SALOME_ModuleCatalog::Service Struct Reference
This struct contains fields defining each service. More...
import"SALOME_ModuleCatalog.idl";
Data Fields
string ServiceName
 Name of the service. More...
ListOfServicesParameter ServiceinParameter
 List of input parameters of the services. More...
ListOfServicesParameter ServiceoutParameter
 List of output parameters of the services. More...
ListOfServicesDataStreamParameter ServiceinDataStreamParameter
ListOfServicesDataStreamParameter ServiceoutDataStreamParameter
boolean Servicebydefault
 True if the service is taken with its default fields. More...
boolean TypeOfNode
 True is the service is a factory node. More...
◆ Servicebydefault
boolean SALOME_ModuleCatalog::Service::Servicebydefault
Referenced by SALOME_ModuleCatalogImpl::Private::duplicate(), and SALOME_ModuleCatalog_AcomponentImpl::duplicate().
◆ ServiceinDataStreamParameter
ListOfServicesDataStreamParameter SALOME_ModuleCatalog::Service::ServiceinDataStreamParameter
◆ ServiceinParameter
ListOfServicesParameter SALOME_ModuleCatalog::Service::ServiceinParameter
◆ ServiceName
string SALOME_ModuleCatalog::Service::ServiceName
◆ ServiceoutDataStreamParameter
ListOfServicesDataStreamParameter SALOME_ModuleCatalog::Service::ServiceoutDataStreamParameter
◆ ServiceoutParameter
ListOfServicesParameter SALOME_ModuleCatalog::Service::ServiceoutParameter
◆ TypeOfNode
boolean SALOME_ModuleCatalog::Service::TypeOfNode
Otherwise, it's a compute node.
