salomeContext.SalomeContext Class Reference
def __init__ (self, Optional[List[str]] configFileNames=None, str name="salome")
Tuple[bytes, bytes, Union[int, Any]] runSalome (self, List[str] args)
None addToPath (self, str value)
None addToLdLibraryPath (self, str value)
None addToDyldLibraryPath (self, str value)
None addToPythonPath (self, str value)
None addToTestsPath (self, str value)
None setVariable (self, name, str value, bool overwrite=False)
None setDefaultValue (self, str name, Any value)
None unsetVariable (self, str name)
None addToVariable (self, str name, Any value, str separator=os.pathsep)
def appendVariable (self, name, value, separator=os.pathsep)
def removeFromVariable (self, name, value, separator=os.pathsep)
def __getstate__ (self)
def __setstate__ (self, d)
def getLogger (self)
Data Fields
 configFileNames
 name
None __setContextFromConfigFiles (self)
None __loadEnvModules (self, List[str] env_modules)
Tuple[Optional[str], List[str]] __parseArguments (self, List[str] args)
 This begins the private section #. More...
int _startSalome (self, List[str] args)
int __setContextFromConfigFile (self, str filename, Optional[List[str]] reserved=None)
int _runAppli (self, Optional[List[str]] args=None)
int _sessionless (self, Optional[List[str]] args=None)
int _setContext (self, Optional[List[str]] args=None)
int _runSession (self, Optional[List[str]] args=None)
int _runRemote (self, Optional[List[str]] args=None)
int _runConsole (self, Optional[List[str]] args=None)
int _kill (self, Optional[List[str]] args=None)
int _killAll (self, Optional[List[str]] args=None)
int _runTests (self, Optional[List[str]] args=None)
None _showSoftwareVersions (self, Optional[List[str]] softwares=None)
int _showInfo (self, Optional[List[str]] args=None)
int _showDoc (self, Optional[List[str]] args=None)
None _usage (self, Optional[List[str]] unused=None)
None _makeCoffee (self, Optional[List[str]] unused=None)
None _getCar (self, Optional[List[str]] unused=None)
 _logger
The SalomeContext class in an API to configure SALOME context then
start SALOME using a single python command.
Initialize context from a list of configuration files
identified by their names.
These files should be in appropriate .cfg format.
◆ __init__()
def salomeContext.SalomeContext.__init__ (   self,
Optional[List[str]]   configFileNames = None,
str   name = "salome"
◆ __getstate__()
def salomeContext.SalomeContext.__getstate__ (   self)
◆ __loadEnvModules()
None salomeContext.SalomeContext.__loadEnvModules (   self,
◆ __parseArguments()
Tuple[Optional[str], List[str]] salomeContext.SalomeContext.__parseArguments (   self,
List[str]  args
Referenced by salomeContext.SalomeContext._startSalome().
◆ __setContextFromConfigFile()
◆ __setContextFromConfigFiles()
◆ __setstate__()
def salomeContext.SalomeContext.__setstate__ (   self,
  d
◆ _getCar()
None salomeContext.SalomeContext._getCar (   self,
Optional[List[str]]   unused = None
◆ _kill()
int salomeContext.SalomeContext._kill (   self,
Optional[List[str]]   args = None
References setenv.main().
◆ _killAll()
int salomeContext.SalomeContext._killAll (   self,
◆ _makeCoffee()
None salomeContext.SalomeContext._makeCoffee (   self,
◆ _runAppli()
int salomeContext.SalomeContext._runAppli (   self,
◆ _runConsole()
int salomeContext.SalomeContext._runConsole (   self,
◆ _runRemote()
int salomeContext.SalomeContext._runRemote (   self,
◆ _runSession()
int salomeContext.SalomeContext._runSession (   self,
◆ _runTests()
int salomeContext.SalomeContext._runTests (   self,
◆ _sessionless()
int salomeContext.SalomeContext._sessionless (   self,
◆ _setContext()
int salomeContext.SalomeContext._setContext (   self,
◆ _showDoc()
int salomeContext.SalomeContext._showDoc (   self,
◆ _showInfo()
int salomeContext.SalomeContext._showInfo (   self,
◆ _showSoftwareVersions()
None salomeContext.SalomeContext._showSoftwareVersions (   self,
Optional[List[str]]   softwares = None
◆ _startSalome()
◆ _usage()
None salomeContext.SalomeContext._usage (   self,
References salomeContext.usage().
◆ addToDyldLibraryPath()
None salomeContext.SalomeContext.addToDyldLibraryPath (   self,
str  value
Append value to DYLD_LIBRARY_PATH environment variable
References salomeContext.SalomeContext.addToVariable().
◆ addToLdLibraryPath()
None salomeContext.SalomeContext.addToLdLibraryPath (   self,
str  value
Append value to LD_LIBRARY_PATH environment variable
◆ addToPath()
None salomeContext.SalomeContext.addToPath (   self,
str  value
Append value to PATH environment variable
◆ addToPythonPath()
None salomeContext.SalomeContext.addToPythonPath (   self,
str  value
Append value to PYTHONPATH environment variable
◆ addToTestsPath()
None salomeContext.SalomeContext.addToTestsPath (   self,
str  value
Append value to SALOME_TESTS_PATH environnement variable
References salomeContext.SalomeContext.appendVariable().
◆ addToVariable()
None salomeContext.SalomeContext.addToVariable (   self,
str  name,
Any  value,
str   separator = os.pathsep
◆ appendVariable()
def salomeContext.SalomeContext.appendVariable (   self,
  name,
  value,
◆ getLogger()
◆ removeFromVariable()
def salomeContext.SalomeContext.removeFromVariable (   self,
  name,
  value,
Remove value from environment variable
References salomeContext.SalomeContext.getLogger().
◆ runSalome()
Tuple[bytes, bytes, Union[int, Any]] salomeContext.SalomeContext.runSalome (   self,
List[str]  args
◆ setDefaultValue()
None salomeContext.SalomeContext.setDefaultValue (   self,
str  name,
Any  value
Set environment variable only if it is undefined.
Referenced by salomeContext.SalomeContext.__setContextFromConfigFile().
◆ setVariable()
None salomeContext.SalomeContext.setVariable (   self,
  name,
str  value,
bool   overwrite = False
◆ unsetVariable()
None salomeContext.SalomeContext.unsetVariable (   self,
str  name
◆ _logger
salomeContext.SalomeContext._logger
◆ configFileNames
salomeContext.SalomeContext.configFileNames
◆ name
