SALOMEDSClient_IParameters Class Referenceabstract
Class which an interface to store the parameters of the objects. More...
#include <SALOMEDSClient_IParameters.hxx>
Inheritance diagram for SALOMEDSClient_IParameters:
virtual ~SALOMEDSClient_IParameters ()
virtual int append (const std::string &listName, const std::string &value)=0
 Appends a string value to a named list. More...
virtual int nbValues (const std::string &listName)=0
 Returns a number elements in the list. More...
virtual std::vector< std::string > getValues (const std::string &listName)=0
 Returns a list of values in the list. More...
virtual std::string getValue (const std::string &listName, int index)=0
 Returns a value with given index, where index is in range [0:nbValues-1]. More...
virtual std::vector< std::string > getLists ()=0
 Returns a list all entries lists. More...
virtual void setParameter (const std::string &entry, const std::string &parameterName, const std::string &value)=0
 Sets a new named parameter value for the given entry. More...
virtual std::string getParameter (const std::string &entry, const std::string &parameterName)=0
 Gets a named parameter value for the given entry. More...
virtual void setIdParameter (const std::string &entry, const std::string &value)=0
 Sets an id parameter value for the given entry. More...
virtual std::string getIdParameter (const std::string &entry)=0
 Gets an id parameter value for the given entry. More...
virtual std::vector< std::string > getAllParameterNames (const std::string &entry)=0
 Returns all parameter names of the given entry. More...
virtual std::vector< std::string > getAllParameterValues (const std::string &entry)=0
 Returns all parameter values of the given entry. More...
virtual int getNbParameters (const std::string &entry)=0
 Returns a number of parameters of the given entry. More...
virtual std::vector< std::string > getEntries ()=0
 Returns a list all entries. More...
virtual void setProperty (const std::string &name, const std::string &value)=0
 Sets a global named property value. More...
virtual std::string getProperty (const std::string &name)=0
 Gets a value of global named property. More...
virtual std::vector< std::string > getProperties ()=0
 Returns a list all properties. More...
virtual std::vector< std::string > parseValue (const std::string &value, const char separator, bool fromEnd=true)=0
 Breaks a value string in two parts which is divided by separator. More...
virtual std::string encodeEntry (const std::string &entry, const std::string &compName)=0
 Returns encoded entry that is a relative entry for the component. More...
virtual std::string decodeEntry (const std::string &entry)=0
 Returns decoded entry that is an absolute entry. More...
virtual void setDumpPython (const std::string &theID="")=0
 Enables/Disables the dumping visual parameters, static implementation is supposed. More...
virtual bool isDumpPython (const std::string &theID="")=0
 Returns whether there is the dumping visual parameters, static implementation is supposed. More...
virtual std::string getDefaultVisualComponent ()=0
 Returns a default name of the component where the visula parameters are stored. More...
◆ ~SALOMEDSClient_IParameters()
virtual SALOMEDSClient_IParameters::~SALOMEDSClient_IParameters ( )
◆ append()
virtual int SALOMEDSClient_IParameters::append ( const std::string &  listName,
const std::string &  value
pure virtual
Returns a number of the added value. Note: the name of the list MUST be unique
Implemented in SALOMEDS_IParameters.
Referenced by KERNEL_PY.iparameters.IParameters::append(), KERNEL_PY.iparameters.IParameters::setParameter(), and KERNEL_PY.iparameters.IParameters::setProperty().
◆ decodeEntry()
virtual std::string SALOMEDSClient_IParameters::decodeEntry ( const std::string &  entry)
pure virtual
◆ encodeEntry()
virtual std::string SALOMEDSClient_IParameters::encodeEntry ( const std::string &  entry,
const std::string &  compName
pure virtual
◆ getAllParameterNames()
virtual std::vector< std::string > SALOMEDSClient_IParameters::getAllParameterNames ( const std::string &  entry)
pure virtual
◆ getAllParameterValues()
virtual std::vector< std::string > SALOMEDSClient_IParameters::getAllParameterValues ( const std::string &  entry)
pure virtual
◆ getDefaultVisualComponent()
virtual std::string SALOMEDSClient_IParameters::getDefaultVisualComponent ( )
pure virtual
Static implementation is supposed
◆ getEntries()
virtual std::vector< std::string > SALOMEDSClient_IParameters::getEntries ( )
pure virtual
◆ getIdParameter()
virtual std::string SALOMEDSClient_IParameters::getIdParameter ( const std::string &  entry)
pure virtual
◆ getLists()
virtual std::vector< std::string > SALOMEDSClient_IParameters::getLists ( )
pure virtual
◆ getNbParameters()
virtual int SALOMEDSClient_IParameters::getNbParameters ( const std::string &  entry)
pure virtual
◆ getParameter()
virtual std::string SALOMEDSClient_IParameters::getParameter ( const std::string &  entry,
const std::string &  parameterName
pure virtual
◆ getProperties()
virtual std::vector< std::string > SALOMEDSClient_IParameters::getProperties ( )
pure virtual
◆ getProperty()
virtual std::string SALOMEDSClient_IParameters::getProperty ( const std::string &  name)
pure virtual
◆ getValue()
virtual std::string SALOMEDSClient_IParameters::getValue ( const std::string &  listName,
int  index
pure virtual
◆ getValues()
virtual std::vector< std::string > SALOMEDSClient_IParameters::getValues ( const std::string &  listName)
pure virtual
◆ isDumpPython()
virtual bool SALOMEDSClient_IParameters::isDumpPython ( const std::string &  theID = "")
pure virtual
◆ nbValues()
virtual int SALOMEDSClient_IParameters::nbValues ( const std::string &  listName)
pure virtual
◆ parseValue()
virtual std::vector< std::string > SALOMEDSClient_IParameters::parseValue ( const std::string &  value,
bool  fromEnd = true
pure virtual
If fromEnd is True the search of separator starts from the end of the string
◆ setDumpPython()
virtual void SALOMEDSClient_IParameters::setDumpPython ( const std::string &  theID = "")
pure virtual
◆ setIdParameter()
virtual void SALOMEDSClient_IParameters::setIdParameter ( const std::string &  entry,
pure virtual
◆ setParameter()
virtual void SALOMEDSClient_IParameters::setParameter ( const std::string &  entry,
const std::string &  parameterName,
pure virtual
◆ setProperty()
virtual void SALOMEDSClient_IParameters::setProperty ( const std::string &  name,
pure virtual
