| def | __init__ (self, serv) |
| def | Register (self, ObjRef, Path) |
| def | Resolve (self, Path) |
| def | keys (self) |
| def | repr (self) |
Private Attributes | |
| _orb | |
| _obj | |
A python client class to handle remote servant of SALOME_Embedded_NamingService
| def SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.__init__ | ( | self, | |
| serv | |||
| def SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.keys | ( | self | ) |
References SeqByteReceiver._obj, SALOME_PyNode.SeqByteReceiver._obj, SALOME::GenericObj_wrap< GENOBJ >._obj, SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy._obj, SALOME_NamingServicePy.SALOME_NamingServicePy_i._obj, and SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.keys().
Referenced by SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.keys(), and SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.repr().
| def SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.Register | ( | self, | |
| ObjRef, | |||
| Path | |||
References SeqByteReceiver._obj, SALOME_PyNode.SeqByteReceiver._obj, SALOME::GenericObj_wrap< GENOBJ >._obj, SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy._obj, SALOME_NamingServicePy.SALOME_NamingServicePy_i._obj, Engines_Component_i._orb, SALOME_ComponentPy.SALOME_ComponentPy_Gen_i._orb, SALOME_Container.SALOME_Container_Abstract_i._orb, Abstract_Engines_Container_i._orb, SALOME_ContainerManager._orb, SALOME_ContainerPy.SALOME_ContainerPy_Gen_i._orb, SALOME_PyNode.ExchangeContextUsingTCP._orb, ConnectionManager_i._orb, Param_Double_Port_uses_i._orb, SALOME_Launcher._orb, LifeCycleCORBATest._orb, Logger._orb, SALOME_ModuleCatalogImpl._orb, SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy._orb, SALOME_NamingService._orb, SALOME_NamingServicePy.SALOME_NamingServicePy_i._orb, NamingServiceTest._orb, Engines_Parallel_Component_i._orb, Engines_Parallel_Container_i._orb, RegistryService._orb, SALOME_ResourcesManager._orb, SALOMEDS_ChildIterator_i._orb, SALOMEDS_Driver_i._orb, SALOMEDS_DriverFactory_i._orb, SALOMEDS_GenericAttribute_i._orb, SALOMEDS_SComponentIterator_i._orb, SALOMEDS_SObject._orb, SALOMEDS_SObject_i._orb, SALOMEDS_Study._orb, SALOMEDS::Notifier._orb, SALOMEDS::GenObjRegister._orb, SALOMEDS_Study_i._orb, SALOMEDS_StudyBuilder._orb, SALOMEDS_StudyBuilder_i._orb, SALOMEDS_UseCaseBuilder_i._orb, SALOMEDS_UseCaseIterator_i._orb, SALOMEDSTest._orb, SALOMESDS::DataScopeKiller._orb, SALOMESDS::DataScopeServerBase._orb, SALOMESDS::DataServerManager._orb, ORB_INIT._orb, and SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.Register().
Referenced by SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.Register().
| def SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.repr | ( | self | ) |
References std::map< std::string, Engines_Parallel_Component_i::_t_Proxy_Salome_file_map * >.keys, std::map< std::string, CORBA::Object_var >.keys, std::map< std::string, Engines::Salome_file_var >.keys, std::map< std::string, DF_Attribute * >.keys, std::map< int, Launcher::Job * >.keys, std::map< int, DF_Document * >.keys, std::map< int, RegistryService::client_infos * >.keys, std::map< std::string, double >.keys, std::unordered_multimap< K, T >.keys, std::map< int, int >.keys, std::map< std::string, SALOMEDSImpl_SObject >.keys, std::map< std::string, char >.keys, std::map< std::string, CORBA::Any >.keys, std::map< std::string, std::vector< int > >.keys, std::map< std::string, Engines_Component_i::_t_Salome_file_map * >.keys, std::map< std::string, port_t * >.keys, std::map< std::string, Engines::file >.keys, std::map< std::string, Engines_Parallel_Component_i::_t_IOR_Proxy_Salome_file_map * >.keys, std::map< std::string, LoadRateManager * >.keys, std::map< Ports::Calcium_Ports::DateCalSchem, CalciumTypes::DateCalSchem >.keys, std::map< std::string, PortableServer::ObjectId * >.keys, std::map< std::string, SALOME_ModuleCatalog::DataStreamDependency >.keys, std::map< std::string, ParserResourcesType >.keys, std::map< std::string, std::string >.keys, std::map< std::string, std::vector< double > >.keys, std::map< K, T >.keys, std::map< int, double >.keys, std::map< std::string, Engines::PyScriptNode_var >.keys, std::map< std::string, std::vector< std::string > >.keys, std::map< int, std::string >.keys, std::map< DataId, DataType >.keys, std::map< std::string, DF_Label >.keys, std::multimap< K, T >.keys, std::map< std::string, Engines_Parallel_Component_i::_t_Salome_file_map * >.keys, std::map< Ports::Calcium_Ports::InterpolationSchem, CalciumTypes::InterpolationSchem >.keys, std::map< std::string, int >.keys, std::map< std::string, MachineParameters >.keys, std::multiset< K >.keys, std::map< std::string, void * >.keys, std::map< CalciumTypes::InterpolationSchem, Ports::Calcium_Ports::InterpolationSchem >.keys, std::map< std::string, SALOMEDSImpl_SComponent >.keys, std::map< std::string, MPI_Comm >.keys, std::map< std::string, Engines::PyNode_var >.keys, std::map< std::string, ParserType >.keys, std::map< ParserComponentType, SALOME_ModuleCatalog::ComponentType >.keys, std::map< std::string, ParserSequence >.keys, std::map< std::string, ParserObjref >.keys, std::map< std::string, ParserStruct >.keys, std::map< int, FILE * >.keys, std::map< std::string, superv_port_t * >.keys, std::set< K >.keys, std::map< std::string, versionList >.keys, std::map< std::string, Engines::EngineComponent_var >.keys, std::map< Ports::Calcium_Ports::ExtrapolationSchem, CalciumTypes::ExtrapolationSchem >.keys, std::map< std::string, Engines::fileRef_var >.keys, std::map< CalciumTypes::DependencyType, Ports::Calcium_Ports::DependencyType >.keys, std::unordered_multiset< K >.keys, std::map< Engines::ConnectionManager::connectionId, connection_infos * >.keys, std::map< CalciumTypes::ExtrapolationSchem, Ports::Calcium_Ports::ExtrapolationSchem >.keys, std::map< CalciumTypes::DateCalSchem, Ports::Calcium_Ports::DateCalSchem >.keys, std::map< Ports::Calcium_Ports::DependencyType, CalciumTypes::DependencyType >.keys, std::unordered_set< K >.keys, std::unordered_map< K, T >.keys, Engines::EmbeddedNamingService.keys(), SALOME_Embedded_NamingService.keys(), SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.keys(), SalomeSDSClt.Dict.keys(), and SALOMEWrappedStdType.Dict.keys().
| def SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.Resolve | ( | self, | |
| Path | |||
References SeqByteReceiver._obj, SALOME_PyNode.SeqByteReceiver._obj, SALOME::GenericObj_wrap< GENOBJ >._obj, SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy._obj, SALOME_NamingServicePy.SALOME_NamingServicePy_i._obj, Engines_Component_i._orb, SALOME_ComponentPy.SALOME_ComponentPy_Gen_i._orb, SALOME_Container.SALOME_Container_Abstract_i._orb, Abstract_Engines_Container_i._orb, SALOME_ContainerManager._orb, SALOME_ContainerPy.SALOME_ContainerPy_Gen_i._orb, SALOME_PyNode.ExchangeContextUsingTCP._orb, ConnectionManager_i._orb, Param_Double_Port_uses_i._orb, SALOME_Launcher._orb, LifeCycleCORBATest._orb, Logger._orb, SALOME_ModuleCatalogImpl._orb, SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy._orb, SALOME_NamingService._orb, SALOME_NamingServicePy.SALOME_NamingServicePy_i._orb, NamingServiceTest._orb, Engines_Parallel_Component_i._orb, Engines_Parallel_Container_i._orb, RegistryService._orb, SALOME_ResourcesManager._orb, SALOMEDS_ChildIterator_i._orb, SALOMEDS_Driver_i._orb, SALOMEDS_DriverFactory_i._orb, SALOMEDS_GenericAttribute_i._orb, SALOMEDS_SComponentIterator_i._orb, SALOMEDS_SObject._orb, SALOMEDS_SObject_i._orb, SALOMEDS_Study._orb, SALOMEDS::Notifier._orb, SALOMEDS::GenObjRegister._orb, SALOMEDS_Study_i._orb, SALOMEDS_StudyBuilder._orb, SALOMEDS_StudyBuilder_i._orb, SALOMEDS_UseCaseBuilder_i._orb, SALOMEDS_UseCaseIterator_i._orb, SALOMEDSTest._orb, SALOMESDS::DataScopeKiller._orb, SALOMESDS::DataScopeServerBase._orb, SALOMESDS::DataServerManager._orb, ORB_INIT._orb, and SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.Resolve().
Referenced by SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.Resolve(), orbmodule.client.waitNS(), and orbmodule.client.waitNSPID().
private |
Referenced by SALOME_PyNode.SeqByteReceiver.__del__(), SALOME_PyNode.SeqByteReceiver.data(), SALOME_PyNode.SeqByteReceiver.fetchByChunks(), SALOME_PyNode.SeqByteReceiver.fetchOneShot(), SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.keys(), SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.Register(), SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.Resolve(), SALOME_NamingServicePy.SALOME_NamingServicePy_i.Resolve(), and SALOME_NamingServicePy.SALOME_NamingServicePy_i.Resolve_Dir().
private |
Referenced by SALOME_Container.SALOME_Container_Abstract_i.__init__(), SALOME_ContainerPy.SALOME_ContainerPy_Gen_i.__init__(), SALOME_ContainerPy.SALOME_ContainerPy_i.__init__(), SALOME_ComponentPy.SALOME_ComponentPy_Gen_i.__init__(), SALOME_NamingServicePy.SALOME_NamingServicePy_i.__init__(), SALOME_ContainerPy.SALOME_ContainerPy_Gen_i.create_component_instance(), SALOME_Container.SALOME_Container_Abstract_i.create_component_instance(), SALOME_Container.SALOME_Container_Abstract_i.create_pynode(), SALOME_Container.SALOME_Container_Abstract_i.create_pyscriptnode(), SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.Register(), SALOME_Embedded_NamingService_ClientPy.SALOME_Embedded_NamingService_ClientPy.Resolve(), and SALOME_ContainerPy.SALOME_ContainerPy_Gen_i.Shutdown().
