KERNEL_PY.kernel.threadhelper.Runner Class Reference
Inheritance diagram for KERNEL_PY.kernel.threadhelper.Runner:
def __init__ (self, functionToRun=None, *argv)
def setFunction (self, functionToRun)
def setArguments (self, *argv)
def getReturn (self)
def setCallbackFunction (self, callbackFunction)
def setObserver (self, observerToNotify)
def run (self)
def notifyObserver (self)
def callback (self)
def isEnded (self)
def getException (self)
def getId (self)
def wait (self, timeout=None)
def kill (self, message="Arr�t demand�")
def clear (self)
Static Public Attributes
int CONTINUE = 1
int STOP = 0
 _stopevent
 _exception
 _return
 _observer
 _callbackFunction
 _id
 _function
 _argv
This class provides a tool to run and drive a function in a dedicated thread.
◆ __init__()
def KERNEL_PY.kernel.threadhelper.Runner.__init__ (   self,
  functionToRun = None,
*  argv
◆ callback()
def KERNEL_PY.kernel.threadhelper.Runner.callback (   self)
◆ clear()
◆ getException()
def KERNEL_PY.kernel.threadhelper.Runner.getException (   self)
◆ getId()
◆ getReturn()
def KERNEL_PY.kernel.threadhelper.Runner.getReturn (   self)
Retourne le resultat de la fonction. En cas d'erreur, on
r�cup�rera l'exception lev�e au moyen de la m�thode
getException().
References KERNEL_PY.kernel.threadhelper.Runner._return, and KERNEL_PY.kernel.threadhelper.Runner.getException().
◆ isEnded()
def KERNEL_PY.kernel.threadhelper.Runner.isEnded (   self)
Retourne true si la fonction s'est termin�e naturellement
(correctement ou en erreur). Utile pour les client qui
pratique le pooling (interrogation r�p�t�e � intervalle
r�gulier.
References KERNEL_PY.kernel.threadhelper.Runner._stopevent.
◆ kill()
def KERNEL_PY.kernel.threadhelper.Runner.kill (   self,
  message = "Arr�t demand�"
Cette m�thode doit �tre appeler pour interrombre le
thread. Cet appel d�clare le thread comme en erreur (exception
mise � disposition par la m�thode getException().
References KERNEL_PY.kernel.threadhelper.Runner._exception, KERNEL_PY.kernel.threadhelper.Runner._stopevent, and KERNEL_PY.kernel.threadhelper.Runner.getException().
◆ notifyObserver()
def KERNEL_PY.kernel.threadhelper.Runner.notifyObserver (   self)
◆ run()
◆ setArguments()
def KERNEL_PY.kernel.threadhelper.Runner.setArguments (   self,
*  argv
◆ setCallbackFunction()
def KERNEL_PY.kernel.threadhelper.Runner.setCallbackFunction (   self,
  callbackFunction
◆ setFunction()
def KERNEL_PY.kernel.threadhelper.Runner.setFunction (   self,
  functionToRun
Positionne la fonction � ex�cuter. La fonction peut �tre la
m�thode d'un objet pass�e sous la forme 'monobjet.mamethode'.
References Engines::LogManager.clear(), SALOME_ContainerScriptExecPerfLog.clear(), SALOME_LogManager.clear(), KERNEL_PY.iparameters.IParameters.clear(), KERNEL_PY.kernel.threadhelper.Runner.clear(), SalomeSDSClt.Dict.clear(), and SALOMEWrappedStdType.Dict.clear().
◆ setObserver()
def KERNEL_PY.kernel.threadhelper.Runner.setObserver (   self,
  observerToNotify
Permet de sp�cifier un observateur � notifier en fin
d'ex�cution. L'observateur est suppos� �tre un objet qui
impl�mente une m�thode processNotification()
References KERNEL_PY.kernel.threadhelper.Runner._observer, and uiexception.DevelException().
◆ wait()
def KERNEL_PY.kernel.threadhelper.Runner.wait (   self,
  timeout = None
Met fin au thread apr�s timeout seconde s'il est encore en
ex�cution.
Si le compte-�-rebours est atteind sans que la fonction
functionToRun soit termin�e, alors le runner est laiss� dans
l'�tat 'not Ended', c'est-�-dire que isEnded retourne
false. On peut ainsi distinguer l'arr�t normal de l'arr�t �
l'issue du timeout.
◆ _argv
KERNEL_PY.kernel.threadhelper.Runner._argv
◆ _callbackFunction
KERNEL_PY.kernel.threadhelper.Runner._callbackFunction
◆ _exception
◆ _function
KERNEL_PY.kernel.threadhelper.Runner._function
◆ _id
KERNEL_PY.kernel.threadhelper.Runner._id
◆ _observer
◆ _return
◆ _stopevent
◆ CONTINUE
int KERNEL_PY.kernel.threadhelper.Runner.CONTINUE = 1
◆ STOP
int KERNEL_PY.kernel.threadhelper.Runner.STOP = 0
