SALOMEDSClient_IParameters.hxx
23#ifndef SALOMEDSClient_IParameters_H
24#define SALOMEDSClient_IParameters_H
26#include <string>
27#include <vector>
28#include <map>
32
37{
38public:
39
41
47 virtual int append(const std::string& listName, const std::string& value) = 0;
48
52 virtual int nbValues(const std::string& listName) = 0;
53
57 virtual std::vector<std::string> getValues(const std::string& listName) = 0;
58
62 virtual std::string getValue(const std::string& listName, int index) = 0;
63
67 virtual std::vector<std::string> getLists() = 0;
68
72 virtual void setParameter(const std::string& entry, const std::string& parameterName, const std::string& value) = 0;
73
77 virtual std::string getParameter(const std::string& entry, const std::string& parameterName) = 0;
78
82 virtual void setIdParameter(const std::string& entry, const std::string& value) = 0;
83
87 virtual std::string getIdParameter(const std::string& entry) = 0;
88
92 virtual std::vector<std::string> getAllParameterNames(const std::string& entry) = 0;
93
97 virtual std::vector<std::string> getAllParameterValues(const std::string& entry) = 0;
98
102 virtual int getNbParameters(const std::string& entry) = 0;
103
107 virtual std::vector<std::string> getEntries() = 0;
108
112 virtual void setProperty(const std::string& name, const std::string& value) = 0;
113
117 virtual std::string getProperty(const std::string& name) = 0;
118
122 virtual std::vector<std::string> getProperties() = 0;
123
128 virtual std::vector<std::string> parseValue(const std::string& value, const char separator, bool fromEnd = true) = 0;
129
130
134 virtual std::string encodeEntry(const std::string& entry, const std::string& compName) = 0;
135
139 virtual std::string decodeEntry(const std::string& entry) = 0;
140
144 virtual void setDumpPython(const std::string& theID = "") = 0;
145
149 virtual bool isDumpPython(const std::string& theID = "") = 0;
150
155 virtual std::string getDefaultVisualComponent() = 0;
156
157};
158
159
160#endif
Class which an interface to store the parameters of the objects.
Definition: SALOMEDSClient_IParameters.hxx:37
virtual int nbValues(const std::string &listName)=0
Returns a number elements in the list.
virtual std::vector< std::string > getValues(const std::string &listName)=0
Returns a list of values in the list.
virtual std::vector< std::string > getEntries()=0
Returns a list all entries.
virtual std::vector< std::string > getProperties()=0
Returns a list all properties.
virtual int append(const std::string &listName, const std::string &value)=0
Appends a string value to a named list.
virtual void setIdParameter(const std::string &entry, const std::string &value)=0
Sets an id parameter value for the given entry.
virtual std::string getDefaultVisualComponent()=0
Returns a default name of the component where the visula parameters are stored.
virtual ~SALOMEDSClient_IParameters()
Definition: SALOMEDSClient_IParameters.hxx:40
virtual std::vector< std::string > getAllParameterValues(const std::string &entry)=0
Returns all parameter values of the given entry.
virtual std::string encodeEntry(const std::string &entry, const std::string &compName)=0
Returns encoded entry that is a relative entry for the component.
virtual void setDumpPython(const std::string &theID="")=0
Enables/Disables the dumping visual parameters, static implementation is supposed.
virtual std::string decodeEntry(const std::string &entry)=0
Returns decoded entry that is an absolute entry.
virtual std::string getIdParameter(const std::string &entry)=0
Gets an id parameter value for the given entry.
virtual std::vector< std::string > parseValue(const std::string &value, const char separator, bool fromEnd=true)=0
Breaks a value string in two parts which is divided by separator.
virtual void setProperty(const std::string &name, const std::string &value)=0
Sets a global named property value.
virtual void setParameter(const std::string &entry, const std::string &parameterName, const std::string &value)=0
Sets a new named parameter value for the given entry.
virtual std::vector< std::string > getLists()=0
Returns a list all entries lists.
virtual std::vector< std::string > getAllParameterNames(const std::string &entry)=0
Returns all parameter names of the given entry.
virtual std::string getValue(const std::string &listName, int index)=0
Returns a value with given index, where index is in range [0:nbValues-1].
virtual int getNbParameters(const std::string &entry)=0
Returns a number of parameters of the given entry.
virtual std::string getProperty(const std::string &name)=0
Gets a value of global named property.
virtual std::string getParameter(const std::string &entry, const std::string &parameterName)=0
Gets a named parameter value for the given entry.
virtual bool isDumpPython(const std::string &theID="")=0
Returns whether there is the dumping visual parameters, static implementation is supposed.
string name
Definition: pythfilter.py:56
index
Definition: python_test_driver.py:105
