SALOME_ModuleCatalog.idl
23// File : SALOME_ModuleCatalog.idl
24// Author : Estelle Deville
25// $Header$
26//
38{
49 OTHER
50 } ;
53 {
56 } ;
57
63 } ;
64
67 {
71 } ;
72
74 typedef sequence<ServicesParameter> ListOfServicesParameter;
76 typedef sequence<ServicesDataStreamParameter> ListOfServicesDataStreamParameter;
77
79 typedef sequence<string> ListOfString;
80
83 {
86 Int ,
87 Str ,
90 Seq ,
92 Struc
93 };
94
97 {
98 string name;
99 string type;
100 };
102 typedef sequence<MemberDefinition> ListOfMemberDefinition;
103
106 {
107 string name;
109 string id;
110 string content;
113 };
114
116 typedef sequence<TypeDefinition> ListOfTypeDefinition;
117
119 struct Service
120 {
121 string ServiceName;
127 boolean TypeOfNode;
128 } ;
130 typedef sequence<Service> ListOfInterfaceService;
132 typedef sequence<string> ListOfServices ;
135 {
138 } ;
140 typedef sequence<DefinitionInterface> ListOfDefInterface ;
142 typedef sequence<string> ListOfInterfaces ;
143
147 struct PathPrefix {
148 string machine;
149 string path;
150 };
151
153 typedef sequence<PathPrefix> PathPrefixes;
154
156 enum ImplType {
160 CEXE
161 } ;
162
165 {
167 string name;
168 string username;
170 string implname;
171 string icon;
175 };
176
178 typedef sequence<string> ListOfComponents ;
180 typedef sequence<string> ListOfComputers ;
183 {
184 string modulename;
186 string moduleicone;
189 };
194 typedef sequence<IAPP_Affich> ListOfIAPP_Affich ;
195
197 exception NotFound
198 {
199 string what ;
200 } ;
201
206 interface Acomponent
207 {
213
220 DefinitionInterface GetInterface(in string interfacename) raises(NotFound);
221
228 ListOfServices GetServiceList(in string interfacename) raises(NotFound);
229
230
238 Service GetService(in string interfacename,
239 in string servicename) raises(NotFound);
240
247 Service GetDefaultService(in string interfacename) raises(NotFound);
248
255 string GetPathPrefix(in string machinename) raises(NotFound);
256
261 readonly attribute string constraint ;
262
265 readonly attribute string componentname;
266
269 readonly attribute string componentusername;
270
273 readonly attribute ComponentType component_type ;
274
277 readonly attribute string component_icone;
278
283 readonly attribute ImplType implementation_type;
289 readonly attribute string implementation_name;
290 } ;
291
297 {
300 void ping();
301
304 long getPID();
305
308 oneway void ShutdownWithExit();
309
313
317
319 string GetPathPrefix(in string machinename) raises(NotFound);
320
323
328
332
335 Acomponent GetComponent(in string componentname) raises(NotFound);
336
339 ComponentDef GetComponentInfo(in string componentName) raises(NotFound);
340
345 void ImportXmlCatalogFile(in string filename) raises(NotFound);
346
349 void shutdown();
350 } ;
351};
@ MESH
Definition: SALOME_ModuleCatalog_Parser.hxx:45
@ SUPERV
@ VISU
@ Med
@ DATA
@ GEOM
@ OTHER
@ SOLVER
This exception is raised when a component, a service or a pathPrefix is not found.
Definition: SALOME_ModuleCatalog.idl:198
string what
Indicates if it's a component, a service or a % pathPrefix.
Definition: SALOME_ModuleCatalog.idl:199
This interface provides the common functionality information of corresponding component.
Definition: SALOME_ModuleCatalog.idl:207
Get the type of the component.
Definition: SALOME_ModuleCatalog.idl:273
Service GetService(in string interfacename, in string servicename)
Get a service of an interface of the component.
ListOfInterfaces GetInterfaceList()
Get the list of interface names of the component.
Get the user name of the component.
Definition: SALOME_ModuleCatalog.idl:269
Get an interface of the component.
Get the constraint affected to the component.
Definition: SALOME_ModuleCatalog.idl:261
Get the default service of an interface of the component.
Get the implementation type of the component.
Definition: SALOME_ModuleCatalog.idl:283
Get the implementation name of the component.
Definition: SALOME_ModuleCatalog.idl:289
Get the component name.
Definition: SALOME_ModuleCatalog.idl:265
Get the list of service names of an interface belonging to the component.
Get the icone of the component (for IAPP)
Definition: SALOME_ModuleCatalog.idl:277
Get the prefix path of the computer containing the component.
Module catalog interface
Definition: SALOME_ModuleCatalog.idl:297
Read a xml file and import new components from this file.
void shutdown()
Shutdown the module catalog server.
void ping()
ping the ModuleCatalog server
Get one component of the catalog.
long getPID()
Returns the PID of the ModuleCatalog server.
Shutdown the ModuleCatalog server.
ListOfComputers GetComputerList()
Get a list of computer names of the catalog.
Get the PathPrefix of a computer.
ListOfIAPP_Affich GetComponentIconeList()
Get a list of pair GUI elements (component name, component icone) used for representation of the modu...
ListOfComponents GetComponentList()
Get a list of component names of the catalog.
Get the description of a component of the catalog.
ListOfTypeDefinition GetTypes()
Get the types of the catalog.
ListOfComponents GetTypedComponentList(in ComponentType _component_type)
Get a list of component names of a particular type, which belong to this catalog.
The main package of interfaces used for the module catalog in SALOME application.
Definition: SALOME_ModuleCatalog.idl:38
sequence< TypeDefinition > ListOfTypeDefinition
list of type definitions
Definition: SALOME_ModuleCatalog.idl:116
sequence< string > ListOfString
a string list
Definition: SALOME_ModuleCatalog.idl:79
sequence< ServicesParameter > ListOfServicesParameter
The list of the parameters of service.
Definition: SALOME_ModuleCatalog.idl:74
ImplType
Component implementation type.
Definition: SALOME_ModuleCatalog.idl:156
@ SO
component implemented as a dynamic library loadable with dlopen
Definition: SALOME_ModuleCatalog.idl:157
@ PY
component implemented as a python module loadable with import
Definition: SALOME_ModuleCatalog.idl:158
@ CEXE
component to be loaded by a container which executable is given in the catalog
Definition: SALOME_ModuleCatalog.idl:160
@ EXE
component implemented as an executable
Definition: SALOME_ModuleCatalog.idl:159
TypeKind
enumeration to define data types used by services
Definition: SALOME_ModuleCatalog.idl:83
@ Objref
an object reference
Definition: SALOME_ModuleCatalog.idl:89
@ Struc
a structure with named members
Definition: SALOME_ModuleCatalog.idl:92
@ Int
an integer
Definition: SALOME_ModuleCatalog.idl:86
@ Array
an array
Definition: SALOME_ModuleCatalog.idl:91
@ Dble
a double
Definition: SALOME_ModuleCatalog.idl:85
@ Seq
a sequence of a content type
Definition: SALOME_ModuleCatalog.idl:90
@ Str
a string
Definition: SALOME_ModuleCatalog.idl:87
@ Bool
a boolean
Definition: SALOME_ModuleCatalog.idl:88
@ NONE
Definition: SALOME_ModuleCatalog.idl:84
sequence< Service > ListOfInterfaceService
List of services of the interface.
Definition: SALOME_ModuleCatalog.idl:130
sequence< string > ListOfComputers
List of computer names.
Definition: SALOME_ModuleCatalog.idl:180
ComponentType
This enumeration contains a current set of definitions of the components integrated into SALOME appli...
Definition: SALOME_ModuleCatalog.idl:42
DataStreamDependency
enumeration to define datastream ports dependency
Definition: SALOME_ModuleCatalog.idl:59
@ DATASTREAM_ITERATIVE
iterative dependency
Definition: SALOME_ModuleCatalog.idl:62
@ DATASTREAM_TEMPORAL
time dependency
Definition: SALOME_ModuleCatalog.idl:61
@ DATASTREAM_UNDEFINED
dependency not defined
Definition: SALOME_ModuleCatalog.idl:60
sequence< MemberDefinition > ListOfMemberDefinition
List of member definitions in a structure.
Definition: SALOME_ModuleCatalog.idl:102
sequence< IAPP_Affich > ListOfIAPP_Affich
List of pair GUI elements (component name, component icone)
Definition: SALOME_ModuleCatalog.idl:194
sequence< string > ListOfServices
List of services.
Definition: SALOME_ModuleCatalog.idl:132
sequence< string > ListOfComponents
List of component names.
Definition: SALOME_ModuleCatalog.idl:178
sequence< DefinitionInterface > ListOfDefInterface
List of interface definitions.
Definition: SALOME_ModuleCatalog.idl:140
sequence< PathPrefix > PathPrefixes
List of path prefixes.
Definition: SALOME_ModuleCatalog.idl:153
sequence< ServicesDataStreamParameter > ListOfServicesDataStreamParameter
The list of datastream parameters of service.
Definition: SALOME_ModuleCatalog.idl:76
sequence< string > ListOfInterfaces
List of interface names.
Definition: SALOME_ModuleCatalog.idl:142
filename
Definition: pythfilter.py:558
Description of a component.
Definition: SALOME_ModuleCatalog.idl:165
PathPrefixes paths
Definition: SALOME_ModuleCatalog.idl:174
string username
Definition: SALOME_ModuleCatalog.idl:168
ListOfDefInterface interfaces
Definition: SALOME_ModuleCatalog.idl:173
ImplType implementationType
Definition: SALOME_ModuleCatalog.idl:169
string constraint
Definition: SALOME_ModuleCatalog.idl:172
string name
Definition: SALOME_ModuleCatalog.idl:167
string implname
Definition: SALOME_ModuleCatalog.idl:170
ComponentType type
Definition: SALOME_ModuleCatalog.idl:166
string icon
Definition: SALOME_ModuleCatalog.idl:171
This struct contains fields defining each interface.
Definition: SALOME_ModuleCatalog.idl:135
Name of the interface.
Definition: SALOME_ModuleCatalog.idl:136
ListOfInterfaceService interfaceservicelist
Definition: SALOME_ModuleCatalog.idl:137
This struct contains GUI elements used for representation of the module in IAPP component.
Definition: SALOME_ModuleCatalog.idl:183
string modulecomment
Comment to the module.
Definition: SALOME_ModuleCatalog.idl:188
string moduleicone
Icone representing the module.
Definition: SALOME_ModuleCatalog.idl:186
string modulename
Name of the module.
Definition: SALOME_ModuleCatalog.idl:184
string moduleusername
UserName of the module.
Definition: SALOME_ModuleCatalog.idl:185
string moduleversion
Version of the module.
Definition: SALOME_ModuleCatalog.idl:187
struct to define members of a Struc TypeKind
Definition: SALOME_ModuleCatalog.idl:97
string name
Member name.
Definition: SALOME_ModuleCatalog.idl:98
string type
Member type name.
Definition: SALOME_ModuleCatalog.idl:99
PathPrefix : association of a machine name and a path to a component.
Definition: SALOME_ModuleCatalog.idl:147
string machine
Definition: SALOME_ModuleCatalog.idl:148
string path
Definition: SALOME_ModuleCatalog.idl:149
This struct contains fields defining each service.
Definition: SALOME_ModuleCatalog.idl:120
ListOfServicesParameter ServiceinParameter
List of input parameters of the services.
Definition: SALOME_ModuleCatalog.idl:122
string ServiceName
Name of the service.
Definition: SALOME_ModuleCatalog.idl:121
ListOfServicesParameter ServiceoutParameter
List of output parameters of the services.
Definition: SALOME_ModuleCatalog.idl:123
ListOfServicesDataStreamParameter ServiceinDataStreamParameter
Definition: SALOME_ModuleCatalog.idl:124
boolean TypeOfNode
True is the service is a factory node.
Definition: SALOME_ModuleCatalog.idl:127
ListOfServicesDataStreamParameter ServiceoutDataStreamParameter
Definition: SALOME_ModuleCatalog.idl:125
boolean Servicebydefault
True if the service is taken with its default fields.
Definition: SALOME_ModuleCatalog.idl:126
struct to define datastream ports
Definition: SALOME_ModuleCatalog.idl:67
string Parametertype
Parameter type name.
Definition: SALOME_ModuleCatalog.idl:68
string Parametername
Parameter name.
Definition: SALOME_ModuleCatalog.idl:69
DataStreamDependency Parameterdependency
Temporal or iterative dependency.
Definition: SALOME_ModuleCatalog.idl:70
This struct contains fields defining the parameter of the service.
Definition: SALOME_ModuleCatalog.idl:53
Parameter name.
Definition: SALOME_ModuleCatalog.idl:55
Definition: SALOME_ModuleCatalog.idl:54
Struct to get the definition of types used in Salome catalogs.
Definition: SALOME_ModuleCatalog.idl:106
ListOfString bases
base types (if needed)
Definition: SALOME_ModuleCatalog.idl:111
string content
Content type (if needed)
Definition: SALOME_ModuleCatalog.idl:110
ListOfMemberDefinition members
Member types (if needed)
Definition: SALOME_ModuleCatalog.idl:112
string id
id (if needed)
Definition: SALOME_ModuleCatalog.idl:109
string name
Type name.
Definition: SALOME_ModuleCatalog.idl:107
TypeKind kind
Type kind.
Definition: SALOME_ModuleCatalog.idl:108
