GetComponentInfo()
SALOME_ModuleCatalog::ComponentDef * SALOME_ModuleCatalogImpl::GetComponentInfo ( const char *  name)
the wanted component description
References SALOME_ModuleCatalogImpl::Private::duplicate(), SALOME_ModuleCatalogImpl::Private::findComponent(), myPrivate, pythfilter::name, and Utils_Identity::s.
◆ GetComponentList()
SALOME_ModuleCatalog::ListOfComponents * SALOME_ModuleCatalogImpl::GetComponentList ( )
◆ GetComputerList()
SALOME_ModuleCatalog::ListOfComputers * SALOME_ModuleCatalogImpl::GetComputerList ( )
a component list
◆ GetPathPrefix()
char * SALOME_ModuleCatalogImpl::GetPathPrefix ( const char *  machinename)
If the wanted computer doesn't exist, the Notfound exception is thrown
machinenameconst char* arguments
the prefix path
References SALOME_ModuleCatalogImpl::Private::_general_path_list, SALOME_ModuleCatalogImpl::Private::_personal_path_list, MESSAGE, and myPrivate.
◆ getPID()
CORBA::Long SALOME_ModuleCatalogImpl::getPID ( )
◆ GetTypedComponentList()
◆ GetTypes()
SALOME_ModuleCatalog::ListOfTypeDefinition * SALOME_ModuleCatalogImpl::GetTypes ( )
◆ ImportXmlCatalogFile()
void SALOME_ModuleCatalogImpl::ImportXmlCatalogFile ( const char *  xmlFileName)
If the XML file doesn't exist or is not readable, the Notfound exception is thrown
constchar* xmlFileName
References SALOME_ModuleCatalogImpl::Private::_parse_xml_file(), SALOME_ModuleCatalogImpl::Private::_personal_module_list, SALOME_ModuleCatalogImpl::Private::_personal_path_list, SALOME_ModuleCatalogImpl::Private::_typeList, SALOME_ModuleCatalogImpl::Private::_typeMap, Utils_Identity::file, and myPrivate.
◆ ping()
void SALOME_ModuleCatalogImpl::ping ( )
◆ shutdown()
void SALOME_ModuleCatalogImpl::shutdown ( )
shutdown server
References _orb.
◆ ShutdownWithExit()
void SALOME_ModuleCatalogImpl::ShutdownWithExit ( )
◆ _orb
◆ ENTRY_IN_NS
const char SALOME_ModuleCatalogImpl::ENTRY_IN_NS = "/Kernel/ModulCatalog"
◆ myPrivate
