SALOME_ModuleCatalog Module Reference
The main package of interfaces used for the module catalog in SALOME application. More...
interface  Acomponent
 This interface provides the common functionality information of corresponding component. More...
struct  ComponentDef
 Description of a component. More...
struct  DefinitionInterface
 This struct contains fields defining each interface. More...
struct  IAPP_Affich
 This struct contains GUI elements used for representation of the module in IAPP component. More...
struct  MemberDefinition
 struct to define members of a Struc TypeKind More...
interface  ModuleCatalog
 Module catalog interface More...
exception  NotFound
 This exception is raised when a component, a service or a pathPrefix is not found. More...
struct  PathPrefix
 PathPrefix : association of a machine name and a path to a component. More...
struct  Service
 This struct contains fields defining each service. More...
struct  ServicesDataStreamParameter
 struct to define datastream ports More...
struct  ServicesParameter
 This struct contains fields defining the parameter of the service. More...
struct  TypeDefinition
 Struct to get the definition of types used in Salome catalogs. More...
Typedefs
typedef sequence< ServicesParameter > ListOfServicesParameter
 The list of the parameters of service. More...
typedef sequence< ServicesDataStreamParameter > ListOfServicesDataStreamParameter
 The list of datastream parameters of service. More...
typedef sequence< string > ListOfString
 a string list More...
typedef sequence< MemberDefinition > ListOfMemberDefinition
 List of member definitions in a structure. More...
typedef sequence< TypeDefinition > ListOfTypeDefinition
 list of type definitions More...
typedef sequence< Service > ListOfInterfaceService
 List of services of the interface. More...
typedef sequence< string > ListOfServices
 List of services. More...
typedef sequence< DefinitionInterface > ListOfDefInterface
 List of interface definitions. More...
typedef sequence< string > ListOfInterfaces
 List of interface names. More...
typedef sequence< PathPrefix > PathPrefixes
 List of path prefixes. More...
typedef sequence< string > ListOfComponents
 List of component names. More...
typedef sequence< string > ListOfComputers
 List of computer names. More...
typedef sequence< IAPP_Affich > ListOfIAPP_Affich
 List of pair GUI elements (component name, component icone) More...
Enumerations
enum  ComponentType {
  GEOM , MESH , Med , SOLVER ,
  DATA , VISU , SUPERV , OTHER
 This enumeration contains a current set of definitions of the components integrated into SALOME application. More...
enum  DataStreamDependency { DATASTREAM_UNDEFINED , DATASTREAM_TEMPORAL , DATASTREAM_ITERATIVE }
 enumeration to define datastream ports dependency More...
enum  TypeKind {
  NONE , Dble , Int , Str ,
  Bool , Objref , Seq , Array ,
  Struc
 enumeration to define data types used by services More...
enum  ImplType { SO , PY , EXE , CEXE }
 Component implementation type. More...
Module catalog allows to manage components of SALOME application, to call specified in the xml files interfaces with the help of AComponent interface.
Typedef Documentation
◆ ListOfComponents
typedef sequence<string> SALOME_ModuleCatalog::ListOfComponents
◆ ListOfComputers
typedef sequence<string> SALOME_ModuleCatalog::ListOfComputers
◆ ListOfDefInterface
◆ ListOfIAPP_Affich
◆ ListOfInterfaces
typedef sequence<string> SALOME_ModuleCatalog::ListOfInterfaces
◆ ListOfInterfaceService
◆ ListOfMemberDefinition
◆ ListOfServices
typedef sequence<string> SALOME_ModuleCatalog::ListOfServices
List of services.
◆ ListOfServicesDataStreamParameter
◆ ListOfServicesParameter
◆ ListOfString
typedef sequence<string> SALOME_ModuleCatalog::ListOfString
a string list
◆ ListOfTypeDefinition
◆ PathPrefixes
◆ ComponentType
GEOM
Module GEOM.
MESH
Module MESH.
Med
Module Med.
SOLVER
Module of SOLVER type.
DATA
Module DATA.
VISU
Module VISU.
SUPERV
Module SUPERVISION.
OTHER
Any other type of module.
◆ DataStreamDependency
dependency not defined
DATASTREAM_TEMPORAL
time dependency
iterative dependency
◆ ImplType
SO
component implemented as a dynamic library loadable with dlopen
PY
component implemented as a python module loadable with import
EXE
component implemented as an executable
CEXE
component to be loaded by a container which executable is given in the catalog
◆ TypeKind
NONE
Dble
a double
Int
an integer
Str
a string
Bool
a boolean
Objref
an object reference
Seq
a sequence of a content type
Array
an array
Struc
a structure with named members
