Class which an interface to store the parameters of the objects. More...
#include <SALOMEDS_IParameters.hxx>
| SALOMEDS_IParameters (const _PTR(AttributeParameter)&ap) | |
| Constructor. More... | |
| virtual | ~SALOMEDS_IParameters () |
| virtual int | append (const std::string &listName, const std::string &value) |
| Appends a string value to a named list. More... | |
| virtual int | nbValues (const std::string &listName) |
| Returns a number elements in the list. More... | |
| virtual std::vector< std::string > | getValues (const std::string &listName) |
| Returns a list of values in the list. More... | |
| virtual std::string | getValue (const std::string &listName, int index) |
| Returns a value with given index, where index is in range [0:nbValues-1]. More... | |
| virtual std::vector< std::string > | getLists () |
| Returns a list all entries lists. More... | |
| virtual void | setParameter (const std::string &entry, const std::string ¶meterName, const std::string &value) |
| Sets a new named parameter value for the given entry. More... | |
| virtual std::string | getParameter (const std::string &entry, const std::string ¶meterName) |
| Gets a named parameter value for the given entry. More... | |
| virtual void | setIdParameter (const std::string &entry, const std::string &value) |
| Sets an id parameter value for the given entry. More... | |
| virtual std::string | getIdParameter (const std::string &entry) |
| Gets an id parameter value for the given entry. More... | |
| virtual std::vector< std::string > | getAllParameterNames (const std::string &entry) |
| Returns all parameter names of the given entry. More... | |
| virtual std::vector< std::string > | getAllParameterValues (const std::string &entry) |
| Returns all parameter values of the given entry. More... | |
| virtual int | getNbParameters (const std::string &entry) |
| Returns a number of parameters of the given entry. More... | |
| virtual std::vector< std::string > | getEntries () |
| Returns a list all entries. More... | |
| virtual void | setProperty (const std::string &name, const std::string &value) |
| Sets a global named property value. More... | |
| virtual std::string | getProperty (const std::string &name) |
| Gets a value of global named property. More... | |
| virtual std::vector< std::string > | getProperties () |
| Returns a list all properties. More... | |
| virtual std::vector< std::string > | parseValue (const std::string &value, const char separator, bool fromEnd=true) |
| Breaks a value string in two parts which is divided by separator. More... | |
| virtual std::string | encodeEntry (const std::string &entry, const std::string &compName) |
| Returns encoded entry that is a relative entry for the component. More... | |
| virtual std::string | decodeEntry (const std::string &entry) |
| Returns decoded entry that is an absolute entry. More... | |
| virtual void | setDumpPython (const std::string &theID="") |
| Enables/Disables the dumping visual parameters. More... | |
| virtual bool | isDumpPython (const std::string &theID="") |
| Returns whether there is the dumping visual parameters. More... | |
| virtual std::string | getDefaultVisualComponent () |
| Returns a default name of the component where the visula parameters are stored. More... | |
Private Member Functions | |
| _PTR (AttributeParameter) _ap | |
Private Attributes | |
| std::map< std::string, std::string > | _compNames |
| SALOMEDS_IParameters::SALOMEDS_IParameters | ( | const _PTR(AttributeParameter)& | ap | ) |
References _compNames.
private |
Referenced by decodeEntry(), isDumpPython(), and setDumpPython().
Returns a number of the added value. Note: the name of the list MUST be unique
< TODO: conversion from size_t to int
Implements SALOMEDSClient_IParameters.
References _AP_ENTRIES_LIST_, _AP_LISTS_LIST_, _AP_PROPERTIES_LIST_, append(), and PT_STRARRAY.
Referenced by append(), KERNEL_PY.iparameters.IParameters::append(), setIdParameter(), setParameter(), KERNEL_PY.iparameters.IParameters::setParameter(), setProperty(), and KERNEL_PY.iparameters.IParameters::setProperty().
References _compNames, _PTR(), KERNEL::getStudyServant(), and ClientFactory::Study().
References PT_STRARRAY.
Referenced by isDumpPython(), and setDumpPython().
References _AP_ENTRIES_LIST_, and PT_STRARRAY.
References _PT_ID_, and PT_STRARRAY.
References _AP_LISTS_LIST_, and PT_STRARRAY.
References _AP_PROPERTIES_LIST_, and PT_STRARRAY.
References pythfilter::name, and PT_STRING.
References python_test_driver::index, and PT_STRARRAY.
References _AP_DUMP_PYTHON_, _PTR(), getDefaultVisualComponent(), KERNEL::getStudyServant(), PT_BOOLEAN, and ClientFactory::Study().
Referenced by setDumpPython().
If fromEnd is True the search of separator starts from the end of the string
References _AP_DUMP_PYTHON_, _PTR(), getDefaultVisualComponent(), KERNEL::getStudyServant(), isDumpPython(), and ClientFactory::Study().
References _AP_ENTRIES_LIST_, _PT_ID_, append(), and PT_STRARRAY.
References _AP_ENTRIES_LIST_, append(), and PT_STRARRAY.
References _AP_PROPERTIES_LIST_, append(), pythfilter::name, and PT_STRING.
private |
Referenced by decodeEntry(), and ~SALOMEDS_IParameters().
