Data Structures | |
| class | SalomeContext |
Functions | |
| str | usage (str name="salome", str appended_cmd_doc="", str appended_opt_doc="", bool do_print=True) |
Variables | |
| parser = argparse.ArgumentParser(usage=usage(do_print=False)) | |
| help | |
| args = parser.parse_args() | |
| SalomeContext | |
| str | |
| status = context._startSalome(cargs) | |
| str salomeContext.usage | ( | str | name = "salome", |
| str | appended_cmd_doc = "", |
| str | appended_opt_doc = "", |
| bool | do_print = True |
References salome_instance.port.
Referenced by salomeContext.SalomeContext._startSalome(), and salomeContext.SalomeContext._usage().
| salomeContext.args = parser.parse_args() |
| salomeContext.help |
| salomeContext.status = context._startSalome(cargs) |
Referenced by MPIObject_i.BCastIOR(), SALOME_ContainerManager.BuildTempFileToLaunchRemoteContainer(), CreateDataScope(), Abstract_Engines_Container_i.createExecutableInstance(), Exists(), HDFConvert.FromAscii(), BatchTest.get_home(), SALOME_ContainerManager.GetMPIZeroNode(), SALOME_ContainerManager.LaunchContainer(), Salome_file_i.load(), main(), printBacktrace(), NOTIFICATION_Consumer.Receive(), Salome_file_i.setDistributedFile(), Salome_file_i.setLocalFile(), BatchTest.test_appli(), BatchTest.test_connection(), BatchTest.test_filecopy(), BatchTest.test_getresult(), BatchTest.test_jobsubmit_mpi(), BatchTest.test_jobsubmit_simple(), and SALOME_ContainerManager.~SALOME_ContainerManager().
| salomeContext.str |
Referenced by DF_Label.Entry(), SALOME_Trace.putMessage(), and Launcher::Job.updateJobState().
