Engines_Parallel_Container_i Class Reference
C++ implementation of Engines::Container interface for parallel container implemented with PaCO++. More...
#include <SALOME_ParallelContainer_i.hxx>
Inheritance diagram for Engines_Parallel_Container_i:
 Engines_Parallel_Container_i (CORBA::ORB_ptr orb, char *ior, int rank, PortableServer::POA_ptr poa, std::string containerName, bool isServantAloneInProcess=true)
virtual ~Engines_Parallel_Container_i ()
virtual bool load_component_Library (const char *componentName, CORBA::String_out reason)
 load a new component class More...
virtual Engines::EngineComponent_ptr create_component_instance (const char *componentName)
 Create a new component instance. More...
virtual Engines::EngineComponent_ptr create_component_instance_env (const char *componentName, const Engines::FieldsDict &env, CORBA::String_out reason)
virtual char * create_python_service_instance (const char *CompName, CORBA::String_out reason)
Engines::EngineComponent_ptr find_component_instance (const char *registeredName)
 Find an existing (in the container) component instance. More...
Engines::EngineComponent_ptr load_impl (const char *nameToRegister, const char *componentName)
 Find or create a new component instance. More...
void create_paco_component_node_instance (const char *componentName, const char *proxy_containerName)
void updateInstanceNumber ()
void remove_impl (Engines::EngineComponent_ptr component_i)
 Remove the component instance from container. More...
void finalize_removal ()
 Unload component libraries from the container. More...
virtual void ping ()
 Ping the servant to check it is still alive. More...
char * name ()
 Get container name. More...
char * workingdir ()
 Get container working directory. More...
char * logfilename ()
 Get container log file name. More...
void logfilename (const char *name)
 Set container log file name. More...
virtual void Shutdown ()
 Shutdown the container. More...
char * getHostName ()
 Get container host name. More...
CORBA::Long getPID ()
 Get container PID. More...
bool Kill_impl ()
 Kill current container. More...
Engines::EngineComponent_ptr find_or_create_instance (std::string genericRegisterName)
 Finds an already existing component instance or create a new instance. More...
Engines::EngineComponent_ptr createCPPInstance (std::string genericRegisterName, void *handle)
 Create a new CPP component instance. More...
Engines::EngineComponent_ptr createPythonInstance (std::string genericRegisterName)
 Create a new Python component instance. More...
void set_id (PortableServer::ObjectId *id)
Engines::fileRef_ptr createFileRef (const char *origFileName)
 Get or create a file reference object associated to a local file (to transfer it) More...
Engines::fileTransfer_ptr getFileTransfer ()
 CORBA method: More...
virtual Engines::Salome_file_ptr createSalome_file (const char *origFileName)
void copyFile (Engines::Container_ptr container, const char *remoteFile, const char *localFile)
 copy a file from a remote host (container) to the local host More...
Engines::PyNode_ptr createPyNode (const char *nodeName, const char *code)
 create a PyNode object to execute remote python code More...
Engines::PyNode_ptr getDefaultPyNode (const char *nodeName)
Engines::PyScriptNode_ptr createPyScriptNode (const char *nodeName, const char *code)
Engines::PyScriptNode_ptr getDefaultPyScriptNode (const char *nodeName)
static bool isPythonContainer (const char *ContainerName)
 Indicate if container is a python one. More...
static void decInstanceCnt (std::string genericRegisterName)
 Decrement component instance reference count. More...
Protected Types
typedef std::map< std::string, Engines::EngineComponent_var > _listInstances_map_t
typedef std::map< std::string, Engines::fileRef_var > _fileRef_map_t
typedef std::map< std::string, Engines::Salome_file_var > _Salome_file_map_t
typedef PortableServer::ObjectId *(* FACTORY_FUNCTION) (CORBA::ORB_ptr, char *, int, PortableServer::POA_ptr, PortableServer::ObjectId *, const char *, const char *)
SALOME_NamingService * _NS
std::string _hostname
std::string _library_path
std::string _containerName
std::string _logfilename
CORBA::ORB_var _orb
PortableServer::POA_var _poa
PortableServer::ObjectId * _id
int _numInstance
CORBA::Long _pid
bool _isServantAloneInProcess
Engines::fileTransfer_var _fileTransfer
_listInstances_map_t _listInstances_map
_fileRef_map_t _fileRef_map
_Salome_file_map_t _Salome_file_map
std::map< std::string, PortableServer::ObjectId * > _par_obj_inst_map
Static Protected Attributes
static std::map< std::string, int > _cntInstances_map
static std::map< std::string, void * > _library_map
static std::map< std::string, void * > _toRemove_map
static omni_mutex _numInstanceMutex
◆ _fileRef_map_t
typedef std::map<std::string,Engines::fileRef_var> Engines_Parallel_Container_i::_fileRef_map_t
◆ _listInstances_map_t
typedef std::map<std::string,Engines::EngineComponent_var> Engines_Parallel_Container_i::_listInstances_map_t
◆ _Salome_file_map_t
typedef std::map<std::string,Engines::Salome_file_var> Engines_Parallel_Container_i::_Salome_file_map_t
◆ FACTORY_FUNCTION
typedef PortableServer::ObjectId *(* Engines_Parallel_Container_i::FACTORY_FUNCTION) (CORBA::ORB_ptr, char *, int, PortableServer::POA_ptr, PortableServer::ObjectId *, const char *, const char *)
◆ Engines_Parallel_Container_i()
Engines_Parallel_Container_i::Engines_Parallel_Container_i ( CORBA::ORB_ptr  orb,
char *  ior,
int  rank,
bool  isServantAloneInProcess = true
◆ ~Engines_Parallel_Container_i()
Engines_Parallel_Container_i::~Engines_Parallel_Container_i ( )
References _id, _NS, and MESSAGE.
◆ copyFile()
void Engines_Parallel_Container_i::copyFile ( Engines::Container_ptr  container,
const char *  remoteFile,
const char *  localFile
containerthe remote container
remoteFilethe file to copy locally from the remote host into localFile
localFilethe local file
References TestComponentPy::container, MESSAGE, and SALOME_utilities::SCRUTE().
◆ create_component_instance()
Engines::EngineComponent_ptr Engines_Parallel_Container_i::create_component_instance ( const char *  genericRegisterName)
CORBA method: Creates a new servant instance of a component. The servant registers itself to naming service and Registry.
genericRegisterNameName of the component instance to register in Registry & Name Service (without _inst_n suffix)
a loaded component
References create_component_instance_env().
Referenced by SALOME_ContainerPy.SALOME_ContainerPy_Gen_i::create_component_instance_env(), SALOME_ContainerPy.SALOME_ContainerPy_Gen_i::create_python_service_instance(), and find_or_create_instance().
◆ create_component_instance_env()
Engines::EngineComponent_ptr Engines_Parallel_Container_i::create_component_instance_env ( const char *  genericRegisterName,
const Engines::FieldsDict &  env,
envdict of environment variables
a loaded component
References ParallelGlobalProcessVar_i::_library_map, _numInstance, ParallelGlobalProcessVar_i::_numInstanceMutex, createCPPInstance(), createPythonInstance(), and MESSAGE.
Referenced by create_component_instance().
◆ create_paco_component_node_instance()
◆ create_python_service_instance()
char * Engines_Parallel_Container_i::create_python_service_instance ( const char *  CompName,
◆ createCPPInstance()
Engines::EngineComponent_ptr Engines_Parallel_Container_i::createCPPInstance ( std::string  genericRegisterName,
void *  handle
C++ method: create a servant instance of a component.
genericRegisterNameName of the component instance to register in Registry & Name Service, (without _inst_n suffix, like "COMPONENT")
handleloaded library handle
a loaded component
example with names: aGenRegisterName = COMPONENT (= first argument) _containerName = /Containers/cli76ce/FactoryServer factoryName = COMPONENTEngine_factory component_registerBase = /Containers/cli76ce/FactoryServer/COMPONENT instanceName = COMPONENT_inst_1 component_registerName = /Containers/cli76ce/FactoryServer/COMPONENT_inst_1
References ParallelGlobalProcessVar_i::_cntInstances_map, _containerName, _id, _listInstances_map, _NS, _numInstance, _orb, _poa, MESSAGE, KERNEL_PY.batchmode_salome::obj, and SALOME_NamingService::Register().
Referenced by create_component_instance_env().
◆ createFileRef()
Engines::fileRef_ptr Engines_Parallel_Container_i::createFileRef ( const char *  origFileName)
CORBA method: get or create a fileRef object associated to a local file (a file on the computer on which runs the container server), which stores a list of (machine, localFileName) corresponding to copies already done.
origFileNameabsolute path for a local file to copy on other computers
a fileRef object associated to the file.
References _fileRef_map, _id, ParallelGlobalProcessVar_i::_numInstanceMutex, _poa, and KERNEL_PY.batchmode_salome::obj.
◆ createPyNode()
Engines::PyNode_ptr Engines_Parallel_Container_i::createPyNode ( const char *  nodeName,
const char *  code
nodeNamethe name of the node
codethe python code to load
the PyNode
◆ createPyScriptNode()
Engines::PyScriptNode_ptr Engines_Parallel_Container_i::createPyScriptNode ( const char *  nodeName,
const char *  code
◆ createPythonInstance()
Engines::EngineComponent_ptr Engines_Parallel_Container_i::createPythonInstance ( std::string  genericRegisterName)
a loaded component
References _containerName, _listInstances_map, _numInstance, _orb, IDLparser::error(), and KERNEL_PY.batchmode_salome::obj.
◆ createSalome_file()
Engines::Salome_file_ptr Engines_Parallel_Container_i::createSalome_file ( const char *  origFileName)
◆ decInstanceCnt()
◆ finalize_removal()
void Engines_Parallel_Container_i::finalize_removal ( )
CORBA method: Discharges unused libraries from the container.
References ParallelGlobalProcessVar_i::_numInstanceMutex, ParallelGlobalProcessVar_i::_toRemove_map, and MESSAGE.
◆ find_component_instance()
Engines::EngineComponent_ptr Engines_Parallel_Container_i::find_component_instance ( const char *  registeredName)
CORBA method: Finds a servant instance of a component
registeredNameName of the component in Registry or Name Service, without instance suffix number
the first found instance
References _listInstances_map, and SALOME_utilities::SCRUTE().
◆ find_or_create_instance()
Engines::EngineComponent_ptr Engines_Parallel_Container_i::find_or_create_instance ( std::string  genericRegisterName)
C++ method: Finds an already existing servant instance of a component, or create an instance. -— USE ONLY FOR MULTISTUDY INSTANCES ! -----—
a loaded component
example with names: aGenRegisterName = COMPONENT (= first argument) impl_name = libCOMPONENTEngine.so (= second argument) _containerName = /Containers/cli76ce/FactoryServer factoryName = COMPONENTEngine_factory component_registerBase = /Containers/cli76ce/FactoryServer/COMPONENT
References _containerName, _NS, create_component_instance(), KERNEL_PY.batchmode_salome::obj, and SALOME_NamingService::ResolveFirst().
Referenced by load_impl().
◆ getDefaultPyNode()
Engines::PyNode_ptr Engines_Parallel_Container_i::getDefaultPyNode ( const char *  nodeName)
◆ getDefaultPyScriptNode()
Engines::PyScriptNode_ptr Engines_Parallel_Container_i::getDefaultPyScriptNode ( const char *  nodeName)
◆ getFileTransfer()
Engines::fileTransfer_ptr Engines_Parallel_Container_i::getFileTransfer ( )
CORBA method:
a reference to the fileTransfer object
References _fileTransfer.
◆ getHostName()
char * Engines_Parallel_Container_i::getHostName ( )
CORBA method: Get the hostName of the Container (without domain extensions)
References _hostname, and MESSAGE.
◆ getPID()
CORBA::Long Engines_Parallel_Container_i::getPID ( )
Get container PID.
CORBA method: Get the PID (process identification) of the Container
References _pid, and MESSAGE.
◆ isPythonContainer()
bool Engines_Parallel_Container_i::isPythonContainer ( const char *  ContainerName)
Retrieves only with container naming convention if it is a python container
References TestKernelHelpers::ret.
◆ Kill_impl()
bool Engines_Parallel_Container_i::Kill_impl ( )
Kill the container.
CORBA method: Kill the container process with exit(0). To remove : never returns !
References _containerName, _hostname, _pid, and MESSAGE.
◆ load_component_Library()
bool Engines_Parallel_Container_i::load_component_Library ( const char *  componentName,
CORBA method: load a new component class (Python or C++ implementation)
componentNamelike COMPONENT try to make a Python import of COMPONENT, then a lib open of libCOMPONENTEngine.so
true if dlopen successful or already done, false otherwise
References ParallelGlobalProcessVar_i::_library_map, ParallelGlobalProcessVar_i::_numInstanceMutex, ParallelGlobalProcessVar_i::_toRemove_map, MESSAGE, and TestKernelHelpers::ret.
◆ load_impl()
Engines::EngineComponent_ptr Engines_Parallel_Container_i::load_impl ( const char *  genericRegisterName,
CORBA method: find or create an instance of the component (servant), load a new component class (dynamic library) if required, -— FOR COMPATIBILITY WITH 2.2 -— -— USE ONLY FOR MULTISTUDY INSTANCES ! -----— The servant registers itself to naming service and Registry.
genericRegisterNameName of the component to register in Registry & Name Service
componentNameName of the constructed library of the component
a loaded component
References find_or_create_instance(), and load_component_Library().
◆ logfilename() [1/2]
char * Engines_Parallel_Container_i::logfilename ( )
CORBA attribute: Container log file name
References _logfilename.
◆ logfilename() [2/2]
void Engines_Parallel_Container_i::logfilename ( const char *  name)
References _logfilename, and name().
char * Engines_Parallel_Container_i::name ( )
Get container name.
CORBA attribute: Container name (see constructor)
References _containerName.
Referenced by IDLparser.Tree::__repr__(), salomeContext.SalomeContext::_startSalome(), IDLparser.Tree::getNode(), logfilename(), and IDLparser.Tree::output_xml().
◆ ping()
void Engines_Parallel_Container_i::ping ( )
CORBA method: check if servant is still alive
◆ remove_impl()
void Engines_Parallel_Container_i::remove_impl ( Engines::EngineComponent_ptr  component_i)
CORBA method: Stops the component servant, and deletes all related objects
component_iComponent to be removed
References _listInstances_map, _NS, ParallelGlobalProcessVar_i::_numInstanceMutex, SALOME_NamingService::Destroy_Name(), and MESSAGE.
◆ set_id()
void Engines_Parallel_Container_i::set_id ( PortableServer::ObjectId *  id)
◆ Shutdown()
void Engines_Parallel_Container_i::Shutdown ( )
CORBA method, oneway: Server shutdown.
  • Container name removed from naming service,
  • servant deactivation,
  • orb shutdown if no other servants in the process
References _containerName, _isServantAloneInProcess, _listInstances_map, _NS, _orb, _par_obj_inst_map, _poa, SALOME_NamingService::Destroy_FullDirectory(), SALOME_NamingService::Destroy_Name(), and MESSAGE.
◆ updateInstanceNumber()
void Engines_Parallel_Container_i::updateInstanceNumber ( )
◆ workingdir()
char * Engines_Parallel_Container_i::workingdir ( )
CORBA attribute: Container working directory
◆ _cntInstances_map
std::map< std::string, int > ParallelGlobalProcessVar_i::_cntInstances_map
staticprotectedinherited
◆ _containerName
◆ _fileRef_map
_fileRef_map_t Engines_Parallel_Container_i::_fileRef_map
Referenced by createFileRef().
◆ _fileTransfer
Engines::fileTransfer_var Engines_Parallel_Container_i::_fileTransfer
◆ _hostname
◆ _id
◆ _isServantAloneInProcess
bool Engines_Parallel_Container_i::_isServantAloneInProcess
Referenced by Shutdown().
◆ _library_map
◆ _library_path
std::string Engines_Parallel_Container_i::_library_path
◆ _logfilename
std::string Engines_Parallel_Container_i::_logfilename
◆ _NS
◆ _numInstance
◆ _numInstanceMutex
◆ _orb
◆ _par_obj_inst_map
std::map<std::string, PortableServer::ObjectId *> Engines_Parallel_Container_i::_par_obj_inst_map
◆ _pid
CORBA::Long Engines_Parallel_Container_i::_pid
◆ _poa
◆ _Salome_file_map
_Salome_file_map_t Engines_Parallel_Container_i::_Salome_file_map
Referenced by createSalome_file().
◆ _toRemove_map
std::map< std::string, void * > ParallelGlobalProcessVar_i::_toRemove_map
