KERNEL_PY.iparameters.IParameters Class Reference
def __init__ (self, attributeParameter, clr=False)
def clear (self)
def append (self, listName, value)
def nbValues (self, listName)
def getValues (self, listName)
def getLists (self)
def setParameter (self, entry, parameterName, value)
def getParameter (self, entry, parameterName)
def getAllParameterNames (self, entry)
def getAllParameterValues (self, entry)
def getNbParameters (self, entry)
def getEntries (self)
def setProperty (self, name, value)
def getProperty (self, name)
def getProperties (self)
def parseValue (self, value, separator, fromEnd)
def setDumpPython (self, isDumping)
def isDumpPython (self)
 _ap
Interface IParameters was designed to provide a common way to set up
named parameters. The interface is initialized by AttributeParameter that
is used as a container of stored data.
The interface supports 3 types of named parameters:
1. Named list - a named list consists of string values.
   One can append value to list (method 'append'), get a number of values
   in the list (method 'nbValues'), get all values of the given list
   (method 'getValues') and get names of all created named lists.
2. Parameters - that is a set of named string values associated with some named
   entity. Parameter consists of tree elements: entity name, a parameter name
   and a parameter value. Thus for one named entity there are an arbitrary number
   of pair 'name parameter : value'.
   One can add a new parameter to entry (method 'setParameter'), get a value of
   a given named parameter of the given entry (method 'getParameter'), get a number
   of parameters of the given entry (method 'getNbParameters'), get all names of
   parameters for the given entry (method 'getAllParameterNames'), get all
   values of parameters for the entry (method 'getAllParameterValues') and get all
   stored entries (method 'getEntries')
3. Property - a property has a name and a string value.
   One can set property (method 'setProperty'), getProperty (method 'getProperty') and
   get a list of all stored properties (method 'getProperties').
Note:
      Methods not mentioned above are private and is not supposed to be used
      by module's developers.
◆ __init__()
def KERNEL_PY.iparameters.IParameters.__init__ (   self,
  attributeParameter,
  clr = False
Initializes the instance. If clr parameter is True, all IAPP attribute values are cleared.
◆ append()
◆ clear()
def KERNEL_PY.iparameters.IParameters.clear (   self)
◆ getAllParameterNames()
def KERNEL_PY.iparameters.IParameters.getAllParameterNames (   self,
  entry
Returns all parameter names of the given entry
References KERNEL_PY.iparameters.IParameters._ap, and SALOMEDSImpl_IParameters._ap.
◆ getAllParameterValues()
def KERNEL_PY.iparameters.IParameters.getAllParameterValues (   self,
  entry
Returns all parameter values of the given entry
◆ getEntries()
def KERNEL_PY.iparameters.IParameters.getEntries (   self)
◆ getLists()
def KERNEL_PY.iparameters.IParameters.getLists (   self)
Returns a list of named lists' names
◆ getNbParameters()
def KERNEL_PY.iparameters.IParameters.getNbParameters (   self,
  entry
Returns a number of parameters of the entry
◆ getParameter()
def KERNEL_PY.iparameters.IParameters.getParameter (   self,
  entry,
  parameterName
Returns a value of the named parameter for the entry
◆ getProperties()
def KERNEL_PY.iparameters.IParameters.getProperties (   self)
◆ getProperty()
def KERNEL_PY.iparameters.IParameters.getProperty (   self,
  name
Returns a value of the named property
◆ getValues()
def KERNEL_PY.iparameters.IParameters.getValues (   self,
  listName
Returns a list of values in the named list
◆ isDumpPython()
def KERNEL_PY.iparameters.IParameters.isDumpPython (   self)
Returns whether there is the dumping to Python
◆ nbValues()
def KERNEL_PY.iparameters.IParameters.nbValues (   self,
  listName
Returns a number of values in the named list
◆ parseValue()
def KERNEL_PY.iparameters.IParameters.parseValue (   self,
  value,
  separator,
  fromEnd
Breaks a value string in two parts which is divided by separator.
◆ setDumpPython()
def KERNEL_PY.iparameters.IParameters.setDumpPython (   self,
  isDumping
Enables/Disables the dumping to Python
◆ setParameter()
◆ setProperty()
◆ _ap
