SALOME_ModuleCatalog::Acomponent Interface Reference
This interface provides the common functionality information of corresponding component. More...
import"SALOME_ModuleCatalog.idl";
ListOfInterfaces GetInterfaceList ()
 Get the list of interface names of the component. More...
DefinitionInterface GetInterface (in string interfacename) raises (NotFound)
 Get an interface of the component. More...
ListOfServices GetServiceList (in string interfacename) raises (NotFound)
 Get the list of service names of an interface belonging to the component. More...
Service GetService (in string interfacename, in string servicename) raises (NotFound)
 Get a service of an interface of the component. More...
Service GetDefaultService (in string interfacename) raises (NotFound)
 Get the default service of an interface of the component. More...
string GetPathPrefix (in string machinename) raises (NotFound)
 Get the prefix path of the computer containing the component. More...
Data Fields
readonly attribute string constraint
 Get the constraint affected to the component. More...
readonly attribute string componentname
 Get the component name. More...
readonly attribute string componentusername
 Get the user name of the component. More...
readonly attribute ComponentType component_type
 Get the type of the component. More...
readonly attribute string component_icone
 Get the icone of the component (for IAPP) More...
readonly attribute ImplType implementation_type
 Get the implementation type of the component. More...
readonly attribute string implementation_name
 Get the implementation name of the component. More...
Information is loaded from specific xml files.
◆ GetDefaultService()
Service SALOME_ModuleCatalog::Acomponent::GetDefaultService ( in string  interfacename)
raises (NotFound
If the required service or the specified interface don't exist, Notfound exception is thrown.
interfacenameName of the interface
Required service
◆ GetInterface()
DefinitionInterface SALOME_ModuleCatalog::Acomponent::GetInterface ( in string  interfacename)
raises (NotFound
If the specified interface doesn't exist, Notfound exception is thrown
Required interface
◆ GetInterfaceList()
ListOfInterfaces SALOME_ModuleCatalog::Acomponent::GetInterfaceList ( )
a list of interfaces of the component
◆ GetPathPrefix()
string SALOME_ModuleCatalog::Acomponent::GetPathPrefix ( in string  machinename)
raises (NotFound
If the required computer doesn't exist, Notfound exception is thrown
machinenameName of the machine
Prefix path
◆ GetService()
Service SALOME_ModuleCatalog::Acomponent::GetService ( in string  interfacename,
raises (NotFound
servicenameName of the service
Required service
◆ GetServiceList()
ListOfServices SALOME_ModuleCatalog::Acomponent::GetServiceList ( in string  interfacename)
raises (NotFound
If the specified interface doesn't exist, Notfound exception is thrown.
List of services of the required interface
◆ component_icone
readonly attribute string SALOME_ModuleCatalog::Acomponent::component_icone
◆ component_type
readonly attribute ComponentType SALOME_ModuleCatalog::Acomponent::component_type
◆ componentname
readonly attribute string SALOME_ModuleCatalog::Acomponent::componentname
◆ componentusername
readonly attribute string SALOME_ModuleCatalog::Acomponent::componentusername
◆ constraint
readonly attribute string SALOME_ModuleCatalog::Acomponent::constraint
constraint to be resolved by LifeCycle for the computer choice
◆ implementation_name
readonly attribute string SALOME_ModuleCatalog::Acomponent::implementation_name
It's the name of the dyn lib or the python module or the executable if the default naming scheme is not convenient.
◆ implementation_type
readonly attribute ImplType SALOME_ModuleCatalog::Acomponent::implementation_type
C++ (dyn lib), Python (module) or executable
