| def | __init__ (self, name='', content='', key=None) |
| def | addChild (self, tree) |
| def | addNamedChild (self, name, content='') |
| def | replaceChild (self, tree) |
| def | insertFirstChild (self, tree) |
| def | insertFirstNamedChild (self, name, content='') |
| def | output_xml (self, f, depth=0) |
| def | Dump (self, levels=-1, depth=0) |
| def | parents (self) |
| def | getChild (self, name, content=None) |
| def | getNode (self, name, content='', depth=-1) |
| def | __repr__ (self) |
| def | merge (self, t) |
| def | mergeChilds (self, t, list) |
| def | setAttrib (self, name, value) |
Data Fields | |
| name | |
| content | |
| key | |
| parent | |
| childs | |
| comments | |
| attrs | |
| def IDLparser.Tree.__init__ | ( | self, | |
name = '', |
content = '', |
key = None |
| def IDLparser.Tree.__repr__ | ( | self | ) |
References study_exchange_vars.Variable.name, salomeContext.SalomeContext.name, Engines::Superv_Component::multiple_param.name, Engines::Container.name, Engines::SfState.name, Engines::Parameter.name, SALOME_ModuleCatalog::MemberDefinition.name, SALOME_ModuleCatalog::TypeDefinition.name, SALOME_ModuleCatalog::ComponentDef.name, SALOME_TYPES::Parameter.name, Registry::Infos.name, Engines::ResourceParameters.name, Engines::ResourceDefinition.name, Abstract_Engines_Container_i.name(), KERNEL_PY.kernel.parametric.study_exchange_vars.Variable.name, SALOME_ContainerScriptPerfLog.name(), ResourceDefinition_cpp.name, ParserParameter.name, ParserDataStreamParameter.name, ParserService.name, ParserInterface.name, ParserComponent.name, ParserType.name, IDLparser.Tree.name, Engines_Parallel_Container_i.name(), resourceParams.name, and Identity.name().
| def IDLparser.Tree.addChild | ( | self, | |
| tree | |||
References IDLparser.Tree.childs, IDLparser.StructType.childs, and IDLparser.ObjType.childs.
Referenced by IDLparser.Tree.addNamedChild(), and IDLparser.Tree.replaceChild().
| def IDLparser.Tree.addNamedChild | ( | self, | |
| name, | |||
content = '' |
| def IDLparser.Tree.Dump | ( | self, | |
levels = -1, |
depth = 0 |
| def IDLparser.Tree.getChild | ( | self, | |
| name, | |||
content = None |
Referenced by IDLparser.Service.createDataStreamParameter(), IDLparser.Service.createInParameter(), IDLparser.Component.createInterface(), IDLparser.Service.createOutParameter(), IDLparser.Interface.createService(), IDLparser.Interface.findService(), and IDLparser.Component.merge().
| def IDLparser.Tree.getNode | ( | self, | |
| name, | |||
content = '', |
depth = -1 |
References IDLparser.Tree.childs, IDLparser.StructType.childs, IDLparser.ObjType.childs, SALOME_ModuleCatalog::TypeDefinition.content, ParserType.content, IDLparser.Tree.content, study_exchange_vars.Variable.name, salomeContext.SalomeContext.name, Engines::Superv_Component::multiple_param.name, Engines::Container.name, Engines::SfState.name, Engines::Parameter.name, SALOME_ModuleCatalog::MemberDefinition.name, SALOME_ModuleCatalog::TypeDefinition.name, SALOME_ModuleCatalog::ComponentDef.name, SALOME_TYPES::Parameter.name, Registry::Infos.name, Engines::ResourceParameters.name, Engines::ResourceDefinition.name, Abstract_Engines_Container_i.name(), KERNEL_PY.kernel.parametric.study_exchange_vars.Variable.name, SALOME_ContainerScriptPerfLog.name(), ResourceDefinition_cpp.name, ParserParameter.name, ParserDataStreamParameter.name, ParserService.name, ParserInterface.name, ParserComponent.name, ParserType.name, IDLparser.Tree.name, Engines_Parallel_Container_i.name(), resourceParams.name, and Identity.name().
Referenced by IDLparser.Catalog.mergeComponent(), IDLparser.Catalog.mergeType(), and IDLparser.Catalog.removeComponent().
| def IDLparser.Tree.insertFirstChild | ( | self, | |
| tree | |||
Referenced by IDLparser.Tree.insertFirstNamedChild().
| def IDLparser.Tree.insertFirstNamedChild | ( | self, | |
| name, | |||
content = '' |
References IDLparser.Tree.insertFirstChild().
| def IDLparser.Tree.merge | ( | self, | |
| t | |||
| def IDLparser.Tree.mergeChilds | ( | self, | |
| t, | |||
| list | |||
Referenced by IDLparser.Component.merge(), IDLparser.Interface.merge(), and IDLparser.Service.merge().
| def IDLparser.Tree.output_xml | ( | self, | |
| f, | |||
depth = 0 |
References IDLparser.Tree.attrs, IDLparser.Tree.childs, IDLparser.StructType.childs, IDLparser.ObjType.childs, SALOME_ModuleCatalog::TypeDefinition.content, ParserType.content, IDLparser.Tree.content, study_exchange_vars.Variable.name, salomeContext.SalomeContext.name, Engines::Superv_Component::multiple_param.name, Engines::Container.name, Engines::SfState.name, Engines::Parameter.name, SALOME_ModuleCatalog::MemberDefinition.name, SALOME_ModuleCatalog::TypeDefinition.name, SALOME_ModuleCatalog::ComponentDef.name, SALOME_TYPES::Parameter.name, Registry::Infos.name, Engines::ResourceParameters.name, Engines::ResourceDefinition.name, Abstract_Engines_Container_i.name(), KERNEL_PY.kernel.parametric.study_exchange_vars.Variable.name, SALOME_ContainerScriptPerfLog.name(), ResourceDefinition_cpp.name, ParserParameter.name, ParserDataStreamParameter.name, ParserService.name, ParserInterface.name, ParserComponent.name, ParserType.name, IDLparser.Tree.name, Engines_Parallel_Container_i.name(), resourceParams.name, and Identity.name().
| def IDLparser.Tree.parents | ( | self | ) |
References IDLparser.Tree.parent.
| def IDLparser.Tree.replaceChild | ( | self, | |
| tree | |||
| def IDLparser.Tree.setAttrib | ( | self, | |
| name, | |||
| value | |||
| IDLparser.Tree.attrs |
Referenced by IDLparser.Tree.output_xml(), and IDLparser.Tree.setAttrib().
| IDLparser.Tree.childs |
| IDLparser.Tree.comments |
Referenced by IDLparser.Interface.processDataStreams().
| IDLparser.Tree.content |
Referenced by IDLparser.Tree.Dump(), IDLparser.Tree.getNode(), and IDLparser.Tree.output_xml().
| IDLparser.Tree.key |
| IDLparser.Tree.name |
| IDLparser.Tree.parent |
Referenced by IDLparser.Tree.parents().
